Solent&Wessex
- Joined
- 9 Jul 2009
- Messages
- 2,683
What happens when such queries arise with Travelling Passengers is that staff too often lack the expertise and/or the inclination and/or the resources to check and clarify the position, even when they repeatedly encounter the same issue (as with the Manchester-Reading via London example above).
They rely on intuition (e.g. 'a cheaper ticket can't be valid when a more expensive ticket exists') and frequently deny the relevance of the Routeing Guide.
It is this behaviour that is unacceptable and must be addressed through effective training.
Sadly though this reaction from some staff is sort of understandable, as I posted on another thread.
If you are not given effective training by your employer, your employer fails to tell that such things as the Routeing Guide actually exist (and in some cases when you enquire to your employer about it you are told it either doesn't exist or it is outdated and irrelevant), the internal notices you see only give you very vague information about things (generally along the lines of a cheaper ticket can't be valid when a more expensive ticket exists) and you have no one to contact to find out (the person on the other end of the phone in control probably knows less than you) then what do you do? Listen to the passenger, who is using some complicated ticket combination that you have never been told about - but everything you have been told by your employer gives you the impression they might not be valid - and tells you to look it up in a document you have never even heard of, or your employers training. You might be inclined to believe that the passenger is trying to pull the wool over your eyes and is in fact invalid.
