Extra London Midland trains Crewe to Euston?
No, there wont be two extra trains per hour, in the evening peak there will be to Crewe. Can't see anything about an extra Manchester to Birmingham either (which there won't be)
Because it isn't there to exploit whilst you are building HS2 at Euston...
Nothing to stop more Birmingham-Manchester/Liverpool/Preston services.
If the extra capacity is not usable, I won't ask what the point of building the flyover was... ;)
Resilience. You don't have to use every path if you don't need it.
I'm sure it didn't say that on the business case.
It would parrot the NR line about more paths in all directions. ;)
It's like the extra capacity at Manchester Airport - ask for bids and then refuse them all.
HS2 wasnt considered in CP4 or 5 business plans and until it gets Royal Assent you still cannot technically call it a certainty.
Baxenden Bank
23 Oct 2013
No point timetabling extra trains if you can't run the existing ones. Last northbound train from Stone today was the 1650 (1U39, 1446 from Euston) - no 1750, no 1945, no 2105.
WatcherZero
25 Feb 2010
Depends how you define considered, the CP5 plan allocated £36m to assist the Dft in HS2 and develop network interfaces (junctions between the networks).
