quantinghome
- Joined
- 1 Jun 2013
- Messages
- 2,265
Wouldn't the 332s be useful for Northwest to Man Airport services? There'd be no need for a major refurbish as they are already set up for airport luggage requirements.
Really? Have you read this thread and what the issues are with redeploying 332s?Wouldn't the 332s be useful for Northwest to Man Airport services? There'd be no need for a major refurbish as they are already set up for airport luggage requirements.
Trouble is development costs. For a small dedicated fleet these could not be recouped, the economies of scale in the sale of a large fleet won't apply so the unit cost of a micro fleet might be so high to prevent it being viable. So the thought of upcycling a small fleet of units like the 332 may come into play. Sounds like the 230 D-train sales pitch!
It does doesn't it, I think they have a stronger case than the D-train.
Want me to put you in touch with Mr Shooter then?...
Northern are generally fine in regards to EMUs. It's the DMUs that are the problem - specifically how to ensure enough new units so the Pacers can (finally) be consigned to the dustbin.Wouldn't the 332s be useful for Northwest to Man Airport services? There'd be no need for a major refurbish as they are already set up for airport luggage requirements.
i suppose what we are leading up to is, how best can the small fleet of 332s be recycled, is it feasible to fit them with batteries, along with the other things needed (AWS/TPWS etc)?
A cab shot up-thread suggests the 332s already have AWS. It's possible their unusual history resulted in them never getting TPWS because of their limited operating range and the presence of the GW ATP on all lines traversed, but TPWS retrofit is actually fairly easy as it uses the same traction and braking interfaces as AWS while being otherwise largely self contained. That's why it was such a compelling retrofit to the general network and fleet in the first place when the industry had to 'do something' about train protection. The 333s must have received TPWS so would represent a design template for that on the 332s. Conversion of either train to ETCS would be a much taller order I'm sure and probably not worth if for a small fleet of what is now a comparatively old train. That's possibly the primary reason to get the 332s out of Heathrow which will allow the pilot ATP system to be finally decommissioned in the airport tunnels and on the GWML. With their similarity to 333s I would have thought a very good fleet strengthening case could be made for the Leeds electric network and they could be maintained at Neville Hill.
1 - almost certainly yes. I don't think your other suggestions are serious, and why would they hang onto something that they have no use for and costs them a fair bit to keep?1-Do Heathrow Airport want to sell them.
2-Would a ROSCO want to buy them.
3-Would a TOC want to lease them.
All unanswered questions. Whos to say that HAL wont stack them in a big pile and replace the A380 model on the approach. Or even convert them into new jetways. Just because they are similar to other units on the network doesnt immediatly mean that they are going to be reused. If and when HAL decide to sell, if the scrap man offers the best price, then that is where they will go.
You probably already know this, but the primary reason for getting the 332s out of Heathrow is not directly to do with the signalling but that the site of their maintenance depot at Old Oak Common is required for the construction of HS2. The site has to be cleared by December 2019 to permit HS2 to keep to its schedule.A cab shot up-thread suggests the 332s already have AWS. It's possible their unusual history resulted in them never getting TPWS because of their limited operating range and the presence of the GW ATP on all lines traversed, but TPWS retrofit is actually fairly easy as it uses the same traction and braking interfaces as AWS while being otherwise largely self contained. That's why it was such a compelling retrofit to the general network and fleet in the first place when the industry had to 'do something' about train protection. The 333s must have received TPWS so would represent a design template for that on the 332s. Conversion of either train to ETCS would be a much taller order I'm sure and probably not worth if for a small fleet of what is now a comparatively old train. That's possibly the primary reason to get the 332s out of Heathrow which will allow the pilot ATP system to be finally decommissioned in the airport tunnels and on the GWML. With their similarity to 333s I would have thought a very good fleet strengthening case could be made for the Leeds electric network and they could be maintained at Neville Hill.
the DfT decided that this would be wasted money for only 5 years and therefore engineered the scheme to replace the 332s by re-fitted 387s.
There isn't really anywhere in West Yorkshire they'd fit. The current fleet is 16x 333s, 3x 321s & 5x 322s, which operate on just a handful of routes. The 321/322s are due to be replaced by a number of 3-car 331s which will largely work in pairs. There are no new electric routes due to start up in the next few years and no need for extra 4 and 5-car units.I suppose GWR could plausibly accommodate the 332s at Reading but there would have been a cost in dedicated facilities, maybe not as much as a standalone depot at Langley, but a considerable expense nonetheless, and at least some of the 387s would have been idle as a result possibly. As to a Leeds transfer I suppose it would only stack up as a ROSCO proposal to homogenise a fleet in exchange for transferring some other class elsewhere to achieve a similar aim. I'm not entirely familiar with the broader emu fleet in the west/south Yorkshire local area, so I can't be sure this is plausible.
Since GW-ATP is being replaced, wouldn't the Class 332s have had to be refitted anyway [with ETCS] in order to continue operating.
I think it was fortuitous that electrification to Oxford was deferred, leading to GWR having some spare units and depot capacity.So you are saying that electrification to Oxford was postponed because of HS2‽
What sort of timescales were being mooted for that though? Crossrail are/were going to the expense of developing the ETCS overlay for the Heathrow branch so presumably the expectation prior to this was that GW-ATP was going to be around for a while.
The number of EMUs had already been reduced since the original 37 x 387 and 21 x 365 plans down to 45 x 387, and the number of bi-mode 802s increased. It is quite possible that the orders for the trains to cope with the eventual Oxford wiring already exist, and they will already have a depot plan.But I guess this means more units and depot enhancement if and when electrification to Oxford goes ahead, unless Heathrow Express has become something else (through running to Heathrow Southern with depot elsewhere?) by then.
Whilst we both know that this suggestion is highly unlikely to happen IRL, it's not a bad suggestion in theory because:It would make more sense to take some of the 332 trailers and stick in the 333s to make a 5 car 333. This would give more seats (assuming the new trailer re-seated like the other 333s) than two 3 car 331s working in pairs. Also the guard would have access through the train. Cheaper to run, cheaper to maintain, less platform space needed.
Subject to platform lengths in Yorkshire you could extend all 333s to 5-car as there are 9 332s with one intermediate trailer and 5 sets with 2 trailers - so 19 trailers for 16 sets. Add in the 331 plan and that would mean all the Leeds/Bradford/Skipton/Ilkley service would get lengthened trains.Whilst we both know that this suggestion is highly unlikely to happen IRL, it's not a bad suggestion in theory because:
In reality, scrapping is most likely.
- It avoids the TPWS issue by not using any 332 cabs (Counter-point: another solution to withdrawal of 321/322s required as a result).
- It has been suggested that the 332s haven't aged well. This idea would maybe allow the vehicles/components in the worst condition to be rejected while still making use of the better examples.
What's supposed to be working Manchester-Airport-Blackpool once wired? Could 332's suffice to free-up more DMU's?
I think there might just be a plan for 20 May
319s and 323s for the time being, followed by 319s and 331s.
if there's 380s available during snow then what are they doing when there's no snow? No point running anything else!1. Install TPWS
2. Build the Glasgow Airport Rail Link
3. Deploy 332's on it.
4. Store at Shields Depot.
There. A good use for the Class 332. Issues and how to avert:
No TPWS: Add TPWS
Doesn't like snow: Put 380's on during snow, nobody would mind as most flights would be cancelled!
Interior: It's on airport runs, who cares?
The plan is for some lengthening to 6-car platforms on the Airedale line, but not all AFAIK. Though if all units were longer that would introduce extra costs to extend platforms at minor stations on the Leeds to Doncaster line which is currently planned to be served by 333s (12m longer than the current 321/322s, though they've run to Donny occasionally in the past so I assume platforms already take a 4-car 23m unit). Either that or Donny gets downgraded to single 331 operation, which would be fun in the peaks!Subject to platform lengths in Yorkshire you could extend all 333s to 5-car as there are 9 332s with one intermediate trailer and 5 sets with 2 trailers - so 19 trailers for 16 sets. Add in the 331 plan and that would mean all the Leeds/Bradford/Skipton/Ilkley service would get lengthened trains.
They're not Desiros... they pre-date the Desiro concept by a good few years and aren't even a Siemens design: they're a CAF design with Siemens providing the running gear I believe.Hello all
Just thought I'd like to add to this, as I am internal with Siemens and can provide a bit of info.
As far as I am aware, there is no future plans for these units. There is a number of issues with them at present with bodywork & bogies, and they are also non standard type Desiros. They do not have TPWS either which would have to be retrofitted, but it is unlikely this will happen.
Heathrow own the units and would have to be sold by themselves to another party to be in with a chance of surviving. They will probably be put into storage as a result.
Cheers
