Farnborough to Reading
Steddenm
2 Mar 2017
Clane, Co. Kildare
I've noticed that fares between Farnborough (North or Main) to Reading are cheaper than a Farnborough Main to Basingstoke return, yet one of the routes is via Basingstoke to Reading?
So I'm guessing a Farnborough Main/North to Reading ticket is valid via Basingstoke and not just on GWR services from North? And can you split at Basingstoke on the return and come back later? Thanks.
Farnborough Main/North to Reading is indeed valid via Basingstoke.
I'm not sure what your last question means; are you asking if you can break your journey? Yes you can, though I don't know if this would be hassle-free.
You can but I've no idea if the ticket would work the barriers, as if they don't, how the staff would react.
FenMan
13 Oct 2011
This only applies to Off Peak tickets, which have different validities on weekdays.
The Farnborough - Basingstoke Off Peak ticket (priced by SWR) is valid after 0859, so, using the May timetable, is valid on the 0903 from Farnborough Main, arriving in Basingstoke at 0928.
The Farnborough - Reading Off Peak ticket (priced by GWR) is valid after 0914, so the first valid service from Farnborough Main to Reading via Basingstoke is the 0933, arriving in Basingstoke at 0958.
