Merseyrail
Ormskirk-Preston
Kirkby-Wigan Wallgate
Kirkby-Bootle New Strand
Bidston-Wrexham Central
West Kirkby-Hooton via Heswall & Neston (Wirral Loop)
Ellesmere Port-Runcorn North
Hunts Cross-Bootle New Strand/Aintree (Outer Circle)
Albert Dock-Sandhills via Edge Hill (Inner Circle)
Highly unlikely I know but would like to see the short underground branch to Dingle off the Liverpool Central to Hunts Cross line reopened. (This was the southern terminus of the Liverpool Overhead).
The station is in use as a car garage. Whilst the area surrounding the former station is well populated this may well not be suffice on its own and a higher order land use (e.g. large development such as an university campus) in the area may be required to develop the critical mass to justify such a project.
The old LOR tunnel is at a higher level than the Hunts Cross line (in fact crosses it on a bridge within the tunnels). How do you expect to solve this disparity in level?
Dingle is between St Michaels and Brunswick (which did not coexist with the LOR) and not too far from either. How much traffic do you expect to use a reopened Dingle even if any modern train could fit into the tunnel and could climb any gradient to get to it?
Eccles-Leigh
This also would be a good idea. Leigh NEEDS to be rail connected to Manchester. This would be a far better means of doing this than the daft 'Busway' idea that is being floated at this time. If is is routed properly, then the Towns of Tyldesely, Mosley Common and Worsley would really benefit with a Metrolink service into central Manchester.
St Werburgh's Road-Fallowfield
Possible this might work if you continued past Fallowfield and terminated the trams at either Guide Bridge, to extend them through Hyde and terminated them at Marple Rose Hill. This would release capacity on heavy rail services running into Piccadilly from Chinley & Sheffield.
Fewer people correlate with fewer stops per mile (hence less noise and more speed), less robust fencing/walls and also with the presence of more wild animals and livestock that are potentially strays onto the line.Wrexham- Birkenhead/Liverpool indeed.
If it is safe enough where there are lots of people why is 3rd rail too dangerous modernly(?) where there are fewer people?
I don't think that it is because nobody cares but that the only way to extend in to the west end would be extensive tunnelling or lots of demolition of peoples homes. Both would be too expensive for the north east.
Funnily enough they have been tearing down parts of Benwell and Elswick in the past so I see now problem of doing it now. Bu tI see your point. Some thing has to be done though as they cant carry on just having bus services
It would require a steeply graded approach i.e. embankment from the Brunswick side. Similar probably to the gradient which Valley Lines trains climb immediately east of Cardiff Central before crossing the South Wales main line.
Out of interest is the bridge on which the old LOR tunnel crosses the Hunts Cross line still extant?
Whilst not having tunnel dimensions the LOR trains seemed sizeable enough.
Reopening St. James is probably a much more realistic prospect.
Safety measures that were good enough in days of yore no longer are, for various reasons. Urban routes tend to be sturdily fenced even for OHLE. In the end this makes overhead electrification cheaper than 3rd rail for rural routes but about the same as 3rd rail (or even more) for dense urban routes.
The St Werburgh's Road to Fallowfield item you mention would appear to be the old Fallowfield Loop Line. Has there ever been any recent discussions on the future strategic transportation use of of this once well-used South Manchester suburban railway?
Not to my knowledge Paul.
There have been quite a few posts on SSC in re. to it being reused. However, given that the route was rather circuitous & has since been built over at Fallowfield, there really isn't much justification for reopening.
Rather than electrifying all the way to Wrexham, I'd propose Bidston to Neston only. Two extra stations would be needed. One at woodchurch to cater for the expanded estate there and a new station about a mile to the south of Neston to provide a service to Little Neston and Ness. Looking at the area, there is land available to build decent stations there. The "Little Neston & Ness" station would be the terminus for Merseyrail, and the diesel service by ATW would ferry passengers from Wales to join the Merseyrail service around the Wirral Line loop to Liverpool.
Better minds than mine would be able to figure out how such a service would fit into the present West Kirkby and New Brighton schedules.
Slightly more fanciful, but how about extend Merseyrail just to Woodchuch and have the Borderlands Line intechange there and then turn eastwards to a new high level station at Birkenhead Central, perhaps with an intermediate station at Oxton? It could make the line more useful and perhaps long distance services from South Wales could run. Would require a lot of demolition though; mostly of wealthy properties where the people insist on driving everywhere no matter what when and there would be uproar, but it'd be fun none the less.
Definitely sub-optimal to turn trains back at Neston.Rather than electrifying all the way to Wrexham, I'd propose Bidston to Neston only. Two extra stations would be needed. One at woodchurch to cater for the expanded estate there and a new station about a mile to the south of Neston ... The "Little Neston & Ness" station would be the terminus for Merseyrail, and the diesel service by ATW ...
"Fanciful" you may call this idea....others will have a different turn of phrase.
Good grief no, I think that it's bad enough that the service between Sunderland and Newcastle was "downgraded" from Pacers and Sprinters (At least Pacers have toilets, and the North East ones have had high back seats for the past 12 years or so) to the shake, rattle and roll Metrocars and their extended journey times (Although at least the coming of the Metro to Sunderland provided a massive increase in capacity between Sunderland and Newcastle that is very much used to the full). Let alone considering extending the Metro network to cover journeys of around 80 minutes from Newcastle to Middlesborough.What about extending the Metro all the way to Middlesbrough, electrifying the entire route at 1500V? It would yield Monument-Middlesbrough travel times similar to those on the Metropolitan line from Amersham to Bakers street.
Once upon a time a chord (for freight trains) was proposed at Shotton. Constructing that would make it possible to electrify from Bidston, via Neston and Hawarden Bridge to Chester. Which gives a lot more travel possibilities.
Overhead electrification of course.
Such as yourself? Go on, don't leave me in suspense
Had I wished to make a comment, I would have. It was yourself who used the word "fanciful" to describe your own posting. I was hoping to warn you that you may have elicted a response from other members, with the wording of the final part of your posting.
I doubt that this was really necessary though Paul; if people have something to say about a post they'll normally say it regardless.
Following on from the "Ghost train" thread , Ellesmere Port to Runcorn North sounds like madness.
The ELP-Helsby section has vitually no services with almost no passengers now. Electrification isn't going to change that.
Runcorn passengers can get onto the Merseyrail network at Liverpool South Parkway with a simple change .
I can't see even a seed of a business case here.
