Fenny Stratford - Grantham
DarloRich
Fenny Stratford
Morning,
I fancy a trip to Grantham for the football on Saturday 9th April but it needs to be as cheap as possible. I have some spare cash and a rare free weekend.
The cheapest I can find is:
£5 advance MKC to Nuneaton
£36 East Midlands Day Rover
£5 advance From Nuneaton to MKC
The routes via London and via Leicester seem VERY expensive - can anyone suggest something better? I only have a Netwokr Gold Card which is of little use.
Cheers!
OwlMan
25 Jun 2008
Bedworth, Warwickshire
From Milton keynes - Nuneaton advance out £5 ret £5
Nuneaton - Leicester advance out £4.70 ret £4.70/£2.60)
Leicester - Grantham Off Peak Day Return (via Nottingham) £14
Total max £33.40
bangor-toad
20 Feb 2009
Hi there,
What about:
X5 bus to St Neots: £13.15 return
Off Peak Return, St Neots to Grantham: £24.20
Even with the bus being a bit slow it still seems quite reasonable compared to the routing needed sticking to rail only.
If you do want to stick with rail only and don't want to be tied to advances only then you can split at Long Eaton for about the same as what you've got:
MKC - Long Eaton. £38.40 (Return)
(Travel valid via Nottingham)
Nottingham to Grantham: £8.80 (Return)
Cheers,
Mr Toad
philjo
9 Jun 2009
Could you use the X5 bus from Bedford to St Neots? split the fares at peterborough
Fenny Stratford-Bedford - CDR - £4.35 (with Gold card)
St Neots - Peterborough - super off-peak day return - £5
Peterborough-Grantham - off-peak day return £15.30
£24.65 plus cost of the bus - all rail tickets are walk-on fares.
DarloRich
Fenny Stratford
Thanks - The bus is a good option but the return time worries me. I will have a look..........
Is there any benefit in a Derby split as that might let me come back via Birmingham?
Romilly
5 Nov 2013
2 x £5 MKC/Nuneaton Advances could be combined with a £24.40 Nuneaton-Grantham offpeak day return or, at a cost in journey times (as you would be restricted to trains that call at Hinckley), with a £5.40 Nuneaton-Hinckley return and a £17.50 Hinckley-Grantham return. Total: £32.90 or £34.40.
And for MKC-Nuneaton, an offpeak return is £12.20 with an annual gold card, if you prefer to avoid Advances, but the discounted ticket can only be used on LM trains.
Edit: the £24.40 Nuneaton-Grantham ticket is (per the VTEC journey planner) valid via Tamworth, Derby & Nottingham, or via Leicester & Nottingham, or via Leicester & Peterborough, or via Birmingham New Street, Tamworth, Derby & Nottingham.
DarloRich
Fenny Stratford
Romilly - genius. I completely forgot to look at a Nuneaton - Grantham leg! doh. I will go out via New Street and back via Peterborough
thanks
