Grand Union Trains Plans to run from London to Cardiff - Now rejected by ORR
John Newbury
10 Jun 2019
Looks like the original open access request has been withdrawn and a new application extended to Llanelli has been made in its place.
https://orr.gov.uk/__data/assets/pd...ibrium-test-grand-union-trains-2019-07-10.pdf
Initially a service every 2 hours between Cardiff Central –Newport– Severn Tunnel Junction – Bristol Parkway - London Paddington.
Service then increased to hourly and extended from Cardiff to Bridgend–Port Talbot Parkway –Neath– Swansea– Gowerto nand Llanelli.
Further extension to Carmarthen under consideration pending further diagram work.
Darandio
24 Feb 2007
I'm pretty certain that Yeowart simply throws darts at a map for locations, then spins a wheel that has a load of rolling stock written on it.
Cambrian359
17 Jun 2018
Straight in for the kill with 9 car formations! giving all customers a seat for years to come will prove a big hit with passengers no doubt!
800002
19 Jun 2019
Who's going to pay for the route clearance / gauging work?
Last time I checked it's only the Mark 3's (without mods) that are cleared thatway.
Let alone the cl.91 and DVT's...
Thay may be 'compatable' but it'll cost someone to sort it.
Glenn1969
22 Jan 2019
Halifax, Yorks
Also possible extension west of Llanelli to Carmarthen "pending further diagram work" . Is an hourly service to London from West Wales really a viable prospect?
It will cost them to sort it, simple as.
800002
19 Jun 2019
So has the proposed rolling stock changed now from 91s + Mk 4s to 802s?
From the application:
Please set out indicative information about the intended rolling stock.
Initial service: Class 91 locomotives, up to 9 coaches and 1 DVT in each train set Extended service: Class 802 in 9 car formation
Cardiff123
10 Mar 2013
We're forgetting that Grand Union's plans for 91s + Mk 4s are very much dependent on whether NR can find a permanent solution for getting electricity through the Severn Tunnel
cactustwirly
10 Apr 2013
Isn't the Severn Tunnel already wired?
cactustwirly
10 Apr 2013
More likely to be a paper exercise, as the GWML was built for a more generous loading gauge than other lines. Although that is dependent on the 91s being compatible with the electrical supply
800002
19 Jun 2019
When is Swansea - Carmathen getting wired?
cactustwirly
10 Apr 2013
I was thinking, as planned intro in May 2021, that eighteen months would be long enough to make the mods required. Given that 2020 is the red line for the overhauls to be completed for current stock - wouldn't that open up sufficient space for the additional stock?
It ain't, that's why they're using 802s for that bit, shouldn't be an issue as the very similar 800s are cleared all the way to Pembroke
Tomos y Tanc
1 Jul 2019
There may be some poltical support for this given that the UK and Welsh Governments are in talks with Network Rail about developing a Parkway station on the Swansea district line. It would make sense for the open access operator to offer services via the new station with GWR serving the current city centre station.
krus_aragon
10 Jun 2009
North Wales
The current application mentions serving Neath and Swansea when the service is extended, though. They'd have to sacrifice the passenger traffic from those stations in order to go via the District Line instead.
Cardiff123
10 Mar 2013
Nope, we're not. The tunnel has been wired (well, conductor-railed) for some time now.
And as has been already stated, that's not working due to the harsh, damp, salty conditions in the tunnel.
BBC News - Trains to London: Severn Tunnel electrification problems
https://www.bbc.co.uk/news/uk-wales-48621944
Earth straps - a safety feature on the overhead connectors holding up the power line - were corroding in the salt water environment within months when they are supposed to have a 25-year lifespan, meaning the line through the tunnel could not be electrified safely.
It means the electrification system within the brickwork tunnel - the longest underwater tunnel in the world for more than 100 years after it opened in 1886 - struggles to maintain voltage and regularly trips.
Network Rail contracted experts from Swiss company Furrer and Frey, specialists in developing power cables inside tunnels, to design a solution but none have so far worked in the salty climate.
II
28 Dec 2016
No great urgency to get it fixed is there? IETs will just run on diesel mode throughout the tunnel area. Though plans to use 387s as Cardiff event crowd busters would be affected that is hardly a crucial hurdle.
Envoy
29 Aug 2014
The seats in the 387’s are even worse than those in the IET’s. Can’t see people wanting to be in them for long.
