Great Western Electrification Progress
hwl
5 Feb 2012
There may not be much a construction industry left in UK soon due to virus issues, it will take a long time to rebuild our ability to carry out major construction work from that that low point.
Meerkat
14 Jul 2018
Unless lots of working age people die, or somehow the equipment gets destroyed, I can’t see how you can come to that conclusion
Peter Sarf
Croydon
The bigger threat to electrification is due to the pause that came about before COVID-19. The teams that built up experience have been disbanded and so, when the next projects start, there will be a labour force but they will be un-trained.
hwl
5 Feb 2012
The construction industry (based on my discussions with key firms) is expecting will be very damaged with all existing projects picking up significant extra delays delay and major supply chain disruption e.g. firms /factory closing leading to huge amounts of extra work to complete things. This will knock new projects even further into the future.
hwl
5 Feb 2012
The knowledge / specialist equipment hasn't entirely dispersed, but the crisis construction faces is likely to see that reduced even further.
The Ham
6 Jul 2012
Whilst I agree that there's a risk that it could disperse further there's also a chance that with the construction industry badly hit that it could be fairly easy (as long as it happens early on) that enough of a team is reformed to allow future electrification to happen.
Peter Sarf
Croydon
Actually I have been wondering for a while if railway construction projects might be cheaper if there was not so much construction going on elsewhere in the UK. I mean making resources scarce and so more expensive. I think there has been a lot of construction because loans are cheap maybe ?.
FGW_DID
23 Jun 2011
81E
There wasn't enough expertise / qualified personnel from the UK to start with on the GWML Electrification, I cant speak for other areas but certainly the OLE team who wired up Reading TCD, were predominately Spaniards working with a UK COSS.
linuxlad7
9 Nov 2017
What about Furrer unt Frei (wherent they the OLE expert contractors ,... and any news from Noel Dolphyn??)
Domh245
6 Apr 2013
nowhere
F+F design electrification components, as do several others including Bonomi & Siemens. Then there are the people who design the actual systems using said components (eg Atkins), and finally the people who are out on the ground physically installing it. The component design companies are all global and so won't loose any skills, the system designers are again relatively global - if there aren't any british railways in need of electrification designs, there'll be other railways that they can crack on with, or even use skills from other offices across the world for UK systems if necessary in the future. It's the installers where the loss of skills from no further schemes will be most felt.
The installers are mult-national too. Much of the recent Scottish electrification was installed by Italians.
DidcotDickie
12 Mar 2017
Oxfordshire
Yep. On the Great Western electrification Amey partnered with Inabensa (Spanish) for the installation. They guys I saw putting up the wires from the HOPS train between Challow and Uffington a few years ago sounded Spanish.
Dai Corner
20 Jul 2015
Amey are/were due to be starting the Welsh Valley lines around now.
stj
15 Apr 2019
Things could go either way if we end up with mass unemployment there could be a massive expansion of railway and infrastructure projects to create jobs.
IanXC
Emeritus Moderator
18 Dec 2009
Lets be careful here. I'm not sure we're wishing for mass unemployment...
The Ham
6 Jul 2012
I am certainly not. To prevent that it needs some good infrastructure projects and electrification does that as well as helping the climate.
Indeed, I would go further and suggest that road based projects are likely to be cut as demand drops due to more people working from home.
Whilst this would also have an impact on rail, much of the losses from rail are likely to be offset by more occasional rail travel from those who no longer use road transport.
Richard Scott
13 Dec 2018
Looks like Severn Tunnel is closed this weekend, they working on the overheads with a view to bringing it into operation?
si404
28 Dec 2012
Most road-based projects are about connecting to new residential developments. OK, you won't see as many big ticket motorway widenings to increase commuter capacity, but 'distributor roads' and 'relief roads' are about opening up areas to development, not actually increasing capacity.
And increased working from home is going to increase demand for less dense living (and thus more relief/distributor roads to serve new suburban/exurban development as urban densification would be less lucrative) - spending more time at home and less in the office, you'd favour space to work over speed to work.
Richard Scott
13 Dec 2018
Was asking the question as no trains through the tunnel this weekend so afraid I don't have any knowledge of the work going on, just happen to live nearby!
Dhassell
22 Mar 2015
They where meant to be moving in the new bridge at Gipsy Patch Lane, but that was postponed. Network Rail on twitter have posted about replacing points south of Pilning towards the Severn Tunnel.
The Ham
6 Jul 2012
Most of the roads schemes we I've been involved in which they create the link roads you describe serve two purposes:
- bypass a busy junction
- provide access to the houses
With a reduction in traffic the first point would be less critical, so they may not be required.
However the funding of such schemes is primarily provided by the housebuilders who benefit from the roads involved. Without needing to find such roads the councils are likely to require the householders to build better cycle facilities and/or invest in public transport.
Amey itself is Spanish-owned (by Ferrovial).
It is also reputed to be up for sale/disposal after steep UK losses (not in rail, apparently).
There is still no real sign that any new electrification projects are going to get the green light.
The main hope now is that it will figure in HMG plans to kick-start industry after Covid-19.
Even then there are few installation-ready schemes after the 5-year hiatus since the CP5 plug was pulled..
themiller
4 Dec 2011
Cumbria, UK
Surely, the parts of the GWR electrification to Temple Meads and to Oxford are ready to go as they were suddenly curtailed to get Cardiff wired.
