Please post your example here
Your example is ideal if the restricted route is a permitted route according to the ATOC routeing maps.
Did you have any in mind?
As I recall, it says that in one of the examples, but is contradicted in other parts of the routeing guide.then you may not travel that route via the 'any permitted' ticket.
This one we had somewhere recently:
Nottingham - Lichfield City, but only Off-Peak Return, and Anytime First Day Return.
no, I'm trying to test some code. The routeing guide says (I think) that if a routed ticket has a higher fare than a 'any permitted' ticket, then you may not travel that route via the 'any permitted' ticket...
If the Any Permitted fare is less than the Manchester routed fare, the ticketholder may not go via Manchester.
I can't access the routeing guide atm, but I think you have mis-read it. My understanding is that an 'Any Permitted' ticket is valid on any route permitted by the guide, but is not valid on OTHER routes for which a higher fare applies.
...so you can't travel via a routeing point if it involves doubling back....Routes via Banbury and Coventry fail the route test for doubling back at Leamington.
...wait, so you can double back, as long as it is through Tyseley....But the journey is valid on direct trains from
Stratford-upon-Avon to Birmingham and from Birmingham to Solihull.
Changing at Tyseley is not permitted
But Mon-Fri the £66.20 SVR Manchester - London route Any Permitted is valid on trains arriving St Pancras at or after 1129, while the £90 SVR Manchester - London route Chesterfield is valid on trains arriving St Pancras at or after 1005.Manchester to London SVR is more expensive route Chesterfield yet it's permitted anyway
The railway gets hundreds of millions of pounds in subsidy, but they can't manage to employ one decent person, for even a couple of months, to sort out this abomination.
The National Routeing Guide said:How to determine Permitted routes
If a choice of routes is available and the fare for the journey is described as "Any Permitted" route or is unrouted, you are free to choose from any of the routes listed in the guide. Where the fare specifies a particular route. you may choose only those routes listed in the guide which pass through the station shown in the route description. The routeing guide may have to be used to find out how to reach the station shown in the route description. Where there are other permitted routes, these may also be used for the same journey provided that the same or a lower fare applies.
Ensuring the routeing points are appropriate
You may only use all the permitted routes if the fare is unrouted or the route is described as "Any Permitted". An "Any Permitted" ticket cannot be used for travel on a route not listed in the Routeing Guide for which a higher priced route specific fare exists. It can be used on routes not listed in the Routeing Guide for which a lower priced route specific fare exists.
.... I will check to see if the examples used now are the original ones adapted to suit the new maps at some point tomorrow.
