Fares via Halton Curve
Discussion in 'Fares Advice & Policy' started by M28361M, 8 Apr 2019.
  1. krus_aragon
    krus_aragon Established Member
    3,869
    10 Jun 2009
    North Wales
    Indeed. To paraphrase: if you have to change train, it's not a direct train.
    There should be fares created for the Halton route from further afield (or adjustments made to the routeing guide), but they haven't been yet.
  2. M28361M
    M28361M Member
    247
    15 May 2014
    I see from a post in the Routeing Guide thread that mapped routes have now been added via the Halton Curve, and the original test journey I used in my first post (Liverpool South Parkway to Llandudno) now offers journeys via Runcorn. Great news!
  3. supervalkoinen
    supervalkoinen Member
    185
    21 Sep 2010
    But still no fares for other reasonable and fastest routes/journeys from Wirral stations - e.g. no through ticket available from Eastham Rake or Hooton to Runcorn via Chester.
  4. lyndhurst25
    lyndhurst25 Member
    882
    26 Nov 2010
    Still no "via Runcorn" fares to Chester from Merseyrail Northern Line stations. It's a simple change at Liverpool South Parkway onto the new service via the Halton Curve, but having to buy an expensive "Any Permitted" ticket to use it means most passengers from the north Liverpool suburbs will still be going Merseyrail all the way via Birkenhead.
  5. tony_mac
    tony_mac Established Member
    3,492
    25 Feb 2009
    It looks like the new fares have been added using a very limited number of specific stations only, and not the usual clusters.
    You can't even get a ticket from Liverpool Central, never mind the suburbs.
    You would think, having spent around £20m upgrading the line, that they might actually want people to use it. (I guess that none of the budget actually goes towards fixing the ticketing).
  6. lyndhurst25
    lyndhurst25 Member
    882
    26 Nov 2010
    Another thought. What about Excess Fares between the "via Runcorn" and "via Birkenhead" routes? The potential complicating matter is that Merseyrail doesn't do Off Peak Day Returns (CDRs), but instead issues a TOC restricted Day Saver ticket.
    Liverpool to Chester:
    "via Runcorn" SDR £7.50
    "via Runcorn CDR £6.00
    "via Birkenhead" SDR £7.80
    "via Birkenhead" no CDR exists but passengers are sold a Merseyrail Daysaver at £5.30
    Can you excess up a Day Saver to travel via Runcorn for 35p each way? Is a "via Runcorn" CDR also valid via Birkenhead as it costs more that a Day Saver?
  7. Merseysider
    Merseysider Established Member Fares Advisor
    4,254
    22 Jan 2014
    Tickets cannot be excessed to/from Day Ranger/Rover tickets.
    The excess payable would be to the equivalent CDR or SDR fare, as available.
  8. ForTheLoveOf
    ForTheLoveOf Established Member
    5,044
    7 Oct 2017
    Is a Day Saver valid between Liverpool Lime Street and South Parkway on TOCs other than Merseyrail?
  9. 185143
    185143 Established Member
    2,934
    3 Mar 2013
    No. You need a Saveaway (valid on all TOCs within Merseyside, buses and the ferry) which costs a massive TEN PENCE more than Merseyrail's sham Day Saver.
  10. lyndhurst25
    lyndhurst25 Member
    882
    26 Nov 2010
    Another shambles from our not-joined-up railway then. Merseyrail should never have been allowed to withdraw CDRs and replace them with the DaySaver. It has implications for RailCard holders not getting discounts and also here for excess fares.
  11. nedchester
    nedchester Established Member
    1,030
    28 May 2008
    At Helsby this morning the station ticket machine couldn't issue a via Runcorn ticket (£6.00)
    Bought a mobile one instead. The tickets were also available from the conductor.
    As a separate issue the first train was well loaded......
  12. infobleep
    infobleep Established Member
    8,534
    27 Feb 2011
    I wonder how many people had valid tickets for the first train or would it not be possible to reach the first train without a valid ticket, given the time of the morning it was running.
  13. LNW-GW Joint
    LNW-GW Joint Veteran Member
    12,699
    Just to answer my own question from before the service started, I used a Cheshire Day Ranger via Runcorn yesterday without problems.
Share This Page
