FANTASY: You're in charge of refurbishing a train
30 Sep 2017
The Land of the E12
What train would you refurbish, and what would you do to it.
I would take the Class 314 and add garbage bins, a toilet and WiFi
class387
9 Oct 2015
Class 700s to the same layout of a 387 with Scotrail style cushions.
No longer here
390 Pendolinos:
Coach K to be refurbished along the lines of Frecciarossa Executive Class and sold at a premium.
Staff will not be allowed to sit there - and if they do need a break, two seats in Coach J to be denoted as Staff Only with red antimacassars for their use.
Pendolino (and indeed any long distance unit) - Grammer IC3000 seats as much aligned to windows as feasible on spacing similar to the present.
Could be tempted to suggest adding an intermediate "business class" in coach U with 2+2 Grammer IC3000 seats but at First Class spacing with recliners. About half would be full tables and the other half airline style "mini tables" like Coach K has for those wanting privacy. Sockets throughout. Fixed fee to upgrade rather than a separate fare range.
Standard maybe consider some areas of 3+1 seating instead of 2+2, the groups of 6 facing seats would be popular with groups and the single seats (airline style) with solo travellers.
RLBH
17 May 2018
My wife's answer for her commute: rip out the 2+3 seating on Class 318s and replace it with longitudinal bench seating 'like on the Underground'. I'm not entirely sold on this approach.
Warwick
10 Apr 2018
On the naughty step again.
Applies to any train. Put in nice comfortable seats.
Applies to any train. Give us some legroom.
Those trains from Exeter to Woking are impossible to sit in properly in the airline type seats for me. I'm not really that tall at 6' 2".
RichJF
2 Nov 2012
Sussex
Southern Class 377 (as it's the only EMU on my line outside peaks):
2+2 seating throughout & narrow 3+2 seating removed.
Seats to align with windows.
Luggage racks/foldable cycle space installed where the seats leave an odd gap.
Table seats to have a double plug/USB installed at the window level on tables.
Wifi installed throughout.
Inter-coach sensor doors replaced with handle operated doors.
Class 700 style first class compartment to properly separate 1st class from standard class.
LED lights internally & on unit ends (marker/headlight).
Units repainted into overall green (excluding doors obv) to evoke old Southern livery.
Number 1 painted on doors where 1st class is located.
Fit pantographs to make future cascade easier.
bussnapperwm
18 May 2014
WM 172s
Add WiFi, USB charging points, more "bay seating" in the non toilet coach, plus a luggage rack in coach c
507021
19 Feb 2015
Chester
Northern Class 319s:
Replace the 2+3 seating (where possible) with 2+2 seating and tables with USB charging points.
Install Wi-Fi, air conditioning and LED lighting.
Install luggage racks.
61653 HTAFC
18 Dec 2012
Another planet...
Class 150/2. Remove one row from each section and space out.
That approach would apply equally to the 155s...
As this is a fantasy thread:
The soon-to-be displaced 315s/317s/319s/321s (whichever are in better condition).
  • Install diesel engines in the sections between each cab and the closest set of doors. Battery packs also an option.
  • Interiors completely gutted and replaced with the better Fainsa seats from Northern's sham roadshow in 2+2 formation split 50/50 between bays and airline arrangement.
  • The spaces where the door-pockets mean no windows fitted alternately with luggage stacks and single longitudinal priority seats.
  • Disabled loo in the inner end of the centre trailer, with tip-up seats in the area surrounding, including a pull-out table as seen in the "ballroom" of the 185s.
  • Traction motors replaced with modern AC motors.
  • Air-conditioning fitted, with lockable hoppers on alternate windows in case of failure.
  • Mini-tables (CIG/CEP-style) at facing bays. Pull-down tray tables and cup holders at airline seats.
  • Free WiFi fitted including the ability to work in tunnels, and each pair of seats given one 3-pin plug and 2 USB ports.
  • AC capability retained, and 3rd-rail capability also retained where applicable.
There you have it, a reasonable bi-mode unit for regional and stopping services!
driver_m
8 Nov 2011
Put the 2 original Merseyrail units back out there with insanely bright headlights so it doesn't need yellow ends. Stick the relevant gubbins in the cabs like GSM etc Stick a few pp3's in for non third rail hehe and run them as BR did as a sideline for goodwill .And do exactly the same with any other AC/DC units away from the southern region in the same manner .
Hadders
27 Apr 2011
Class 700 fitted out to the same interior design as the original 365 layout.
alangla
11 Apr 2018
The real life refurb(s) of the class 334 has been pretty good, adding mains power, WiFi, air con and better interior and exterior colours, the only missed tricks were not going 2+2 in the middle coach & putting tables in as per 318/320, so basically add those two things to the 334 and it would be perfect.
Geoff DC
27 Jan 2018
Penzance
On XC Voyagers convert one car to a lavatory car ( asian & euro choices)
1 or 2 cars to all standing ( 1 on a 4 car - 2 on a 5 car) 5th Class
1 car on a 5 car to be 3+2 seating 4th class
The existing 1st class to be more correctly sold as 3rd class
3 carriage 144.
Remove a row of seats from every carriage and move the rest down a bit. Also install seat back and window tables.
MML HST
Refresh seat coverings where necessary. That is all.
LOL The Irony
29 Jul 2017
Chinatown, New York
Class 185
Fit Grammer IC3000's in standard and as many tables as possible. Add a massive luggage rack in coach B by in front of the toilet cubicle. First class would have VTWC first class seats. All seats will be half leather and have a 3 pin plug & 2 USB ports (one with a data transfer function). They will all be semi permanently coupled in 6 car formations.
Parallel
9 Dec 2013
I’d refurbish GWR’s 165s/166s to ATW 158 standards, complete with new 2+2 seating with small head rests, new armrests, tables, better lighting and a deep clean and a repaint. And although not sorted on the ATW or GWR units, I’d also make air conditioning/cooling a priority!!
alangla
11 Apr 2018
Fit Grammer IC3000's in standard.
The Grammer IC3000 briefly became the standard IC seat, with variants in GWR HSTs and quite a lot of Class 158s. It needs to return, with the Government inspired Class 800 seat being dumped.
First poster's name is appropriate - I remember when the first Grammer fitted HSTs were coming into service, the seats were described as tombstones, the coaches were claustrophobic and clinical because the seats blocked any view of a window not directly alongside and also any view down the coach plus the lighting was left on its "eye-searing" full power, so zero view out at night. How times change...
The Scotrail 158 Grammer fit is pretty good, to be fair, but those FGW HSTs are awful compared to GNER interiors from the same era.
In 10 years time there will probably be posts on here bemoaning the loss of the 800's seats...
Class465fan
12 Jun 2016
abbey wood
Surprised that no one has mentioned the class 442 yet so here it goes.
Remove airline seating interior in order to reform the original seating layout along with the buffet/snug area.
Remove first class area on the motor coach and move it back to driving trailers.
First class carriage would have a compartment layout like they had in the NSE/SWT days.
DarloRich
Fenny Stratford
Take Voyager. Push over cliff. Go home.
Seriously - rip out the insides of the voyager, fit nicer seats, lighten the decor, remove at least 1 of the toilets, take out first class, fit free wifi and plugs at every seat, remove any catering provision and use every inch of space for seats.
