Stephen Lee
- Joined
- 7 Jul 2019
- Messages
- 675
i wondered if the trains mentioned will upgrade into Railjet Trains after the opening of Brenner Base Tunnel.......
Just to add to what has been mentioned above, the main driver for new stock is the change in rail fire safety standards in Italy - this has been a long running topic which if I recall currently Austrian stock has an exemption for by exception. It runs out in 2022 and therefore there is no option but to order new stock for the Brenner services.
The original (German) press release from 2018 when the framework agreement was agreed with Siemens is here https://press.siemens.com/global/de...iessen-rahmenvertrag-ueber-reisezugwagen-fuer . The 8, 9 carriage trains that form part of the initial contract entered into (rather than the broader framework for upto 700 carriages) are for the Brenner. It also makes clear existing Taurus locos will be used - that makes sense given a sub group of 1216s are passed for Italian running.
In terms of route - I am not sure much will change being frank unless they plan to stop serving Brenner (which using the tunnel would mean).
Is RailJet stock exempt from the fire regulations?
RJs work the Vienna-Villach-Venice trains via the Pontebba tunnels.
An RJ also works a Bolzano-Innsbruck-Vienna service via the Brenner tunnels.
Most of the original route was built by the Austrians, of course, although the modern tunnels are Italian.
