Gillingham Dorset (or Dorchester West or Salisbury) to Camborne
Dunderhead
6 Mar 2012
Bournemouth
Hi there, wondering if I can do any better than the standard £63.60? Out on Sept 9th AM and returning Sept 12th PM if that makes any difference. I have a Network Railcard. I put the latter two stations in brackets as I'm assuming they would be more expensive.
Much gratitude for any advice offered.
crehld
1 Nov 2014
Norfolk
FOSW 3in7 if you have a railcard is 53.90
I'm guessing the OP doesn't have a railcard given they're quoting 63.60 as the cheapest fare they've found so far, which is a non-railcard fare. Perhaps the OP could clarify?
Dunderhead
6 Mar 2012
Bournemouth
Thank you, but unfortunately, I only have a Network Railcard, which I believe would only help me with an off-peak ticket from Gillingham as far as Exeter. :(
kieron
22 Mar 2012
Connah's Quay
If you're happy to wait until 10am to leave, splitting at Exeter would reduce the cost to £58.40 (Gillingham-Exeter £19.20, Exeter-Cranbourne £39.20). Advance tickets could reduce this further, although not from Gillingham as SWT doesn't seem to provide them.
SickyNicky
Verified Rep - FastJP
8 Sep 2010
Ledbury
Or Totnes for £53.90:
Code:
GILLINGHAM DSET to TOTNES
Off-Peak Return	£24.50
Route: ANY PERMITTED
Restriction WG applies
TOTNES to CAMBORNE
Off-Peak Return	£29.40
Restriction code WG allows travel any time after 08.33. No railcard being used at all.
If you're happy to use advances, try splitting at Exeter, as kieron suggests.
Dunderhead
6 Mar 2012
Bournemouth
Thank you all for your responses. Since my original post I have discovered the TrainSplit website (is that your creation, SickyNicky?) and I've used it to find a split for the two journeys I like best...
Outbound: 10:17 - 14:45 (4 Hours, 28 Minutes)
From Gillingham (Dorset) To Camborne
Changing At Exeter St Davids
Return: 16:21 - 20:50 (4 Hours, 29 Minutes)
From Camborne To Gillingham (Dorset)
GILLINGHAM (DORSET) to NEWTON ABBOT
OFF-PEAK R Return £24.50
(outbound: VALID AS ADVERTISED )
(return: VALID AS ADVERTISED )
Route: Valid via any permitted route.
Restriction code WG - please read this important ticket information
NEWTON ABBOT to PLYMOUTH
OFF-PEAK R Return £12.10
PLYMOUTH to CAMBORNE
OFF-PEAK R Return £19.20
Total Fare £55.80
If I had picked two journeys that both called at Totnes then I could have got it down by another couple of quid (as someone said above), and it looks like I could knock a further tenner off by switching onto an advance fare at Newton Abbot, but I've decided that I don't want to tempt fate with this particular trip!
Thanks again for all the suggestions (what a shame I don't have a railcard for the FOSW), and since I won't be purchasing until September now I'll remain open to hearing anything better that anyone finds before then!
SickyNicky
8 Sep 2010
Ledbury
Yep. Glad you like it. It's not perfect yet, but we're hard at work (right now, in fact) in improving it.
Dunderhead
6 Mar 2012
Bournemouth
Yes, it seems like quite a remarkable feat of engineering that you've managed to do this. Thank you for your efforts, I'm sure this won't be the last time that they save me money!
Dunderhead
6 Mar 2012
Bournemouth
I was definitely surprised at how inexpensive the FOSWs are for what they offer, but as the CDRs from Camborne to local destinations like Penzance, Falmouth and Truro are all around the £5 mark, I don't think I would break even with an FOSW on this trip. Definitely something for me to think about on future excursions, though.
