1. 125Group forum donation: see here!
Great Northern Class 700 diagrams?
Discussion in 'Allocations, Diagrams & Timetables' started by JonathanPrince, 11 Oct 2017.
  1. sefton
    sefton Member
    504
    30 Oct 2017
    The reason these trains are a design failure is the services they are to be used on.
    For a short 20 minute hop when crammed as full as a tube train their design may have a point.
    However for a long distance hour long journey specifying rediculously squashed together seats so your customers suffer is preposterous.
    And yes train customers will have to suffer these failures for many years to come. That is not something to celebrate, but should provoke an investigation to prevent it ever happening again.
  2. AM9
    AM9 Established Member
    5,896
    13 May 2014
    St Albans
    When a 240m long train can carry over 1700 passengers and deliver 40 second dwells with large egress/ingres volumes in safety with a conventional layout such as a Class365 then maybe such trains may be deployed. But as yet, it can't be done so Class700/345 and newer classes about to be designed will be the style that gives us the route capacity needed. If that capacity isn't there then all the investment is wasted. If the slightly increased comfort levels are really in demand, then the TOC could offer the two types of interior with a ticket price difference. I would imagine that the Class700s wouldn't be short of passengers as not many are prepared to pay for the extra comfort it gives to the first on board.
  3. Hadders
    Hadders Established Member
    5,485
    27 Apr 2011
    Passengers on the 0656 from Peterborough seem to think that the reason standard class is so bad is to sell more 1st class tickets...
    I've no issues with wider doors and fewer seats near to the doors to give larger areas for standing but there is no excuse for the squashed up ironing board seats that are totally unsuitable for many of the routes covered by the trains. Grammer seats, the same seats fitted to the 345s or even the same seats as on the 365s would be so much better than what we've ended up with.
    When these trains launched we were told we couldn't even have table back seats because they would make the train too heavy and they would adversely affect dwell times in the core. What a load of rubbish - if this really is the case why are they now being fitted?
    The DfT has simply tried to fob us off with a sub standard interior. It didn't need to be like this.
  4. Failed Unit
    Failed Unit Established Member
    6,369
    26 Jan 2009
    Central Belt
    I am interested in what extra capacity these trains will give?
    Less seats? So more people standing maybe.
    However more stops on existing services means that a train already standing at Welwyn Garden city such as the 0755 will somehow need to take Hatfield and Potters bar passengers. Where are they going to fit?
    The service is also less frequent. Again how does the 700 help this?
    The service is slower so maybe they hope less people will use it?
    Sadly nothing for great northern passengers to look forward to. Should add this isn’t the fault of the train, it is whoever has decided the busiest stations on the line need a worse service and the quiet ones like welwyn north and knebworth need improvements. The same problems would exist with 365s or 387s. It is just the 700s coincides with one of the biggest reductions in capacity since the 153 was introduced. If the 700s brought an increase in the number of seats I am sure the majory of passengers would live them. But less seats, lower frequency and slower journeys is why we are unhappy. The introduction of the 700s I suspect is a sad coincidence.
    Thameslink is seeing capacity improvements. (8 coach into 12) great northern isn’t.
  5. jon0844
    jon0844 Veteran Member
    23,297
    1 Feb 2009
    I don't remember weight being mentioned before, but I do think they had/have a point about dwell times. One solution could have been to have tables only on the back of window seats, but we shall see as time goes on.
    I suspect the DfT caved in following outrage from users, and decided not stick to their guns or attempt to justify their original decision, just as many companies now give in to outrage for an easy life, often apologising for things they needn't apologise for or arguably shouldn't apologise for.
    As an aside, we've just had an MP apologise for having a go at a person putting their feet on the seats. Why do that? Now the person thinks they 'won' and will carry on.
  6. sefton
    sefton Member
    504
    30 Oct 2017
    Tables have no impact on dwell times.
    Dwell time is determined by the carriage that empties last, since you cannot leave until everyone in that carriage gets off (although one or two drivers try).
    The last carriage to empty is the one next to the stairs as ironically everyone in there wants to be away first. Nobody in that carriage is going to let anything delay them getting off as soon as possible, let alone a table.
    So fitting tables isn't giving in despite being right, it is giving in because you are wrong.
  7. Dunnyrail
    Dunnyrail Member
    67
    26 Oct 2017
    Dont know never tried, would I ba able to use it on Vodaphone?
    JonD
  8. bramling
    bramling Established Member
    5,240
    South-east / Barnard Castle
    And, a walk-through train *encourages* folk to move through the train to be near the doorway nearest to the exit, which means *more* people trying to alight through that door. So much for dwell times...
  9. Failed Unit
    6,369
    26 Jan 2009
    Central Belt
    The first class at rear situation encourages people to always be at rear of the train slowing down dwells as well.
    Back to topic and work at weekends or do the 700s just sit at Peterborough?
  10. Ianno87
    Ianno87 Established Member
    3,476
    3 May 2015
    I've found that alighting at Blackfriars in the morning peak that the queue for the southernmost door is sometimes so long, you can easily alight from the 3rd/4th coach and beat the last person in the queue (who barged you out of the way to get there...)
    I guess the walk through does have a benefit for dwell times when *boarding* (usually the slower of the two processes), i.e. people can spread down to board wherever, and walk down when they alight without worrying about being in the right carriage for "their" station.
  11. bramling
    5,240
    I think a walk-through train has some merit on a genuine metro application, but only if all the platform entrances - at the busiest stations at least - are spread along the platform. This simply isn't Thameslink - your example of Blackfriars demonstrates this amply well. Add in the fact that quite often the entrance is at the same place as the exit, so your busiest doors for alighting may well also have more trying to entrain through them too - one can do all the encouragement in the world but there's only so much which can be done, especially in the current climate where it's not really considered acceptable to close doors on people - which doesn't really work anyway as all that happens is the train doesn't get interlock or someone will get caught and then we simply get the extra time of the whole door closure process having to be repeated.
    I never really understand why some people are *so* keen to be quick off the train. I do it very occasionally if for unforeseen reasons I'm really in a hurry, but for me this is very much the exception. Yet one can see the same people doing it day in day out. It's been going on for years, and I just can't see it changing.
    In my view walk-through trains are a fad which will come and pass.
  12. APUK002
    APUK002 Member
    294
    26 Dec 2016
    Yes,of course. You sign up when at a 02 WiFi hotspot once,then u can use at any 02 WiFi spot :
    sure you can,but not @ Biggleswade station,:https://www.greatnorthernrail.com/travel-information/plan-your-journey/wifi-at-our-stations, a lot of cafes and venues use o2 WiFi,harvester,Costa e.g.
  13. sefton
    sefton Member
    504
    30 Oct 2017
    I always pick either the 'exit' carriage so I can avoid the queues at the stairs, the barriers, the exit from the car park, and have a chance of catching the bus if the train is late.
    Or if that is full the carriage furthest from the exit so the crowds have disappeared by the time I get there.
  14. TT-ONR-NRN
    TT-ONR-NRN On Moderation
    2,567
    30 Dec 2016
    Still only two trains a day?
  15. otomous
    otomous Member
    444
    5 Oct 2011
    Capacity isn’t just about frequency. Yes there are fewer seats to squash in more standing passengers but that is the cost we pay for the limited loading gauge we have in the UK. We are pretty much at the limits of the realistic size of the rolling stock’s footprint. Can’t make them wider, can’t make them taller, can’t make them longer. Fewer seats is it. Before we get to standing only full stop hopefully infrastructure upgrades, changes in working practices or new lines will open up more opportunities (but look what a bad press HS2 gets when it tries the latter). ATO in the core will provide consistent journeys from stop to stop, making full use of headways.
    The trains themselves have features which speed up dispatch - wide fast sliding doors, walk through, more space for passengers to get to and from the doorways, fast acceleration, and these help to increase a given route capacity too.
  16. 387star
    387star Established Member
    5,113
    Not sure tables are being retro fitted yet or just 700125 upwards
    The overhead luggage racks are miles better than 377s and the interior finish is much more streamlined. .. The 377 has too many rattly panels for instance about three separate parts from the windows down whereas the 700 has the clean white wall finish
  17. APUK002
    APUK002 Member
    294
    26 Dec 2016
    Found the horn of 700, it sounds funny, but what does the whistle sound like?
    The was a 70p test run yesterday xhe to Cambridge [CBG] and back, does this mean anything, diagrams wise?
  18. LewisT
    LewisT Member
    10
    6 Aug 2017
    The same unit seems to be going from Hornsey to CBG and back quite often. I spotted it at about 1pm a couple of Tuesdays ago just beside Platform 8. Believe this may be a 700 run on Tuesday http://www.realtimetrains.co.uk/train/N09852/2017/12/20/advanced. Also, there was a unit parked up on Plat 3 yesterday for about 5 hours, according to RTT, http://www.realtimetrains.co.uk/train/N09817/2017/12/16/advanced and http://www.realtimetrains.co.uk/train/N09818/2017/12/16/advanced.
  19. APUK002
    APUK002 Member
    294
    26 Dec 2016
    Yes that’s right,they test daily back and forth to Cbg.
  20. APUK002
    APUK002 Member
    294
    26 Dec 2016
    365501 de-branded now, future in sight (700s soon), 6 diagrams on paper to change?
  21. TT-ONR-NRN
    2,567
    30 Dec 2016
    I don’t see why they're being debranded when they aren’t going to a new TOC.
  22. AM9
    5,896
    13 May 2014
    St Albans
    At the moment!
  23. class387
    class387 Established Member
    1,252
    9 Oct 2015
    Any idea when the next GN 700 diagrams are being introduced?
  24. Skimble19
    Skimble19 Established Member
    1,335
    12 Dec 2009
    East Coast Mainline
    12th February will be when the diagrams next change.
  25. jon0844
    23,297
    1 Feb 2009
    Lots of 700s out and about in the day now, so lots more testing of both 8 and 12 car trains. Presumably drivers getting some time with them to sign them.
  26. Skimble19
    1,335
    12 Dec 2009
    East Coast Mainline
    Minor amendment to my previous post: Due to Engineering Works between Ely and Kings Lynn from 12th to 16th February, many diagrams that week will be amended, as such the 700/0s will not be entering service on GN until 19th February. The following Weekday services are planned to swap to 700/0s on this date:
    Cambridge Route
    UP
    2R35
    2R41
    1R45
    1R47
    1R55
    1C01
    1C49
    1T29
    1T33
    1T69
    2T61
    1T17
    1T25
    DOWN
    1T14
    1T18
    1T34
    2T22
    1T02
    1T10
    2C02
    1R38
    2C28
    2R38
    2R50
    1C88
    Peterborough Route
    UP
    2P21
    1P41
    2P91
    1P09
    1P51
    1P53
    1P57
    2P45
    1P63
    1P69
    2P63
    2P65
    1P85
    1P73
    DOWN
    2P02
    1P42
    1P44
    2P06
    1P50
    2P14
    1P54
    1P56
    1P60
    1P64
    1P18
    1P70
    1P78
    1P80
    1P32
    2P58
    Welwyn Route
    UP
    2Y83
    2Y91
    2Y67
    700/1 - Peterborough Route
    UP
    1P05
    1P49
    DOWN
    1P94
    1P66
    1P68
    Apologies if I've missed any. Will add weekend services when I get chance.
  27. Hadders
    5,485
    27 Apr 2011
    Are the 700s coming off the existing diagrams - I seem to remember someone saying that was the plan.
  28. class387
    1,252
    9 Oct 2015
    Thank you!
  29. Failed Unit
    6,369
    26 Jan 2009
    Central Belt
    The trains. (Adding detail from Post above - thanks for gen)
    Cambridge Route
    UP
    2R35 0834 Letchworth - London
    2R41 1001 Letchworth - London
    1R45 0713 Royston - London
    1R47 0732 Royston - London
    1R55 1713 Royston - London
    1C01 0514 Cambridge - London
    1C49 0756 Cambridge - London
    1T29 1158 Ely - London
    1T33 1358 Ely - London
    1T69 1658 Ely - London
    2T61 1747 Cambridge- London
    1T17 1858 Ely - London
    1T25 2058 Ely - London
    DOWN
    1T14 1014 London- Ely
    1T18 1114 London - Ely
    1T34 1514 London - Ely
    2T22 1605 London- Cambridge North.
    1T02 1714 London- Ely
    1T10 1914 London - Ely
    2C02 0604 London - Cambridge
    1R38 1616 London - Royston
    2C28 1722 London - Cambridge
    2R38 1934 London - letchworth
    2R50 2234 London - Royston
    1C88
    Peterborough Route
    UP
    2P21 0410 Peterborough- London
    1P41 0510 Peterborough - London
    2P91 0547 Peterborough- London
    1P09 0726 Peterborough- London
    1P51 0816 Peterborough- London
    1P53 0847 Peterborough- London
    1P57 0946 Peterborough - London
    2P45 1018 Peterborough- London
    1P63 1247 Peterborough- London
    1P69 1547 Peterborough- London
    2P63 1916 Peterborough- London
    2P65 2016 Peterborough- London.
    1P85 2244 Peterborough - London
    1P73 1803 Peterborough- London.
    DOWN
    2P02 0634 London- Peterborough
    1P42 0722 London- Peterborough
    1P44 0822 London - Peterborough
    2P06 0834 London - Peterborough
    1P50 1122 London - Peterborough
    2P14 1234 London - Peterborough
    1P54 1322 London - Peterborough
    1P56 1422 London - Peterborough
    1P60 1622 London - Huntingdon
    1P64 1712 London - Peterborough
    1P18 1837 London - Peterborough
    1P70 1842 London - Peterborough
    1P78 2022 London - Peterborough
    1P80 2122 London - Peterborough
    1P32 2207 London - Peterborough
    2P58 0034 London - Peterborough
    Welwyn Route
    UP
    2Y83 0703 Welwyn- London
    2Y91 1639 welwyn - London
    2Y67 2334 Welwyn - London
    Will fill in gaps later.
  30. TheDavibob
    TheDavibob Member
    305
    10 Oct 2016
    The heavy use on the alternate fasts to Ely is intriguing -- not a service they'll eventually be in use on. Will these all be the souped up versions with WiFi and table-back seats?
Share This Page
