Ha,is that a coincidence?700125 and 700128 both have seat back tables (as do 700139 and 700140 which are also on the GN).
Ha,the twitter do keep saying,it’s up to onboard (driver counted) or other staff(control,Twitter,platform/station)to declassify itOh! I'l try that then. Not sure why we're being told to add the '1' if it's only function is to declassify the rear first class, only to then go through a rigmorale of cancelling it out!
Typical railway!!
Yes I.meant tables throughout standard not first! The wifi actually comes up as Thameslink wifi. There doesn't seem to be any form of tables in the seat bays, they are purely sear back ones in standard.Does it have seat back tables? Not seen one with either tables or Wi-Fi yet.
Ooo, WiFi live on 700’s(some), no announcement from twitter yet.Also took this service. The lower number of seats was noticeable but the provision for standing room will definitely be helpful. The units certainly shift on AC power and seem to handle wheel slippage very well indeed. The additional power versus 365s will help recover small delays. The WiFi was great, the seat back tables a nice addition and legroom in the priority seats acceptable. Standard seats, less so, and the window side cabling boxes definitely intrude.
Ok,im going on 1 tomorrow for a test.Tonight I saw both 1P66 and 1P68 just before Stevenage and the first was pretty well loaded with a lot of people standing (but far from full) and the second looked to have quite a lot of room with a lot less people standing. First class was also as good as empty at the back, so I assume people now know it's first class?
Maybe people are avoiding them and using other trains, but they don't appear to be too bad. Both were on time too!
Only you can answer that, surely!Ok,have I been on them yet?
Oops, sorry,got new keyboardOnly you can answer that, surely!
Was pretty much ECS to Peterborough with barely 1 coach load on a 12 car Train. How long can that sort of madness continue?
JonD
It's always been the case that at peak times there's quite an over-provision of services between Huntingdon and Peterborough. It's mainly for operational convenience - there's no good way of turning anything between Hitchin and Peterborough, plus train crews are based at Peterborough.
From a passenger point of view, if the fast services were turned short then this would deprive Peterborough of fast GN trains. If the slower services were turned short this would take away some intermediate journeys.
The 0736 from Stevenage is cancelled today, apparently due to a shortage of drivers.
Are the tickets from Stevenage valid on GR?
Why would the be? Not their problem.
I thought you could use any TOC on an anytime or off peak return between London and Stevenage? Oh ok then.
Are the 700s going to be fixed to which side they are on (TL or GN) until the sort of mergey bit?
So is the 0733 Peterborough- Kings cross. Thameslink has this happen a lot at the beginning where the probably have a driver but not one that is passed for the 700s. At least when the 387s were introduced at the beginning they could send another unit as the diagrams focused on Hornsey.
As this is simple out and back diagram from the depot you’d have thought it would be easy to substitute a 365, if the cause was simply a driver not passed to drive 700s.
Sort of but not sure. It would be taken up by yesterday’s shift? If no-one signed on at Peterborough in the morning with traction knowledge the have no-one or no-units to swap it with. At least at Hornsey they do. Sure it was a common situation when they introduced them on Thameslink.
