Same as a Glasgow-London ticket as far as London if you go that way, plus all the usual London-Portsmouth permitted routes (via Farnborough North, Basingstoke and Botley; via Guildford and most of the suburban SWR routes; via Horsham and Three Bridges; via Brighton, optionally Lewes, and Three Bridges; via Reading and Botley).Anyone know what are the permitted routes for this ticket?
Your proposed outward route is fine.Was looking at Glasgow to Kings X , then from Waterloo to Portsmouth via Guildford.
On the return go from Southampton via Basingstoke to London. Can I still stop in Manchester on my return?
Is it possible to overnight in London on way back to Glasgow?
For the return route you'd need to have the ticket issued to Southampton, or a separate ticket to cover you between Southampton and Eastleigh or whichever other station your train to London first called at after Eastleigh.
Portsmouth to London is slightly cheaper than Southampton to London so it isn't valid via Southampton. Soton, being more expensive, is valid via all the Pompey-London routes plus Soton-Eastleigh etc.
You can stop off as many times as you like, at any station along a permitted route, on the return portion of tickets with a 3A restriction code (such as Glasgow-Portsmouth Off-Peak Returns).
London and Manchester are both on permitted routes between Glasgow and Southampton/Portsmouth so you can stop off in either and/or both of those places.
Restriction 3A restricts your arrival into London on the outward portion, and out of London on the return portion. If arriving into King's Cross you should refer to restriction 1K, which bars arrival before 11:17.Thanks for your help.
Is there a off peak restriction for weekday mornings towards London?
And is it possible for overnight on way back to Glasgow in either Manchester or London?
You can break your journey, including overnight stays, as often as you like and for as long as you like on the return portion, during the calendar month that it is valid. So you can stay overnight in Manchester and/or London for one or more nights.
That should be no problem at all (especially since the first "Off-Peak" Euston-bound service out of Glasgow departs at 05:40 currently).The 0648 Glasgow to London Kings X arrives after 12.
I was looking at setting off from the South Coast early morning up to London.
Your arrival into London is unrestricted on the return portion, i.e. from Portsmouth/Southampton to London.
That'd be the 09:20 off Euston then. You may have difficulties inasmuch as that's the last Anytime ticket if holding a London-Manchester Off-Peak ticket. I'd advise getting a reservation for that service when booking your ticket which you can present on top of your ticket.Yes , on return i hope to get the first off peak Manchester bound service.
Should be no trouble there.More likely to be the 10am Euston to Manchester service im catching.
No, you can't go southwest of Birmingham on a Glasgow-Portsmouth ticket.Quick question on routing. Is Glasgow - WCML - Birmingham - Bristol - Westbury - Romsey - Eastleigh - Portsmouth valid?
