FSr 158 at St. Phillip's Marsh
Mojo
7 Aug 2005
I saw a First Scotrail-liveried 158 at Bristol St. Phillip's Marsh this morning.
Does anyone know why it's here & what number it is?
theblackwatch
15 Feb 2006
It is 158741 - it moved down from Haymarket yesterday and is expected to be used in the First 'launch' tomorrow. The unit chosen is one that has been reliveried in the past few weeks - I presume they will remove the 'ScotRail' branding!!
27 Jan 2006
this unit is on a short-term hire however this may change and 158 740 may also join 158741 down in FGW land
Max
8 Jun 2005
Cardiff
What will Scotrail put out instead of these then? Do they have loads of spare units kicking around?
27 Jan 2006
the ex hull 170's fill that space, however they will have another 158 coming out of glasgow works tomorrow in fsr livery so... i think they have enough at the moment.
Sprog
6 Sep 2005
SPM
Shame 741 is not on Malvern - Weston servies.
Id like to sample it.
Whats its interior like compared to Wessex/Central units
did the fSR refurb consist of an interior job aswell as just a re-paint into Barbie, or where the units o/hauled by National Express, so First hasnt touched them inside......?
Id like to see waht interior work First will do on the ex-wessex stuff :)
27 Jan 2006
The interior is the same but with the same seats as exATN's 156's, no the 158 has only been rep-painted (it will be re-done at a later date into the newer livery), the units were overhauled by Nat Ex, first will be fitting PIS boards to the 158's and also they will recieve new wall panels and new carpets/seat covers, it is likely that the first class will be removed
Coxster
9 Jun 2005
Dennis said that the interior of the 158 isn't anything special, with mould on the window frames IIRC?!?
Dennis
8 Aug 2005
Trowbridge
heres a shot of the interior http://dennis-lance.fotopic.net/p27663370.html
Not terribly good as I was being rushed by the traincrew who wanted to lock up and I did not want to upset them more after being told off for drawing some 'neon' stripes in the exterior dirt with my finger while waiting to board at Parkway!
Spot the difference between first and standard class - apart from the provision of hankies on the seat backs, I could not see any.
Generally, the 158741 does not show much sign of interior wear and was clean, especially the carpets. The table I was sat at looked awful and there was algae around the window frame. Otherwise much like any other CT or WT refreshed 158.
devon_metro
11 Oct 2005
Why do they need so much first class accomodation on a 158 which will generally work stopping service and only normally has 2 cars? Unless of course you give it to Wessex who put it on Penzance-Man Picc services :o Bad, bad experience :p
Jordy
9 Jun 2005
WCML South
ROFL! What else can I say ;)
Jordy
andel
8 Feb 2006
its only down to help boost the FGW services... I have heard that the 3 car 158 units are to go north....
