NotATrainspott
- Joined
- 2 Feb 2013
- Messages
- 3,224
We're going around in circles here, firstly, there's no need for a spur, second,
I'm not saying there is a need for captive infrastructure all the way to Midland. What I am saying is that it isn't just a matter of building the least amount of track possible to connect the two and then just leaving it as it is. If you want a fast and reliable NPR service while still allowing more classic services on the same line, you'll need to spend more than if you just wanted to allow more classic services alone.
Victoria isn't going to happen,
Given that the only unconfirmed part of the entire Phase 2 route is South Yorkshire it's pretty clear that the DfT and HS2 Ltd aren't so certain about that.
third, I'm out of this because you are just quoting different reports to suit whatever arguements you have.
Roll on Autumn and the preferred route then we can start talking HS2 with some degree of foundation.
You're stead fast in your belief that Victoria won't happen, regardless of whatever else I'm going to say. I'm presenting the entirely reasonable case that the most effective way to satisfy both the HS2 and NPR requirements is to combine them into one service running through Victoria.
