[gensheet] This Weekends Engineers 30/31
Simming
8 Jun 2005
Cornwall
For 30 and 31 July collected from the usual sources
The main items of interest are:
Work near Glasgow causing use of two curves
Manchester Victoria - Stockport service
GW diversions via Melksham
Bill
SAT SUN Liverpool St - Cambridge lines all trains run via Seven Sisters. No
service via Tottenham Hale
Chingford branch bus from Liverpool St.
1930 SAT - 1100 SUN Doncaster - York blocked.
GNER divert to Leeds with HST diagrammed connections north
Hull divert via Goole
SAT SUN Rotherham area
SAT Meadowhall - Moorthorpe bus. VXC via Barnsley (not noted though)
SUN trains divert via Masborough.
SAT SUN Leicester - Nottingham no through local trains, use MML.
Leicester - Loughborough local bus
Peterborough - Nottingham trains via Syston are diveted via Grantham
SUN Nottingham - Sheffield diverted via Derby. As timetable..
SAT SUN Rugby - Coventry - Birmingham blocked, local buses. Coventry -
Nuneaton
bus
VWC diverted via Nuneaton, diesel drag and use of Nuneaton Abbey Jn
VXC diverted via Solihull. As timetable.
SAT SUN Manchester - Stockport / Airport blocked
London - Macclesfield trains. extended to Stockport
Crewe - Stockport local service by trains not buses
VXC south - Manchester - north diverted via Warrington.
Sheffield - Manchester diverted to route of slow services
Buxton - Hazel Grove extended & diverted Stockport - Manchester Victoria via
Denton
1200 SAT - SUN Crewe - Liverpool bus
VWC diverted via Warrington with diesel drag, as new timetable.
SUN Manchester - Preston not via Chorley. Divert via Wigan (connections),
Lostock - Chorley bus.
ONGOING A Tesco on the line at Gerrards Cross. Denham - Beaconsfield bus
Trains run to special service:
Marylebone - Aylesbury - Princes Risborough - Birmingham
Marylebone - Denham
Beaconsfield - Princes Risborough - Birmingham.
SAT extra Marylebone - Harrow on the Hill and Harrow on the Hill calls by
Birmingham services.
SAT SUN extra trains (not buses) to/from Stratford on Avon
2200 SAT - SUN Reading - Bedwyn bus
GW diverted via Swindon - Melksham. Pewsey - Swindon bus
2200 SAT - SUN Cardiff - Bridgend via Vale of Glamorgan
ONGOING Folkestone - Dover bus. Additional (weekdays) Dover - Minster using
Minster curve, see timetables
to SUN Forth Bridge shut
Edinburgh - north diverted via Stirling
Dalmeny - Inverkeithing bus. # Inverkeithing from P1
SUN All south side lines for Kilmarnock / Neilston / Newton affected
Unspecified but likely as reported for previous weeks with block Eglinton
St -
Pollockshields East:
Kilmarnock / East Kilbride trains run via Polmadie
Cathcart/Newton line trains run via Shields Jn
~~~~~~~~~~~~~ Buses & Crossovers ~~~~~~~~~~~~~~
SUN Barking - Rainham - Grays bus
ONGOING to SUN Sudbury branch bus
SUN Hertford loop bus
SUN T33 trains are bus Sheffield - York
1500 SAT - SUN Pontefract Monkhill - Knottingley - Goole bus
SAT SUN Euston - Watford DC lines bus, also LUL Queens park - Harrrow.
2000 SAT - SUN Clapham - Watford terminate Kensington. #.
SUN Watford - St Albans bus
SAT - SUN Wolverhampton - Walsall bus
SUN to 2145 Stourbridge Junction - Worcester bus.
SUN from 2145 Birmingham - Worcester bus.
Trains run Malvern - Droitwich
SUN Altrincham - Northwich bus
2130 SAT - SUN Reading - Paddington reduced services with 2 line working on
Main Paddington - Southall and Slough - Maidenhead. Burnham bus
2130 SAT - 0900 SUN all trains on DM Maidenhead - Slough. #.
SUN Gloucester - Chepstow bus
SUN to 1100 Hereford - Shrewsbury - Crewe bus
SUN Surbiton - Weybridge all down trains on fast lines. Bus for local
stations. #
SAT SUN Epsom - Dorking / Effingham Jn bus
SUN Victoria - Peckham Rye - London Bridge bus
LUL Normal services, except:
Hammersmith - Paddington (# Royal Oak), rest of Hammersmith and Circle do
not run.
Met - Moorgate (# Moorgate) or Barking in peak
Piccadilly runs Heathrow - Hyde Park Corner, Rayners Lane - Acton and Arnos
Grove - Cockfosters.
FRI - MON Hammersmith - Whitechapel bus
SAT SUN Baker St / West Hampstead - Wembley Park bus.
Extra Chiltern trains calling Harrow on the Hill. #
ONGOING Heathrow T4 loop closed. Bus from Hatton Cross. # T123
