krus_aragon
In this scenario, I'm looking at what possible service improvements could be made to rail services down the Conwy Valley to Blaenau Ffestiniog, once TfW take delivery of all their new rolling stock. For the benefit of any readers that aren't very familiar with the route, here's a quick summary:
Under the current public timetable, the quickest service from LLJ to Blaenau and back (with request stops) operates in two hours and two minutes (1633-1835). If this could be tightened up to below two hours, it would be possible to operate a two-hourly service between LLJ and Blaenau with the same resources, but at the cost of losing the through operation to Llandudno Town.
When the new Civity DMUs are all introduced into service, they will be used on the Conwy Valley as well as mainline services. This hasn't been the case before (with a mix of 158 and 175s on the mainline).
In the current timetable, Manchester-Llandudno services have a long layover at Llandudno, during which they shuttle to LLJ and back. This service will be replaced with a Liverpool-Llandudno service once the new DMUs arrive, but I expect there will still be a similar layover at the Llandudno end.
So here's the big idea: There will be an hourly shuttle from LLJ to Town, courtesy of the Liverpool (nee Manchester) terminators. This will be operated with the same Civity rolling stock as the Conwy Valley. So if the round trip LLJ-BFF-LLJ could be reduced to less than two hours, it could be interworked with the Liverpool-Llandudno services to give a service every two hours between Blaenau Ffestiniog and Llandudno Town, rather than every three.
The Llandudno shuttle would continue working to LLJ and back in the intervening hours. There'd be a net loss of roughly three services each way between Town and LLJ, a relatively small price compared to two extra services to Blaenau and back.
Token exchange at LLJ could be a bit of a problem. At the moment, trains from Blaenau are usually routed to platform 4 at LLJ (over the bridge), as this route doesn't conflict with any services from the Chester direction (heading for platform 3). But as the token would need to be passed on to another unit immediately, it would probably be more advantageous to diagram it for platform 3 instead, with the southbound unit sat nearby on platform 1. (This would still need more time to be clawed back than if the same unit were to shuttle back down with the token.) There'd also be the risk of a late-running northbound service delaying a southbound service, which could take a long time to recover from.
Any observations on this idea, or alternative suggestions, would be very welcome.
- Single track from Llandudno Junction (LLJ) to Blaenau Ffestiniog, with a passing loop at North Llanrwst. Tokens are exchanged at North Llanrwst and LLJ.
- Three-hourly service, currently operated by a single Class 150 unit
- Most stations on the line are request stops
- End-to-end journeys are currently timetabled for roughly 1 hour. North Llanrwst is 20 minutes south of LLJ.
- Every service (except the first few of the day) runs through to/from Llandudno Town, with a ~10 minute layover at LLJ each way for connections with the mainline.
