Freightliner East Mids Gateway - Felixstowe | Odd Routing this week?
ANTONOV 12BP
14 Mar 2019
As the title states, the query, in particular, is associated with the Freightliner intermodal service from East Mids - Felixstowe which seems to be assigned on quite the adventurous voyage down the NLL suburbs through Stratford via the speedy ECML cruise down Retford for this week & next week. Other Intermodals that are worked by DBC & GBRF are also engaging in this little venture too down the NLL and onto the ECML via the journey from the GEML. You'd think that the conventional journey down the March line would at least reduce a bit of mileage! As of currently, does anyone have any info concerning the bizarre routing in place? Thanks in advance!
Here is the odd routing in question: https://www.realtimetrains.co.uk/service/gb-nr:H64554/2021-07-27/detailed
Usual route: https://www.realtimetrains.co.uk/service/gb-nr:H64554/2021-08-09/detailed
GB
16 Nov 2008
Somewhere
Nothing bizarre as happens every 6 weeks or so while there is engineering work on the normal route.
ANTONOV 12BP
14 Mar 2019
I've also figured engineering work of the sorts would be the most plausible outcome to this routing mystery. But I just wanted to consult in case if I ended up jumping the gun a little too soon. What sort of engineering works are they carrying out there? Track renewal?
30907
OT, but I suppose there is a good reason why the service runs via Doncaster in the first place rather than via Syston Junctions?
Dr Hoo
10 Nov 2015
Hope Valley
When was Trent to Syston gauge cleared for larger containers on standard intermodal wagons?
