Excess for an OP to Anytime Upgrade
Discussion in 'Fares Advice & Policy' started by kbrockie, 10 Jan 2017.
Thread Status:
  1. kbrockie
    kbrockie New Member
    2
    4 Feb 2015
    Hi there
    Wondering if I were to upgrade the return portion of a OP Day return to use at peak time would I have to pay the fuil difference between the OPDR and ADR or just for 1 portion?
    Journey is LBT-EDB return. Fare with railcard Anytime £8,45, OP £6.25.
    cheers
    Keith
  2. najaB
    najaB Veteran Member
    15,405
    With reference to the forum rules:
    What is an OPDR or ADR when they're home?
  3. Bletchleyite
    Bletchleyite Veteran Member
    21,059
    Up and down the south WCML (mostly)
    Assuming you mean off-peak to Anytime, the full difference is due for a change of ticket type excess.
  4. yorkie
    yorkie Administrator Staff Member Administrator
    34,933
    These don't appear to be valid fare codes. But, whatever the ticket type it is the full difference (as detailed in our Fares Guide).
    Fortunately these are valid station codes! For anyone without easy access to a computer, that's Larbert to Edinburgh
    http://www.brfares.com/#!fares?orig=EDB&dest=LBT&rlc=DIS
    The cost of the excess is £2.20
  5. paulweaver
    paulweaver Established Member
    2,332
    3 Oct 2015
    Nantwich
    Does this excess need to be paid before boarding the train (assuming the Ticket Office is open), or can it be paid on the train?
  6. najaB
    15,405
    If possible, before boarding.
  7. yorkie
    34,933
    It's the same price, but where ticket inspections occur prior to boarding, the passenger can be sent to the ticket office.
  8. Bletchleyite
    21,059
    Note that the new NRCoT allow a Penalty Fare to be charged for a ticket invalid due to time restrictions, which was not the case before. Therefore, I would say if there is a ticket office open you must do it before boarding. You can't do it at a TVM so one of those is not relevant.
  9. paulweaver
    2,332
    3 Oct 2015
    Nantwich
    Do Scotrail do penalty fares?
  10. yorkie
    34,933
    No, and my understanding is that the legislation doesn't allow for a PF to be issued in these circumstances either.
  11. 185143
    185143 Established Member
    2,376
    3 Mar 2013
    The penalty fare notice I was sat next to on Merseyrail today did not mention PFs being chargeable when using off peak tickets at peak times
  12. yorkie
    34,933
    That's correct, they aren't.
  13. furlong
    furlong Established Member
    1,321
    28 Mar 2013
    Reading
    I don't see how anything has changed here. The new wording might be "simpler" but it doesn't change the actual Penalty Fares schemes it is merely attempting to summarise.
    The SRA Policy which still governs all Penalty Fares schemes is unequivocal:
    And the old wording supporting this is still present, now in 9.4:
    Remember, Penalty Fares meant to offer a fast-track resolution in situations where it is reasonable to infer that the passenger is being dishonest and could (in principle) be prosecuted successfully under RORA. (Typically, the passenger ignored both unambiguous signage insisting that he or she pay before travelling and usable ticketing facilities.) Where the facts of a situation can also be explained reasonably in an alternative way that does not demonstrate deliberate evasion, then allowing a Penalty Fare to be issued is inappropriate, and I think that that's what the Rules are trying to cover here and why they have to err on the safe side.
    You hold an Advance ticket that clearly states it's only valid on a different train? Safe to assume you know what you are doing and attempting to avoid buying a new one.
    You hold an Off-Peak ticket that's invalid because of rarely-simple restrictions? The Penalty Fares system has to give you the benefit of the doubt for the reasons the policy lays out, but that doesn't preclude the direct use of RORA where sufficient evidence of deliberate evasion is present.
Thread Status:
Share This Page
