FGW class 153 diagrams
12CSVT
18 Aug 2010
Does anybody know what services the FGW 153s are diagrammed to work on weekdays ?
I am hoping to track down the last one I need to clear the class (153368) when I am in the South West next week.
TEW
16 May 2008
They are diagrammed to work a huge amount of services. Three are in use on the Falmouth branch, one on the Newquay branch and one on the Looe branch. One is spare at Plymouth all day until it works the 1557 Plymouth-Penzance. Two or three operate on Exmouth-Barnstaple/Paignton service all day. One works the 1607 Exeter-Plymouth and 1746 return. One should be on the 1102 Westbury-Southampton, 1227 Southampton-Great Malvern and the 1650 Great Malvern-Southampton should have two 153s on from Gloucester to Westbury. A couple more operate around Bristol but I'm not 100% sure on what services.
12CSVT
18 Aug 2010
Thanks for that. Looks like Devon and Cornwall account for the majority of diagrams, but as you say they operate over a very wide area.
158757
14 Aug 2007
Another booked service is 0800 Cardiff-Paignton and 1248 return paired with a 158. Then does 1700 Cardiff-Taunton but not sure what after that.
Good luck with your hunt, I still need 8 153s to get the lot but I'm working on it! :D
142
17 Oct 2009
This one is booked 153 though it can throw prety much anything up depending on whats available.
1008 Westbury - Warminster
1025 Warminster - Westbury
1111 Westbury - Southampton
1227 Southampton - Great Malvern via Bristol
1649 Great Malvern - Southampton via Swindon (1 153, however another booked to join train at Gloucester (1750) as far as Westbury, usually the 153 thats "hot spare" at Gloucester most of the day)
This one is booked to have a 150 + 153 on the train most of its journey though it can attach and detach where required (it has been taken off/put on at westbury/bristol/gloucester depending on if there is a unit shortage.
0524 Westbury - Salisbury
0604 Salisbury - Westbury
0638 Westbury - Gloucester
0842 Gloucester - Weymouth
1310 Weymouth - Gloucester
1642 Gloucester - Weymouth
This is booked to run 143 or 150 or 153 or 158 (usualy 150/1 or 153, always 153 on a Sunday)
1932 Westbury - Cheltenham via Swindon
2200 Cheltenham - Swindon
2333 Swindon - Gloucester
Hope this helps
EDIT : not sure how my post appeared twice.
1910 Taunton - Bristol, all stations then ECS
Schnellzug
22 Aug 2011
Evercreech Junction
I think that like with most FGW DMU diagrams, more or less anything (anything with bogies, at any rate :roll:) can appear anywhere really. At least, on routes from Bristol. The 1310 from Weymouth (above) was more often than not a 153+150 in Summer, but is usually a 150 this time of year.
TEW
16 May 2008
Yes, there's plenty of 153s on Weymouth trains in the Summer, but less at this time of year. The diagram which works Southampton-Great Malvern and return does seem to be a 150 more nowadays.
ValleyLines142
25 Jul 2011
Gloucester
This is usually a 150 and a 158 as opposed to a 153. I see it every morning coming into Cardiff on the 0619 from Bristol.
TEW
16 May 2008
Used to be a 158+153. Now that the final two-car 158s are being disbanded it may go to a single three-car 158.
heart-of-wessex
11 Jun 2005
Trowbridge
I've seen the Swindon to Cheltenham services as a 153 on a Weekday once, but also a 158/9 has been on it too so that can be anything it seems.
Also the 06:00 Portsmouth to Cardiff (1F06) has a 153 attached at Westbury (08:10) on a Saturday and drops off at Bristol TM (arr 08:47) which does something else after, don't know if it does the same on weekdays mind
TEW
16 May 2008
Same on weekdays, works the 0905 Bristol-Westbury, a return trip to Warminster and then the 1102 Westbury-Southampton. Nowadays it is often a 150 though.
83G/84D
28 Oct 2011
Cornwall
153368 assisting an ailing 150238 from Exeter today on 2C42 0524 Bristol TM - Penzance then 2P86 1046 Penzance - Plymouth.
Heard recently that FGW have had a successful bid for four extra units in addition to the cascaded examples from LO & LM but I don't know what the units are or where they are coming from.
Anyone able to elaborate?
Plan is to "double up" the 153's on the Falmouth Branch diagram from the December timetable change to ease overcrowding.
Ultimately when enough units are available the Falmouth branch diagrams will consist of 2 x 150 units and the 153's will be used elsewhere. Consideration is also being given to swapping the St Ives and Falmouth diagrams around in the short term to allow 2 Class 150 workings on the Falmouth and a 153 on the St Ives.
What happened to the FGW Class 153's they got rid of a year or two back and went into storage at Eastleigh?
TEW
16 May 2008
153325, 153333, 150202 and 150216 are the extra units, all now with FGW.
TEW
16 May 2008
Falmouth is already 3 153s, 2 on one diagram and one on the other. Thought the plan was for 2 Class 150s from December. 2 150s were used in the high summer this year. A 153 is fine on St Ives at the moment usually, but if you get a nice Saturday, or a nice day in the Christmas holidays the trains will be packed again.
83G/84D
28 Oct 2011
Cornwall
Well a couple of days this week it has been a 150 on one diagram and a single 153 on the other. I believe that is also the case today.
TEW
16 May 2008
150s are much more suitable to the line. The door layout on the 153s causes delays, which can quickly build up with the tight turnarounds on the line.
SprinterMan
20 Sep 2010
Hertford
Went to EMT (302/308/355/374)
153325 and 153333 are London Midland ones, Will they be going back to LM or staying with FGW for good?
Staying with FGW for good.
Why did FGW get rid of 4 153s only to take on 142s, 150s and more 153s.
None of it makes any sense.
83G/84D
28 Oct 2011
Cornwall
I never knew Falmouth was that popular.
Lots of students at Penryn due to the University there.
Drivers state that the 153's are heavier with the toilet installed and struggle to pull away from gradients.
Also heard an unconfirmed story a few months ago that the engines had been downrated to save on fuel and wear and tear!
Schnellzug
22 Aug 2011
Evercreech Junction
I don't think they had much choice about swapping the 153s for 142s; I think that was decided from On High. The 150s & the later 153s came later on, as they became available from LM.
BestWestern
6 Feb 2011
Yes they're stopping with FGW for good it seems. The alleged recent 'refurb' by LM appears to have consisted of a coat of fresh paint and little else, they're pretty grotty inside. Presumably there will be no FGW refurb done on them at this late stage in the franchise, although the swanky new P.I.S system they have is redundant (and means the cab-to-cab doesn't work with other units) so perhaps we'll see this being removed, maybe they'll even return it to LM! :D
TEW
16 May 2008
The PIS system is pretty useless, not sure the passengers really need to be constantly reminded that there on a Class 153. The refurb isn't that great in general, the door areas are still painted in that horrible orange.
30 Dec 2009
The PIS on 153325 and 153333 is to be removed by FGW and manual destination blinds refitted as before, they have a class 170 Public address system with is non standard on the 153s and use a different handset - which has been moved to a different place in the cab. I expect the PIS and internal PIS will be sent back to LM.
3 Aug 2009
Derby
How do you mean?
30 Dec 2009
The external and internal PIS is worked by entering your headcode, service code and day of the week and then it will show service calling pattern internally and final destination externally.
Also you can manually enter a code for the final destination to be displayed externally if your train is being diverted from its normal route or is calling at more or less station than normal for a certain service.
01 Not in Service
02 Divert Emergency
03 Divert Planned
04 Terminate Bus Forward
05 Terminate Taxi Forward
06 Terminate New Train
07 Delayed at Signals
08 Delayed Failed
09 Delayed Weather
10 Terminate Next Stop
11 Incident
12 Short Platform
13 Birmingham Moor Street
14 Birmingham New Street
15 Birmingham Snow Hill
16 Bromsgrove
17 Gloucester
18 Great Malvern
19 Hednesford
20 Hereford
21 Rugeley Town
22 Rugeley Trent Valley
23 Shirley
24 Shrewsbury
25 Stafford
26 Stratford on Avon
27 Tyseley
28 Wellington
29 Wolverhampton
30 Worcester Foregate Street
31 Worcester Shrub Hill
32 Walsall
WillPS
18 Nov 2008
Since all these units are going to need some form of PIS installed by 2020 - doesn't it make sense for all of them to take on the Turbostar PIS format?
