Examples of skip stop/express services on the Tube (or DLR & LO too)
Taunton
1 Aug 2013
The DLR at West India Quay was rebuilt with a flying junction for Bank to Lewisham trains to avoid the flat junctions (in passing, the nearest thing you will find to a roller-coaster this side of Thorpe Park - sit at the front). This line is unable to call at West India Quay southbound. When first opened it was only used in daytime; at late evenings etc it continued to use the old way and stop there, but now the flyover is always used. As a by-product it meant the Stratford to Canary Wharf route, which needs very close control with its single-line sections, is thus wholly independent of the other DLR routes, and thus can run at its own frequency instead of having to be interleaved with the other lines, and/or importing its delays to them, which was really the flyover's greatest benefit.
The District Line peak hour nonstops of the 1950s-60s were when it was running at 40 trains per hour (beat that, modern computer signalling). After some track alterations, for westbound trains when the Circle Line turned off just east (then) of South Ken, the following Richmond non-stopped South Ken and Gloucester Road. Likewise when a District turned off for Wimbledon the following Ealing non-stopped West Ken and Barons Court, all to even out the intervals.
The minor stations, now closed, skipped by alternate Piccadilly Line trains, which platform porters indicated by shouting "Passing xxxx" station, seemed to fascinate the pre-war literature world; there was a West End play called "Passing Brompton Road", and then later no less than John Betjeman wrote a thriller radio play about South Kentish Town and getting trapped in there.
The peak hour "skip-stop" Subway trains described above existed in several US cities; Chicago also had several such lines. The very lengthy routes into suburbia and the frequent stops - you can commonly see the stations either side when waiting - means progress is slow and tedious to the line extremities, so it was a way of speeding things up as well. They have tended to be withdrawn as the suburban areas outside the centre served by such lines lose their population and have reduced frequencies.
jumble
1 Jul 2011
Aside from the Met line fast and semi fast peak time services to Amersham/Chesham, the non stop run between Finchley Road and Wembley Park and the Piccadilly line non stop run between Hammersmith and Acton Town
What other skip stop/express services has the tube ran in the past? I know that the District line ran such services until 1960s
Does the Chiltern line that skips Moor Park fit your criteria as it goes on the same tracks ?
There are also a couple of trains a day that are HoTH to Amersham and VV non stop
NorthKent1989
13 May 2017
Thank you for this information :)
Didn’t some Wimbledon District trains skip West Brompton? Were these from Edgware Road or from the main line?
Amazing to think that the old District line was able to fit in a skip stop service with 40tph!
Yes it certainly does count :)
Acton1991
20 Jan 2019
Lots of skip stops on the western section of TfL Rail out to Reading and Heathrow
Mojo
7 Aug 2005
Don’t know but I know West Brompton used to be closed on weekends.
rebmcr
15 Nov 2011
St Neots
To be fair, the stops skipped were not on the 40tph section, and indeed could only be fitted into the timetable on the sections immediately following a drop in tph.
Dstock7080
17 Feb 2010
West London
some Ealing trains also non-stopped South Kensington, Gloucester Road
and Hounslow trains non-stopped Ravenscourt Park, Stamford Brook
Mikey C
11 Feb 2013
I was on an express Overground "North London Line" service last Thursday!
As it was running late, and there was another train soon after it, it ran fast between Camden Road and Stratford, which was perfect for me :D
I've seen this happen on other occasions too, whereas I don't recall it happening on the Underground, where they prefer to turn trains around short if they are bunched up after a delay.
NorthKent1989
13 May 2017
I recall a few years ago being on a delayed ELL train which ran fast from Forest Hill to Surrey Quays, to my knowledge it’s only happened once on that line, but I have heard this sort of thing happens regularly on the NLL
Dave W
27 Sep 2019
North London
I vaguely recall in the last round of strikes the Victoria Line only stopping at maybe two or three stops between Victoria and Finsbury Park due to staff shortages and resultant overcrowding.
Made my journey home a lot quicker!!! But I think that's drifting too far from the subject.
mr_jrt
30 May 2011
Brighton
The Northern line originally had passing loops on the Edgware extension from Golders Green. As I recall, when the trains were lengthened to 9 cars, the loops weren't long enough, especially when coupled with the platform extensions, so the loops were removed. The primary example was at Brent (now Brent Cross) tube station.
I've seen photos of them before, but can't seem to find any online. You can however see the loops very clearly on old OS maps:
The space where they were is also very obvious at the station today.
Mojo
7 Aug 2005
What stations does this skip? I’m not familiar with that line
On the Off-peak timetable; Acton (Main Line) is only served by the 2tph to the Airport, and West Ealing / Hanwell are not served by the Reading trains.
When the full Crossrail service and planned Off-peak timetable starts opening it gets a little more complex, for example Acton (Main Line) will be served by 4tph to Terminal 4 only, and Hanwell will get trains to all terminals, but not to Reading. Peak hours it becomes a little more complicated, as there will be a Semifast service run by the Crossrail Toc replacing the GWR Semifast train.
Acton1991
20 Jan 2019
Yes, unfortunately Acton Main Line seems to be the loser when the full timetable launches
Mojo
7 Aug 2005
Not really - it doesn’t lose anything but still gains significantly from 4tph all week long vs the previous 2tph Mon - Sat which stopped at about 20.30.
rogercov
8 Feb 2019
Coventry/London
I can remember the District Line trains that ran non-stop through South Kensington and Gloucester Road in the 60s. Of course, that was when all 4 tracks were operational at those stations.
For a long time after that, the enamel indicator signs at Earls court still had the panels for this, with the writing painted over, but you could still make out the words "Not stopping at ...." under the paint.
Are any of these old style indicators still left at Earls Court, and do they still have this panel?
Taunton
1 Aug 2013
The layout at South Ken/Gloucester Road has changed several times over the years. Until the 1950s there was a flat junction to the east of South Ken, the Circle then used the northern pair of tracks, the District the southerns. This reflected the original separate ownerships of the Metropolitan and District railways. To minimise conflicts this was rearranged so the westbounds used the two south side tracks and (separate) platforms, the eastbound on the north side, which allowed a westbound Circle to be held at Gloucester Road to cross the eastbounds without holding up following services, and also the following District to be non-stopped and overtake. This was further rearranged in more recent times, so we have now just the central island platform in use at South Ken.
Dstock7080
17 Feb 2010
West London
Only Gloucester Road WB (now unused) and Earl's Court retain the District Railway 1908 blue describers.
the plates have been changed over the years, most recently 2008 when 'new Johnston' font was sadly used.
I attached above an example of the not-stopping plates used at Earl's Court and Sloane Square - and indeed many other stations.
Taunton
1 Aug 2013
rogercov
8 Feb 2019
Coventry/London
Thank you, Taunton and Dstock7080 for the replies. I guess the panels are all fairly new so there's no evidence of the non-stop trains.
I just remembered that I posted a 1960s picture of South Ken over 2 years ago here:
Not a non-stop train, but a good bit of nostalgia!
Scotrail314209
1 Feb 2017
Edinburgh
Similiar on last Thursday too.
Was waiting at Northwood for a Southbound Metropolitan Line, services were a bit broken because of a problem at Amersham affecting just the Metropolitan. Ended up waiting 20 minutes for it to roll in.
Started off as an All Stations to Aldgate, as soon as we got to Harrow-on-the-Hill the driver announced that the service was running non stop to Finchley Road. Good for me as I was going to King's Cross, which cued half of the train to alight onto the all stops directly adjacent.
We got to Finchley Road where the train then got curtailed to terminate at Moorgate. I wonder how late it was to have it happen, this was also about 8pm.
Dstock7080
17 Feb 2010
West London
Only one that meets that description is T425 21043/44 ex-Amersham pfm.2 20.03; Northwood 20.20; HoH pfm.6 20.30; FL pass Wembley 20.35; Finchley Rd 20.41 altered to Moorgate; arr Moorgate pfm.3 21.00. Dep 21.05.
Scotrail314209
1 Feb 2017
Edinburgh
Yep. That was it. I barely saw anything going the opposite direction either while waiting at Northwood, for about 10 minutes. Then a Chesham came hurtling through followed closely by two trains to Watford.
Acton1991
20 Jan 2019
Ignoring the fact that it gains direct trains right across to the other side of London of course.
Compared to other stations in the west, 4 TPH isn’t exactly generous. But yes, 2 stops to Bond Street isn’t all bad
zero
3 Apr 2011
In 2018 or 2019 I was on a train that went W Croydon, Norwood J then non-stop to New Cross Gate. This was because of earlier delays, but luckily for me I was actually late and the express put me almost back on time.
simple simon
13 Feb 2011
Suburban London
I once read a truly delightful story about a timetable compiler for the UndergrounD who worked at the (then) Underground Group / Combine HQ at St James Park...
Apparently one of the westbound evening rush hour District line trains which he arranged to run 'fast' was timetabled to leave St James Park 'not long' after the end of his working day and it missed out more stations than usual, but only between there and Chiswick Park - which is where he 'just happened' to live.
Mcq
24 May 2019
Covent Garden (Piccadilly Line)was skipped except when the market was trading I think
duncanp
16 Aug 2012
There have been instances of trains on the Victoria Line skip stopping Seven Sisters in order to separate opposing groups of football fans.
On certain occasions when Spurs are playing at home, away fans are taken by the police to Tottenham Hale, and put on to Southbound trains.
This Southbound train then doesn't stop at Seven Sisters, to avoid the away fans mixing in large numbers with the home fans.
This doesn't happen at every game, but it has definitely been used in the past, where the match is contentious, or where the police have reason to believe there will be trouble.
