Furthest point below the Underground
TheNewNo2
31 Mar 2015
Canary Wharf
I took a walk today along the Northern Heights from Alexandra Palace to Edgware. Very nice, and along the way I walked under the Dollis Brook Viaduct, which, as everyone knows, is the highest point above ground level that the tube reaches (18m).
This set me wondering. By walking under it, I was 18m below the tube, but how far below the tube can one be?
So, here's the challenge. Where in London can one get, via tunnels presumably, more than 18m below a tube line? I'd imagine that the Victoria going under the SSL would have a good shot.
jopsuk
13 May 2008
Underground line (including SSL) or Tube?
Ianno87
3 May 2015
What about being on HS1, passing below either the Central Line (at Stratford) or District Line (at Barking).
Also, Heathrow Express tunnels underneath Piccadilly Line mught be a contender.
jopsuk
13 May 2008
There's a list of heights above sea level of all LU platforms here: https://www.ianvisits.co.uk/blog/2011/07/01/how-deep-is-every-tube-station-on-the-underground.
Jubilee at Westminster was my first thought. That's if being on one line below another is allowed.
If it is, then using that data (with its rather odd datum- I guess to avoid negative numbers as many platforms are below sea level) then the track level of the westbound Jubilee at Westminster is 24.4m below the District Line.
In fact, hell, we've got MAX and MIN functions in Excel. So then, greater than 18m difference:
Kings Cross St Pancras
Met/Circle/H&C 109.1m Northern 88.9m Difference 20.2m
Moorgate
Met/Circle/H&C 108.5m Northern Northbound 88.7m Difference 19.8m
Notting Hill Gate
District/Circle 119.4m Central Eastbound 97.1m Difference 22.3m
Waterloo
W&C 98.2m Jubilee 74.0m Difference 24.2m
Westminster
District/Circle 99.0m Jubilee Westbound 74.6m Difference 24.4m
Jubilee at Waterloo is furthest below sea level at 74 above datum- that's -26m. Metropolitan at Amersham is 249.3m above datum, a positively mountainous 149.3m above sea level- the Shard is 309.6m to the tip. The difference between the highest platform track and lowest is 175.3m
D Foster
5 Jan 2016
N Staffs
I suspect that the London water-main ring tunnel is the deepest under London. Does the Underground cross over it on one of its "tentacles"?
One would, of course, need a snorkel... :D
TheNewNo2
31 Mar 2015
Canary Wharf
I'll allow that - I think the rule should be that one could, in principle, stand in the tunnel, so no 6" electrical pipes.
DynamicSpirit
12 Apr 2012
SE London
Does being on a boat count? If so, I gather there would be a whole range of locations in the southern Pacific ocean that would be a full 12800 km below the Underground! :)
If any commercial airlines happen to fly over the vicinity, you might be able to add a further 10 km or so!
HMS Ark Royal
2 Sep 2015
Hull
What about Bull & Bush (originally to be named North End) - if we count unfinished stations
