Fastest route between South Western Main Line and King's Cross/St. Pancras?
Discussion in 'Trip Planning & Reports' started by Muzer, 13 May 2015.
Thread Status:
  1. Muzer
    Muzer Established Member
    2,475
    3 Feb 2012
    I've been wondering this for a while, and thought I'd ask here since I suspect at least one person has probably worked it out in great detail ;)
    If you're heading from a SWML station to King's Cross, assuming your train stops at Clapham Junction, what is the best route? Three that immediately spring to mind are:
    * Clapham to Victoria, Victoria line
    * Clapham to Vauxhall, Victoria line
    * Waterloo to Oxford Circus on Bakerloo, Victoria from there
    Any ideas which is the best option (or if there's a better one I've overlooked?)
    Rail Forums
  3. SpacePhoenix
    SpacePhoenix Established Member
    5,492
    18 Mar 2014
    Depends on day of travel, I think one possibility is Waterloo & City line to Bank then Northern line to Kings X/St Pan.
  4. yorkie
    yorkie Administrator Staff Member Administrator
    37,428
    That would be slower than any of the options above, unless there were delays on the Victoria Line.
  5. TheNewNo2
    TheNewNo2 Member
    1,003
    31 Mar 2015
    Canary Wharf
    The Bank branch is slower than a slow thing (it always feels that way anyway). Probably getting off at Vauxhall or Victoria is best (whichever your train goes to), gives least changes anyway, and the Victoria line is usually pretty fast, at least when they haven't flooded their signalling room with concrete. To be perfectly frank it's one of those ones where there is no right answer.
    Of course, you could always get the Northern Line from Waterloo to Euston and then back to KGXSTP, or have a walk.
  6. LexyBoy
    LexyBoy Established Member Fares Advisor
    4,460
    23 Jan 2009
    North of the rivers
    I'd say Victoria from Vauxhall if your train stops there, otherwise Bakerloo/Vic from Waterloo. The change at Oxford circus is cross-platform and access to the tube is nearly as quick at Waterloo as Victoria.
    Of course if you're me you'd then spend 20 minutes wandering the tunnels of KXSP before coming out at the furthest possible exit from whereever you're going.
  7. phil281
    phil281 Member
    174
    9 Mar 2011
    I do this journey almost every day to work!
    A lot of it depends on the time of day, in the peak I go to Vauxhall (using the windsor line trains, easier to get on). In the peak you often sit outside Victoria for ages waiting for a platform and then often the tube is closed due to overcrowding or the queues are horrendus. It is much easier to board the Victoria Line at Vauxhall.
    Outside the peak it is quicker via Victoria.
  8. theorangeone
    theorangeone Member
    31
    26 Aug 2013
    Central London
    Vauxhall, any day. Factoring in interchange time at Clapham Junction, the crawl into Victoria and how crowded it is, Vauxhall. Even at off-peak times it's so much more pleasant to change at Vauxhall.
    Bak/Vic at Waterloo is the best of the other options.
  9. James Wake
    James Wake Member
    814
    30 Aug 2013
    When I need to get on the Victoria line coming up from Sussex, I tend to get off at Clapham Junction, then Vauxhall, then use my free Oyster from there, as my paper ticket only covers 2-6. I find the Vauxhall change quick, and have done train to tube without rushing in 3 minutes.
  10. phil281
    phil281 Member
    174
    9 Mar 2011
    Another thing to consider, if you go to Victoria it is much better getting one of the suburban services from platfrom 14 at Clapham (even if it stops at Battersea Park) as the walk from the platform to the tube is much shorter and less congested from platforms 9 to 12 at Victoria than 15 to 19.
    If starting from Clapham Jn, it is definitly quicker by 5 minutes or so via Victoria off peak, I do this every day.
  11. Mike99
    Mike99 Member
    176
    4 Mar 2011
    Fareham
    Via Waterloo,
    Bakerloo line to Oxford Circus, cross platform interchange to Victoria Line Northbound to Kings Cross St Pancras.
    Regards
    Mike
  12. DarloRich
    DarloRich Veteran Member
    17,947
    Work - Fenny Stratford(MK) Home - Darlington
    Surely Vauxhall to Kings Cross on the Victoria?
  13. Kite159
    Kite159 Established Member
    10,323
    27 Jan 2014
    West of Andover
    Heading towards King Cross, I tend to use Vauxhall as it is gently less crowded to get to the underground platforms, and you have a better chance at getting a seat on the Vicky train.
    Coming back I tend to change at Oxford Circus and head to Waterloo, unless I'm against the clock then it's straight to Victoria for the first thing which calls at Clapham.
  14. Hadders
    Hadders Established Member
    4,811
    27 Apr 2011
    Vauxhall is the quickest. Be in the rear most carriage upon arrival at Kings Cross St Pancras to make the quickest exit. This is the Euston Road exit rather than via the signed route at the other end of the platform to the Northern Ticket Hall.
    Also, if you're catching a Great Northern train that stops at Finsbury Park then stay on the Victoria Line to Finsbury will be even quicker.
Thread Status:
Share This Page
