robertclark125
For the past 18 months, I've been building a layout in a 6x4 shed, called "Glasgow City". The layout has videos on youtube. But, one continuing issue is the fact that when I built it, I used a lot of track that was about 25 - 30 years old, and hadn't been used for about 15 years. The same could be said for the rolling stock as well.
Recent issues, only noticed after ballasting, have seen me discover a gap in the joins, preventing power to two tracks going to some platforms. In addition, all the locos are analogue, and thus I'm using several power controllers.
Given the fact the baseboards are MDF and weren't sealed before use, and also given the fact the track is old, and perhaps ballasted before it should've been, I've decided to take the plunge, and dismantle the layout, and build a new one, Napier City. But, this time, my plan is to buy new track, and also, importantly, use DCC.
I'm planning to use the same track layout as before, but with a couple of changes. Firstly, instead of a cutting, I'm going to have the track leaving the scene to drop down a level and onto another board, which I can then use to access and change the ends or change the trains. The current plan, of using a cutting, doesn't work at all, as I'm going to be stretching over the layout. The other change would be, if I did that, I could then replace the cutting with a tunnel as a town scene, and it could be a shorter piece of embankment, allowing two sidings in the depot to be longer.
If you go onto youtube, and key in "Glasgow City Station", you'll get the idea of the current track arrangement. I'm also thinking of doing away with the freight yard, and solely having passenger and parcels trains.
So, I need advice on DCC. As it's a small layout, I'm planning on using the cheaper Hornby controller, and not the Elite. Do I need only one power connecting clip? I know I'd need to put clips in the points to make them "live", but for power to the layout, is one clip enough?
I recently bought a new Railroad class 08, 08673, and was wondering, if that or some of my Lima class 37s and 47s could be fitted with DCC decoders?
As regards the baseboards, I'm going to switch from MDF to Plywood, with it being sealed beforehand. I've been recommended to use a 12mm thickness (The mdf is 9) minimum, but also to seal it with a weathershield paint.
Returning to DCC, can I still operate the points manually on my new layout, using my fingers, even though the locos are DCC as is the controller?
Many thanks for your help folks.
