Siemens Staines
- Joined
- 30 Jul 2015
- Messages
- 780
Yes, sorry about that typo! I have corrected my mistake
Where the electrification of the lines and branches has been postponed, has the design work been completed and could work start straight away if a decision to proceed was given?
How long would it actually take to electrify the Windsor branch?
At the moment there must be a lot of trained/skilled staff and equipment with nothing to do.
When I was last at Paddington (29th Jan this year, from about 4pm to 6pm), it was noticeable that quite a few 800s/802s were running on diesel - especially those coming-in ECS from North Pole.As most of the departures from Paddington are now electric, which services still use diesel?
I did notice an improvement in the air quality when I was there a couple of months ago (1st time since the HST withdrawal).
do you know if a feeder station got binned or was the intention to power Oxford from Didcot?No, the design was not completed (most final designs are completed a matter of weeks before installation), and work could not start straight away - far from it.
End fed from Didcot IIRC - there’s only ever been the four main grid connections, and a fifth if Bramley happens. There’s a diagram showing the originally proposed layout linked in this post:do you know if a feeder station got binned or was the intention to power Oxford from Didcot?
Could it be that Kensal Green ATFS still isn't online yet?End fed from Didcot IIRC - there’s only ever been the four main grid connections, and a fifth if Bramley happens. There’s a diagram showing the originally proposed layout linked in this post:
https://www.railforums.co.uk/thread...ification-progress.83452/page-69#post-2472706
...the diamond shaped symbols are the main feeds.
I think your running commentary had it operating in classic mode ages ago, but it was to change to autotransformer feeding at some stage. You asked a question about that last August so I guess either no one noticed it at the time, or didn’t know the answer.Could it be that Kensal Green ATFS still isn't online yet?
Perhaps, in the words of our previous (at time of posting) PM: "Nothing Has Changed!"I think your running commentary had it operating in classic mode ages ago, but it was to change to autotransformer feeding at some stage. You asked a question about that last August so I guess either no one noticed it at the time, or didn’t know the answer.
Certainly, one bit of evidence to back this up is that some (and presumably all) ATF Sealing Ends (where the ATF goes from being a bare wire to being cabled) east of Maidenhead are still bearing portable Earths. The recent wraths of Ciara & Dennis led to falling trees that broke some of the ATF wires near Acton ML too, so that's another obstacle.
The biggest single change to improve the air quality in the Paddington train shed was the fitting of effective exhaust filters to the Burger King kiosk near the end of platforms 7 and 8.As most of the departures from Paddington are now electric, which services still use diesel?
Nothing really, unless Bromsgrove - Worcester (and beyond) and Bromsgrove - Cheltenham/Gloucester - Bristol Parkway were added in too. Plus the remaining unelectrified tracks between Barnt Green and Kings Norton.The recently wired Lickey Incline is a classic setup I read... and famously steep -
would anything be gained in converting it...
especially if freight starts to use electric traction up the bank- pair of 92s would be a considerable load and take most of the available supply as it exists today.Nothing really, unless Bromsgrove - Worcester (and beyond) and Bromsgrove - Cheltenham/Gloucester - Bristol Parkway were added in too. Plus the remaining unelectrified tracks between Barnt Green and Kings Norton.
If those were wired, more services would need to use the wires (beyond the current 3tph of 323s), and THEN there would probably be a case for converting the Lickey (and the whole route to Bristol) to AT feeding.
OK can a type 92 (eg pulling a steel train from Wales) do a run through the Severn Tunnel then run on eastwards on the main line. And would it need to run as a double header??
Safe and reliable OLE operation depends on the ability of the pantograph on the train to collect traction current and follow the wire as it rises and falls to meet infrastructure conditions. Particularly relevant to Steventon are the restrictions imposed by the two level-crossings and the low bridge height.
UK standards generally comply with the EU technical standards for interoperability but, for OLE, a generic set of OLE rules apply, with allowed non-compliance for UK conditions. To achieve the best possible performance under all conditions and at all locations, without the need to design from first principles all the time, these rules must necessarily be conservative.
Under these rules, the designer is driven to include the rate of rise and fall of the wire as seen by the train, generally expressed as a gradient of 1:X (one unit of vertical rise and fall over X units of length). Deviating from limits can mean loss of collector equipment contact, and therefore traction power, along with increased wear on the contact wire, arcing, and a higher potential for dewirement.
The early design processes made the normal assumption that the bridge would be reconstructed to allow for a ‘standard’ OLE design and the running of electric trains at normal linespeeds, in this case 125mph.
However, as the processes of consultation with local authorities and stakeholders progressed, it became apparent that this assumed strategy of reconstruction would not be accepted and the existing bridge would have to be retained, resulting in the linespeed for electric trains being considerably reduced and journey times being lengthened by around five minutes.........
and any hope of some electric freight through the tunnel??are they doing any more work on the wires in the tunnel over Easter (to travel in hope...)
That's not gonna happen until (at the very least) the Poplar Chord (Acton Yard - North London Line) gets wired. Until that occurs, the GWML (with the exception of the Elizabeth Line) will be electrically isolated from the rest of the electrified network.and any hope of some electric freight through the tunnel??
When's everybody's best guess as to when electrification will finally reach Oxford? I mean everything's on hold due to Covid-19 at the moment, but it's taking way too long all the same
Network Rail has not been given the go ahead for any future work on the GW electrification project regrettably. So until such time as the SoS makes an announcement to that effect there is, to the best of my knowledge, no activity. (There may be some behind the scenes work coming up with new costings to help inform any decision, but no spades in the ground).
Well that’s sort of the point of electrifying a line isn’t it.A shame, otherwise oxford to Paddington trains could've been run entirely on electric
