First Greater Glasgow
route101
16 May 2010
There's a low bridge at the bottom of Kilbowie Road so the 1/1A/1B/1E are single deck because of that and the 1C/1D can be extremely busy even off peak too so it's understandable as to why they're mostly double decker. The 1C is the closest bus to me and it can be just as busy off peak as any other service I've used in Glasgow
1 is one of the few routes i think thats built up passenger numbers , other being 77.
27 Mar 2014
Clydebank
Presumably all the 1s could be replaced by a new build low height double decker fleet. There's another bridge in Alexandria too.
However loadings on all 1s merit a larger vehicle.
ScotRail158725
27 Nov 2018
low height MMCs still dont fit under the bridge at Clydebank
JumpinTrainz
30 Jul 2018
I don’t travel on the 1 all that much passed Clydebank but is it really busy after that or are most commuters using it up until Clydebank as it’s the fastest way? Surely if they were willing to build low height E400s for the 6 at one stage then they would have did something with the 1 long before now? I don’t think any deckers fit under that bridge.
PaulMc7
9 Jul 2019
Usually busy until Old Kilpatrick then bowling isn't busy but it then picks up at Dumbarton again normally
duffers2324
1 May 2014
The only way i could see them putting deckers on the 1's obviously bar the 1C and 1D would be to make them run the same route as the 1D up to Second Avenue and then onto Duntocher Rd and back onto Dumbarton Road at Dalmuir but then that means missing a piece of Dumbarton Road between Kilbowie Road and Dalmuir so its a 50/50 do you make it all decker and miss out part of Dumbarton Road or do you keep it as is?
Then as mentioned the bridge at the Vale of Leven hospital which only the 1 uses as the 1A goes via napierston so does that mean that it will only be 1A's to be doubles or do they take the 1 out of the Vale of Leven grounds to put deckers on that as well? Which i personally think would be a bad idea for First in terms of taking it out of the hospital.
PaulMc7
9 Jul 2019
I'd probably keep it as it is tbh. The 206 already goes by the vale without going into it too so it would be pointless taking the 1 out unless they put the 206 into it
ScotRail158725
27 Nov 2018
Many years ago Dumbarton ran low height double deck metrobuses on what is now the 1.
So can't see any probem.
There has been no change to the bridge height since.
the bridge is 13”6 or 7 and a low height MMC is 13”9 so it doesnt fit
92002
27 Mar 2014
Clydebank
Don't seem to remerberany single decks ring created.
However if the bodybuilder want the job they will make sure they fit.
There are more than MMCs around too.
route101
16 May 2010
Cant see them ordering a bespoke order of Low heights. They do a good job of keeping the low heights on the 6 on the route , not
route101
16 May 2010
Used to 60 today , 2 came at once at the Forge . Earlier not two running together.
awsnews
13 Mar 2019
The walkway in the Vale hospital that had the height restriction was demolished some time ago, although not before one of the ex Eastern Counties Paragons managed to hit it.
Old Kilpatrick's RL bodied Dominators did go under Kilbowie Road bridge, but I think at that time the height limits were legally only advisories whereas now they are restrictions.
PaulMc7
9 Jul 2019
The busiest part of the route is definitely been between City Centre and Clydebank. Only thing I can think of is to run 3 smaller routes and start the 1/1A/1B from Clydebank to Balloch/Helensburgh instead.
Make a Faifley to city centre route and a Duntocher to City Centre one along with the 1D and run them with deckers. Might fix the reliability with the 1/1A/1B too if around 30/35 mins is cut off of the route
ScotRail158725
27 Nov 2018
I don’t imagine they’ll introduce a completely new bus type but it’s First so I guess you never know. Not to mention what may be getting cascaded in from other subsidiaries.
agreed, also arent wrights production lines still closed?
156478
3 Aug 2013
Funny how McGilLS dont accept a daytripper though
There's no accountability or reimbursement on Daytripper tickets. Unlike ZoneCard the Daytripper is not a neccessity for any bus operator to accept.
Unlike the Zonecard where the diary is used to apportion the revenue from the scheme, no such mechanism exists for DayTripper.
They know how many they have sold as each ticket has a number printed on them, but they have no clue when or how they are used because of the broad length they are potentially valid for- if you buy one at the start of the tickets validity its valid for three years.
Samuel88
20 Jan 2017
No excuse, every other major city in the UK has a fully integrated day ticket, it should be the case if McGill’s refuse to participate in the daytripper scheme, they aren’t allowed to bid for SPT funded routes or use SPT facilities...
Jordan Adam
12 Sep 2017
Aberdeen
That’s good news! I wonder if we’ll see any Streetdecks like was rumoured a few months back or whether it’ll just be E200/E400MMCs.
Streetdecks have never been rumoured for Glasgow and they won't be getting any. The only mention of Streetdecks was someone on here (i forget who) saying they'd hope Glasgow would buy some so there's variety in the fleet (which is fairly pointless).
JumpinTrainz
30 Jul 2018
There definitely was a rumour a few pages back that said they heard we were getting them. There was also another about Gemini 2s coming from down South.
Jordan Adam
12 Sep 2017
Aberdeen
There wasn't any rumours at any point about Streetdecks. The Gemini2s were due to move, but went / are going to FSW instead.
