Death
Hail again everyone!
Firstly, cheers to those who helped me with split fares last time around! Thanks to that darned useful Chiltern fare from Woking to Birmingham, I've been able to take another two journeys Northbounde in recent times for little more than I'd normally pay for an SDR into London!
Anyhow; On the 7th August, I'll need to travel from Farnborough Group (FNB or BAW - Either's fine) to Haverfordwest for a coaster club event at Oakwood, returning on the 9th...But despite having sat down in front of Avantix for a total of at least four hours so far now, the one reduction that I've been able to find knocks a wapping £4.30 off of the standard Y-P Saver price!
Given the amount of poking and prodding and split/route experimentation that I've tried so far, I reckon that I should've found at least one way to knock a tenner or so off of the fare by now. :roll:
As far as I know the method that I'm using is fairly close to the "right" way (Split at TOC boundaries, cover as much distance as possible per TOC, and use as few TOCs as possible) but no matter whether I split at Reading, Salisbury, Bristol, Cardiff or Swansea (Or even all five! hock any reduction in the per-mile cost of one end of my journey seems to become balanced out by an above anticipated increase on the other end.
To give an example: If I use HVF-SWA-CDF-NWP-BRI-SWI-RDG as my route and I split at Reading, the fare comes in at £49.40 (6.50 + 42.90)...However if I split it at Cardiff, the eastern half goes for £35.65, but then ATW bump that up to a total of £51.25 by chinging me £15.60 for my western bit!
As far as journey/route preferences go I'm pretty flexible in this case as long as I can arrive there by 18:00 at the latest and don't mind which way I wind up going...I'm definitely open to routes that'll fill in a little more of my coverage maps in the process!
By the by: I'll be bailing at Clunderwen on the outward journey, just in case that info helps.
Anyhow...If anyone knows of decent semi/non restricted promo fares knocking around for the Western Region at the moment (Anything like the Chiltern one that I use as a budget return between WOK & BHM would be perfect!), or cheaper routes that I might've missed, then I'd be most greatful and thankful to hear about them. I've attached a copy of my current fares "research" to the end of this post so that ye can see where I've been already...Assuming that ye can understand my strange and fragmented ASCII heiroglyphs!
Farewell for now, and many thanks in advance for any further help!
>> Death <<
Death's home-brew fares research via Avantix:
>> Death <<
Code:
[color=#AA0000][b]Northern route[/b][/color] - fGWR services along WoE line from BAW:
[b]Splitting: Fare1 + Fare2 + Fare3 = Total Remarks:[/b]
RDG, NWP 6.50 + 34.30 + 19.10 = 59.90
RDG, CDF 6.50 + 35.00 + 15.60 = 57.10
RDG, SWA 6.50 + 38.30 + 10.90 = 55.70
RDG, BRI 6.50 + 25.75 + 23.35 = 55.60
BRI, SWA 26.40 + 18.15 + 10.90 = 55.45
SWA 42.25 + 10.90 = 53.15
NWP 33.00 + 19.10 = 52.10
BTH 23.75 + 28.10 = 51.85 Split Bath. Call plumber for repair.
RDG, SWI 6.50 + 13.20 + 30.35 = 50.05
BRI 26.40 + 23.35 = 49.75
CPM 21.10 + 28.40 = 49.50
RDG 6.50 + 42.90 = 49.40
[color=#AA0000][None] 48.85 = 48.85 Standard Y-P SVR fare chinged by fGWR[/color]
SWI 14.20 + 30.35 = 44.55 Split Swindon, SOR to Hwlffordd
[color=#0000AA][b]Southern route[/b][/color] - SWT services via Salisbury & Warminster from FNB:
SAL 14.90 + 36.30 = 51.20
SAL, BRI 14.90 + 13.55 + 23.35 = 51.80
BRI, SWA 23.05 + 18.15 + 10.90 = 52.10
SAL, CDF 14.90 + 18.80 + 15.60 = 49.30
CDF 31.60 + 15.60 = 47.20
NWP, CDF 26.65 + 4.60 + 15.60 = 46.85
SWA 35.00 + 10.90 = 45.90
CDF 29.90 + 15.60 = 45.50
