Well, it was only a study.In that case, we might see it Haddington back on the railway map sooner than I thought.
Hence the "might"Well, it was only a study.
Both reasons were given.I thought the main reason they routed through Shawfair, instead of reinstating Millerhill was because of the new town development?
Hard to think there is ever much chance of Haddington being back on the railway map tbh.In that case, we might see it Haddington back on the railway map sooner than I thought.
What's your better rail suggestion? (Given that this is primarily a rail-focused forum)
None of which really speak to rail projects in the Lothians.Priorities, priorities. Mine, in order:
I have, as our American cousins would say, zero skin in that game seeing as I don't live in and have never even visted Haddington.you can have your Haddington branchline.
He could go to Longniddry and use the Haddington line, as it's still open - for bikesOne advantage of reopening the Haddington line is that non car owners like my son would have a direct route which is only 4 miles long . Ironically he does a wee bit of presenting at the community radio station located on the old station site but to get there needs two or three buses via Prestonpans or Wallyford.The one bus alternative is limited by timing and the route is a long way round ( via Gullane and Drem) for a short cut!
So that would be one gap filled
He doesn't need to go to Longniddry--- we live here!He could go to Longniddry and use the Haddington line, as it's still open - for bikes
I agree but it will be interesting to see how they would fit the second pair of tracks in at certain points.If there has to be one in East Lothian (there have been several in West and Mid), the suggested quadrupling of part of the ECML would be more sensible than a branch.
As I see it in the long term I think there could be capacity problems at Waverley East End.The branch couldn't happen without the quadrupling. As it is the ScotRail ECML services are starved of paths, and a new branch would necessitate an extra service all the way to Waverley. Extra services are already most of the reason for the four-tracking, so it would be perfectly logical to look at new places to terminate them rather than sending them to North Berwick or Dunbar. This study (and all of them) might well find out that it's not actually worthwhile to do the thing suggested
Tokyo Central has two platforms up in the roof reached by a ramp as well as underground platform's with long tunnelled approaches.
Is this the way forward?
It would also possibly be a reason why a Haddington Branch reopening might never happen.
I doubt that they would build a new line alongside the A1 because of the gradients and as I understand it the section to be quadrupled is from Wallyford to Drem which is at least 3 miles and a range of hills away from the A1.
That it could well take a different route to the present line is more than likely given the amount of curvature there is over the length of the section.The long removed footbridge at Lochhill farm looking east gave a really good view of the s bend past Ballencrieff towards Drem for example.
I was wondering that; there was a line into HMNB Clyde, closed 1981. I presume this doesn't mean reopening that, given it wouldn't be a passenger line (presumably) unlike everything else to be considered.On another note, what could improved access to HMNB Clyde look like? A new station on the WHL? One idea could be to set up a regular hourly commuter service along the southern end of the line. The 2043 Route Study had an hourly service to Crianlarich, and this could be a precursor which would hold the paths through the suburban network until then. I don't think it would be at all viable to extend North Clyde electrics services there as Helensburgh Central can't really go down from 2tph and there's no more paths for other trains along the city centre section.
Possibly, but then you are mixing local and long distance services again.Playing Devils Advocate,if you build the new pair of tracks alongside the A1,the Haddington Branch from Longniddry wouldn't need to be reopened - the new line would pass along the North side of Haddington and cross the trackbed of the old line!
At which point it would be where I suggested could be the site for a Park and Ride!!
Would it though?I imagine it might be slightly challenging to get a totally new line (very likely requiring fresh legislation)
It is not the flow from Liverpool to Edinburgh that would justify extension of TPE to Edinburgh but the flow from West Yorkshire. At present passengers from Huddersfield have to change either at Leeds (XC), York or Newcastle (East Coast). Halifax, Bradford, Dewsbury, Bingley and Keighley, all large settlements, will have a better spread of services from Leeds without having to change at Leeds and again at York or Newcastle. You know what they say about changes in a journey deter passengers. It would also give Northallerton more choice of East Coast or TPE.That's all very well but instead of extending TPE from Newcastle to Edinburgh they should just allow XC to have these paths and extend their services to Edinburgh where possible and instead run more TPE services between Liverpool and Scotland via the WCML instead of the 3 or 5 a day that's proposed.
But you could still build a cut-off for Dunbar following the route of the new A1. It would cut out the speed restricted reverse curves on the mainline (80mph) and allow a continued 125mph without braking. The old line could then be used for looping long freights using fast entry and exit speeds.It wouldn't happen. That new line following the A1 would need to remain an express route. Haddington would need to be served by stopping ScotRail services that would need to go via the old line. The bypass line and the Haddington branch could be somewhat symbiotic, as the new branch would be a sweetener to get the locals to accept the new line while the need to fit in the new line might mean the A1 needs reconstructed in a way which provides a space for the branch to run underneath. A park-and-ride station on the wrong side of the A1 might not be fantastically useful for the town given that park and ride passengers would probably prefer a station on the main route with more services, while local passengers wouldn't appreciate having to go more than 2km from the town centre to the station.
Stops at Reston and East Linton could be added to TPE services as a condition of extension to Edinburgh without having to extend Edinburgh-Dunbar services all the way to Berwick.
Would it though?
There is still a corridor between new houses and the A1 road for this to happen.
Northbound though it would allow acceleration sooner so might save a few minutes.I don't think there would be a lot of benefit from doing that. Linespeed has to drop not far south of here for the curves through Grantshouse, so extending the non-stop speeds wouldn't give a huge amount of journey time reduction.
I believe that is why the section being spoken about for quadrupling is Wallyford to Drem and I believe it will be either next to the existing line or very close to it.I don't think pure journey times are the focus here, rather the increase in capacity for freight and local stopping services. If a big chunk of the stopping services would have split off to North Berwick or Haddington there's not so much point four-tracking through Dunbar. I don't think they would bother grade-separating the eastern end of a new line given that slow line traffic would be in the minority there.
