[gensheet] Weekend works
Simming
8 Jun 2005
Cornwall
For 22nd and 23rd October. Main items are Thornton N, Laverstock and
Primrose Hill.
Bill
SAT SUN Liverpool St - Broxbourne all trains via Tottenham Hale. London -
Enfield Town bus
SAT SUN Finsbury Park - Welwyn - Stevenage bus. Reduced trains diverted via
Hertford. Watton-at-Stone bus due to line capacity. # Royston
SUN Stevenage - Royston bus. # Royston. ROTR lists both fast lines closed,
so GNER on slow lines
SUN Doncaster - Hull divert via Selby. Doncaster - Cleethorpes bus.
SAT SUN Derby - Matlock bus Derby - Sheffield diverted via Toton (VXC only)
MML to Sheffield are the Nottingham trains. Those via Derby terminate
Derby.
Not as current timetable.
SUN Birmingham - Derby diverted via Leicester as timetabled, buses Tamworth
& Burton.
SUN Acton Central - Gospel Oak - Camden Road bus
Willesden LL bay - North Woolwich trains via Primrose Hill
DC lines run Euston - Queens Park only. LUL or diverted trains forward to
Harrow and then Harrow - Watford bus.
AC line trains call additionally Wembley when running.
SAT SUN Rugby - Stafford blocked trains via West Midlands.
North services combined with Birmingham so less 'full' diversions using
Aston - Stechford - Bescot - Wednesfield - Bushbury.
SAT xx17 and xx53 ex Euston for example look good though. As timetable.
SAT Crewe - Stockport bus.
All trains from south via Stoke, ATW run Crewe - Warrington - Manchester
Oxford Rd
SUN Leeds - Liverpool diverted Huddersfield - Elland - Manchester Victoria -
Newton-le-Willows - Liverpool, as timetable.
Huddersfield - Marsden - Manchester bus
SUN Crewe - Liverpool VWC diverted via Manchester, local bus. As timetabled
SAT Preston - Carlisle bus, SUN Crewe - Preston - Carlisle bus.
A few VXC divert via Settle using Clitheroe - Hellifield and SUN Preston -
south via Manchester with drags for 390's
(Note Lostock - Chorley bus, so via Wigan NW # )
Buses also St Helens / Morecambe / Carnforth / Windermere.
SAT SUN Bolton - Preston diverted via Wigan, # Wigan. Buses Preston -
Lostock - Chorley
SAT SUN Bromsgrove - Droitwich / Worcester Abbey Wks Jn / Gloucester block.
Selly Oak - Redditch bus
SAT Birmingham - Worcester and VXC diverted via Kidderminster
SUN Birmingham - Gloucester / Newport bus. Gloucester - Cheltenham bus
ONGOING TO WED (est) Worcester - Cheltenham - Gloucester bus. VXC run
through but slowly (SLW and # ?) and only hourly following derailment
SAT SUN Bath - Bristol blocked
1 per hour Padd - Bristol diverted via Badminton.
SAT additional hourly Paddington - Bath, SUN Swindon - Bath rail shuttle.
Westbury - Bristol / Swindon bus.
2300 SAT - SUN Cardiff - Bridgend via Vale of Glamorgan. Bus Bridgend -
Swansea
London services terminate Cardiff
SUN London Waterloo - Clapham, Windsor lines blocked, trains start Clapham
Junction
No mention of diversion of Reading services (odd, would expect this)
Chessington branch run from Wimbledon only, #.
SUN to 1025 Block at Weybridge
Portsmouth line diverted from Surbiton to Guildford (including Weymouth
trains)
Surbiton - Woking bus. Virginia Water - Weybridge divert to Ascot.
SAT SUN Winchester - Eastleigh SLW.
London - Weymouth divert via Guildford
VXC run 1 per 2 hours via Laverstock curve Salisbury
1 train per hour through but no sign which lines and # as ROTR lists a full
block
Note for SE: teletext lists a number of last weeks' works but they are not
listed on SE website (Orpington - Sevenoaks, New Cross - Lewisham -
Dartford). I assume teletext is wrong.
SAT SUN Charing Cross - London Bridge blocked. All SE trains run from
Cannon St (LUL open). Reduced services with Swanley - Ashford shuttle, #
Swanley.
Caterham / Tattenham run from SC side of London Bridge.
SUN Barnham area blocked. Trains terminate at /divert to Chichester and
Littlehampton.
SAT SUN Carlisle - Edinburgh / Glasgow and Motherwell - Lanark bus
VXC through trains divert Kilmarnock
SUN Inverkeithing - Kirkcaldy blocked, local buses. Trains all via
Dunfermline. Use of Thornton North.
~~~~~~~~~~~~~ Buses & Crossovers ~~~~~~~~~~~~~~
SUN Barking - Rainham - Grays bus
SUN Pitsea - Leigh on Sea bus. # Leigh likely.
SAT SUN Thetford - Norwich bus
SAT SUN Bishops Stortford / Stansted - Cambridge bus. London - Stansted
runs normally
SAT SUN Lincoln - Gainsborough bus
SUN Newark - Lincoln bus
SUN Redcar - Saltburn bus
SUN Chesterfield bus, trains on slow lines, #.
SUN to 1200 Euston - Leighton Buzzard bus, VWC bus London - Milton Keynes.
2000 SAT - SUN no service Watford - Kensington.
SUN Machynelleth - Aberystwyth bus
SUN Manchester - Earlestown - Warrington - Chester bus
SAT SUN Manchester - Guide Bridge / Rose Hill Marple bus
SUN Manchester Vic - Stalybridge bus
SUN Hamilton Square - Rock Ferry bus
SUN Hunts Cross - Garston bus. # Garston
SUN Sandhills - Freshfield bus #?
SUN Maidenhaed - Reading 2 line operating, services all on relief lines.
0001 SUN - 0800 SUN SLW on up relief
SUN Plymouth - St Austell bus
SUN Truro - Falmouth bus
SUN Oxted - East Grinstead / Uckfield bus. # Oxted
SUN Redhill avoiding line (fast, quarry) blocked.
All trains via Redhill, reduced Gatwicks
SUN Lewes - Eastbourne bus
SUN work cancelled Victoria - Shortlands via Penge and Tunbridge Wells -
Hastings. Trains run, but from Blackfriars and Cannon St respectively due to
other work
SAT SUN Ashford - Rye bus
SAT SUN Ashford - Canterbury - Ramsgate bus
SAT SUN Dartford - Strood bus. Strood - Gillingham train
SAT SUN Hyde Park Corner / Earls Court - Acton Town / Richmond bus
Travelcards valid on HEx and HEC from Paddington to Heathrow
ONGOING Heathrow T4 loop closed. Bus from Hatton Cross. # T123
