They probably ran it directly from Milton K into Wembley Yard.
I would imagine that the reason for terminating at Milton K in the end had less to do with how late it was per se and more to do with there being no platform capacity available at Euston when it would have eventually got in.
The "rumour" doing the rounds at Northampton was that 1M11 was diverted via Northampton from Rugby due to the late running, and the driver didn't sign the route but realised he was going that way when it was too late. The hold at Northampton was for a replacement route competant driver to work the train forward and then it was so late by the time that was sorted that it was terminated at MK
Virgin could of maintained the 87s better but it was a case of no one wanted to use them including Anglia. At least they have been kept in use in Bulgaria instead of on the scrap heap like some. 86/6s still going strong on the Freightliners so there is no reason why 87s could not still be in use over here even on freight duties or Scotrail could of used them on the sleepers instead of 90s.
Did the 90s not fail?
I think you knocked the nail on the head - "no one wanted to use them". Cotswold Rail, GBRf and even DRS dabbled with them but ultimately gave them up.
Scotrail has nothing to do with providing traction for the CS - National Express and First sub-contracted it to EWS/DBS.
Well i guess EWS or DBS could of taken some then
If we're talking train lengths, the "highland" and "lowland" sleepers are identical lengths out of (and into) Euston.Yes only 1, 2 and 15 can manage the highland. The lowland is a little shorter so it might fit on others like 3 and 4 but don't quote me.
I refer the honourable member to the answer I gave a few moments ago (#89)!
One query that popped to mind was how many of the crew are signed off on the 87 who also sign the WCML?
Constantly in their early days!
hashtag 89???
...yes, you're completely right. Why on earth did I think the lowland was shorter? Chalk it down to tiredness on my part.If we're talking train lengths, the "highland" and "lowland" sleepers are identical lengths out of (and into) Euston.
What are the chances of Class 88's appearing on the sleeper when they arrive?
I don't buy that idea - the engine was defective. The sleeper presumably always goes via Northampton when it is as late as it was on Wednesday morning and almost all freight goes that way so a freight driver would know that route. Surely a driver reports an incorrect route setting as soon as they are aware and would know what the signals were telling them about the route. The train appears to have run to alongside the Kings Heath depot (where I woke up) before failing there having run through since the problems at Stafford. That is quite a long way from Rugby. Also, there were obvious signs of the engine being reset detectable by the air conditioning going on and off.
Zero .... as GBRf are contracted to provide traction to Serco and, as far as I'm aware, only DRS are looking at 88s.
Not TUPE as such, as that is a TOC-TOC process, but I understandHow many GBRF drivers are trained on 90s then? I didn't know that GBRF operated 90s, unless the sleeper drivers were TUPEd over from DBS to GBRF, but that seems very unlikely!
TUPE is exactly what it is.
