Bill Badger
- Joined
- 28 Nov 2008
- Messages
- 284
I'm trying to work out the permitted route(s) from Farnborough to Cuxton.
Farnborough is a Routeing Point
Cuxton has Maidstone and Chatham as Routing Points.
Comparing fares i find the following:
Farnborough Cuxton
Anytime £24.90
off peak £23.50
Farnborough Chatham
Anytime £26.20
off peak £24.60
Farnborough Maidstone
Anytime £26.20
off peak £25.20
So to see which routeing points are valid I need to check fares, however this is where I'm not sure what to do as Cuxton has a lower fare in all instances than either Maidstone or Chatham. The Routing Guide appears to try to address this problem as follows
But that doesn't really make sense as I can't use these fares as they are higher!
Any advise gratefully received!
Cheers,
Kevin
Farnborough Cuxton
Anytime £24.90
off peak £23.50
Farnborough Chatham
Anytime £26.20
off peak £24.60
Anytime £26.20
off peak £25.20
Routeing Guide said:In exceptional circumstances, due to local fares policies, a direct comparison may not be possible. If this is the case and the origin station or destination station has a lower fare of the type selected than all its routeing points, the Standard Single (Day or Open) fares should be used for comparison purposes.
Cheers,
Kevin
