Fawley Branch freight traffic
Harbornite
7 May 2016
Two questions here.
First, how often do the Marchwood MOD facility's sidings get used? I assume that this will vary depending on Britain's military commitments.
Secondly, I heard that traffic to Fawley Esso will cease on August 25th, with the last freight train running on that date. Can anyone confirm if this is the case?
Cheers.
Freightmaster
7 Jul 2009
Two questions here.
Typically one/two trains a week, either a trip working from Eastleigh yard
or a 'special' (class 3) through working from Kineton or Longtown
Correct, although the only remaining traffic is crude oil from Holybourne (Alton);
the last remaining outbound fuel oil traffic finished last year.
MARK
Harbornite
7 May 2016
MARK
Thanks. This is a pity, I hope that the line is retained in case traffic picks up again.
Does this mean the Holybourne tanks are going somewhere else? Or does it cease to be a rail served terminal?
montyburns56
5 Oct 2015
I don't know if that's likely as most of the oil is now transferred by pipeline just like it is at Stanlow. That's just the way the industry works these days.
Harbornite
7 May 2016
UK Rail Tours visit the branch on the 5th November
Ah right.
I remember an article in the railway mag which was about petroleum traffic and it painted a grim picture with regards to loss of freight from oil terminals. The cessation of this working isn't really a big surprise.
The Ham
6 Jul 2012
Although, this means less freight traffic on the two lines, could this mean that there could be scope for more passenger services (either an increase in the Alton line or new services, as are often suggested, for the Fawley line)?
As if IIRC one of the reasons that the Fawley line doesn't have passengers is due to the freight paths that had historicity been required.
NSEFAN
17 Jun 2007
Southampton
IIRC the Alton line has a couple of daily gaps in the half-hourly service to provide a path for the Holybourne tanks to run? These could now be filled in with passenger services.
Regarding the Fawley line, there was a study done fairly recently which seemed to conclude that it wasn't worth reinstating services to Marchwood and Hythe, as it would abstract from the local buses which would then risk being culled. It seems a shame as the site of Marchwood and Hythe stations are largely intact (especially Marchwood). Fawley would be out of the question as it's in the middle of the oil refinery now.
Edit: this is the report, from 2013, with the following quote.
However, the latent demand in the area, overlayed with existing good provision of public transport (bus / ferry) in the area, is not sufficient to support the service. Should rail services be a strong priority, one of the other public transport modes would need to be sacrificed, and that has a host of political ramifications associated with it.
marrk
15 Oct 2016
sad to hear the Esso refinery at Fawley is closing.. i spent many night staring through the windows at the flares lighting up th night sky. happy childhood memories.
jimm
6 Apr 2012
The refinery is not closing.
The equipment used at Fawley to empty the oil trains was worn out and Esso didn't want to spend money on renewing it when the supply from Holybourne was a tiny proportion of the crude oil that is processed there.
Class 170101
1 Mar 2014
I doubt it would get a through service to London except in the peaks (portion working) even if it was electrified due to capacity constraints on the SWML and at Waterloo but given issues with Third Rail extensions, as discussed elsewhere, I cannot see that being likely.
Local DMU only therefore to / from Southampton Central I would have thought.
There have been a few different threads on this subject, and as discussed in one of the other threads the current view of Network Rail (in the Wessex route study) is that there is no likelihood of a passenger service at all. Hampshire County Council are not remotely interested.
Mire discussion here: http://www.railforums.co.uk/showthread.php?t=134955&highlight=fawley
