Greater Anglia Rolling Stock Updates
Bikeman78
26 Apr 2018
Ilford drivers don’t sign Clacton and no other depot on the East sign them. They have to be conducted between Colchester and Clacton when they go for maintenance.
Not sure if they are cleared for passenger use or not but would seem unlikely to happen given the above.
Thanks for the clarification.
Bikeman78
26 Apr 2018
The /6s generally always have made a bit more of a racket in my experience, although the phase one units are starting to catch up. 343 and 508 are two to watch (well, listen!) out for ;)
I'm wondering how much longer we'll be able to enjoy a 317 on the weekdays only 1907 Liverpool Street - King's Lynn. Tottenham Hale to Audley End non-stop, and an end-to-end run of almost 100 miles!
I had 317663 out to Ipswich not long before it was withdrawn. Loud motors and the driver really went for it; stinky brake smell at every stop. Railperf would have enjoyed timing it I think. I'll watch out for 343 and 508.
Unfortunately the 1907 King's Lynn has been a 379 since it started running again.
NoMorePacers
18 Feb 2016
Hull
317s ran to King's Lynn until March 20th. Has anything changed since then to prevent them going there?
I think some stations have had their external DOO equipment removed since then, so the only trains that the operators are willing to send up to Kings Lynn are those which have bodyside CCTV cameras fitted.
Bikeman78
26 Apr 2018
Really? That seems rather backward until all the 317s are gone. So if a 317 kicks out on the 1907 it gets cancelled at Ely.
Class 170101
1 Mar 2014
Or non-stop to Kings Lynn. Remember most services that way are provided by GTR who run the stations and use Class 387s so why maintain the DOO mirrors for a handful of trains per day. Class 379s suffice and if there is an issue the Class 317s would currently deputise on Stansted Express to release a Class 379 or two.
317666
4 Sep 2009
Ely
365s are no longer able to run through to King's Lynn for the same reason. I suppose I should have realised it would apply to the 317s too!
306024
23 Jan 2013
East Anglia
Class 317s have operated DOO with the driver simply sticking their head out of the window and looking back on many routes, similar to class 315s. Is this method of working, old fashioned as it is, not permissible on this route, for any variety of reasons?
Class 365s, and 321s for that matter, are a different cab design and not so suitable for look back DOO.
NoMorePacers
18 Feb 2016
Hull
Well, theoretically 317s and 365s could still run to Kings Lynn stopping at each station on the way, but you'd need to provide a guard for door operation, which isn't really an option for either (GN have no guards at all obviously and I wouldn't imagine GA guards signing to Kings Lynn or signing 317s).
ashkeba
13 May 2019
S lightly curved platforms at Ely, King's Lynn and maybe Littleport?
87015
3 Mar 2006
GEML/WCML/SR
Absolute 317 gala today for any masochists with 379s restricted to non-multi operation so just a few out. 317s on nearly all Stansteds and many Cambridges.
Bikeman78
26 Apr 2018
I'll be one of those masochists later in the week! I see that a 317 worked up from Watlington this morning so they can still run from King's Lynn. I'm assuming the only reason it started at Watlington was that the ECS was late.
LowLevel
26 Oct 2013
I'll be one of those masochists later in the week! I see that a 317 worked up from Watlington this morning so they can still run from King's Lynn. I'm assuming the only reason it started at Watlington that the ECS was late.
Given the problems with the 379 fleet it might be that they have issued a temporary derogation to allow degraded dispatch with the 317s to avoid cancellations. Much the same as allowing guard dispatch on the 755 units once the number of cancellations due to faulty CCTV was getting out of hand, suddenly it went from "get you back to Norwich then fail the set" to guard dispatch for an protracted period.
ashkeba
13 May 2019
Probably but I think the Watlington platforms are straight and the King's Lynn are not.
43074
10 Oct 2012
Nope incorrect and nothing to do with it. The ECS was late as stated above, was nothing to do with despatch arrangements. The platforms at Kings Lynn are not a restriction on despatch. I think it's CD/RA there anyway, no mirrors or monitors involved.
Bikeman78
26 Apr 2018
I believe 317512 worked the 1807 LST-KLN throughout yesterday. The 1707 was a pair of 317s to Cambridge for a single 379 forward.
F Great Eastern
2 Apr 2009
East Anglia
I assume that the 379s not being able to work in multiple is the cause of the short forming on West Anglia that have appeared since?
I say I assume, because Greater Anglia simply are not disclosing why these short forms are happening, avoiding giving a reason on JourneyCheck and are telling passengers that their comments will be noted but not really saying any more than that.
I assume they simply don't want to say anything in case that the press picks up on what apparently happened?
samuelmorris
18 Jul 2013
Brentwood, Essex
I suspect so, it's very much a root cause they'd want to keep under wraps.
