German Kleinbahn System - Werl Area
CarltonA
22 Apr 2012
Gerrards Cross
I resided in the Werl area in the 1980s and was intrigued by a street near Werl station called "An Kleinbahn". Embedded in the road near the level crossing were three rails long disused. It looked like dual standard and narrow gauge. I can find nothing in English but I found the following link which my German is too poor to make much sense of. Was this disused track in the road part of a system mentioned in the internet article?
If you look in the section RLK - was ist geblieben (what survives), which is marked as "under construction," there are photos of mixed-gauge track, so I reckon you are almost certainly right.
There is also a section on the system in "Railway Holiday in Northern Germany" (WJK Davies/D&C, 1965ish) but it doesn't cover Werl.
I suggest contacting the EF Werl - in English will be fine.
Gloster
4 Sep 2020
Up the creek
If you can read German, then there is an entry on the German Wikipedia on the AG-Ruhr-Lippe Kleinbahn. It looks as though the bit at Werl was metre gauge.
CarltonA
22 Apr 2012
Gerrards Cross
Thanks 30907 that "was ist geblieben" page shows a photo "Ein Stück 3 Schienengleis auf einem Fabrikgelände in Werl". That is probably what I saw in about 1983. I'm guessing there was a connection with the main line there for some purpose.
Calthrop
6 Dec 2015
Davies's book, which I have -- published indeed in 1965 -- tells of a tour which he made, I think, the previous year. By inference from the several pages in the book, about the Ruhr-Lippe-Kleinbahn; plus material from the item linked-to by the OP: as at 1964, the only parts of the system then remaining in use were two standard-gauge sections, freight-only, respectively at its northern and southern extremities -- on the more northerly and longer of which (some 20km. running due east from Hamm), Davies travelled by special permission on a freight. The linked-to item tells of end of passenger service on the route through Werl in 1952 (together with that on most of the system): complete closure east of Werl in 1953, and north-west of Werl in 1962.
The linked-to item claims that as at 1936, with system at maximum extent: [approximately-rounded figures] of a total of 100 km., 25 km. were standard gauge, 20 km. three-rail, and 55 km. metre-gauge only. (For what it's worth, Davies gives different figures: one would be inclined, I feel, to give greater credence to the directly-German source.) Neither source gives a fully detailed breakdown of what was the gauge status re the entire system: it can be ascertained, though, that there were standard-gauge / mixed parts at system's southern end, quite close to Werl; I feel that it could be hypothesised that there might have been mixed gauge into Werl from the south and east?
Gloster
4 Sep 2020
Up the creek
A quick skim of the German Wikipedia page, which is a bit difficult as there is no geographic map, suggests that although most traffic had ceased by the early 1960s a small standard-gauge section in Werl remained open for goods traffic until 1 August 1975. This connected with DB’s Dortmund-Soest line, but whether this was operated by the RLE or by DB is not clear.
alex17595
15 Mar 2013
Burton on Trent
The Schweers and Wall rail atlas has an entry for it which translates (using google) to:
Ruhr-Lippe-eisenbahn (today RLG) gauge 1000 mm, from 1907 three-track or gauge change to 1435mm.
Seems they had a bit of a network:
Hamm-Ostonnen 23.3Km
Soest - Neheim 25.4km
Niederense - Mohnesee 5.7km
Hamm - Oestinghausen 24.9Km
Soest - Hovestadt 11.2km
Only Hamm to Lippborg-Heintrop remains in use, partly for freight and partly a tourist line.
30907
There are several photos and an early track plan on the site the OP linked under "Bahnhöfe/nördliche Bahnhöfe."
Between Werl and W-Steinertor (on the east side of the town) there was mixed gauge to serve a yeast factory; this stayed open after the n/g closed until the mid 60s. One photo shows a conventional German station shunter (Kleinlok) but another refers to s/g wagons being shunted by n/g steam locos.
