TT-ONR-NRN
Regarding post #29
Meh, ok.
Meh, ok.
They'll even have a bunch of spare two-car diesel trains shortly thanks to GOBLIN electrification!
They aren't spare, they are earmarked for "wmtrains". If the leases are already signed, LO wouldn't have the option.
It might however be possible to wire it very cheaply as some kind of spur, but of course Windermere wasn't done on that basis so no chance.
That’s interesting, where did you hear it from then?
That’s interesting - considering WM 172s have different front ends, if I ran a TOC I’d want trains of the same class to be homogeneous. I think they’d do well sent off to Chiltern.
They'll have 4 different types of 350 soon enough
Yeah but I think a TOC’s network should be joined up. All other ToCs are - but LO have the 162/378 services stranded from the Lea Valley Lines with no proper connection (ie: At the same station) and they are both stranded from the Romford to Upminster line with no connection.
Single change at Ealing Broadway surely?Shame that Crossrail want to make passengers on that line make 2 changes to get to Heathrow....
The Greenford branch doesn't run to Ealing Broadway, apart from the last train of the day to Paddington and first train of the day from Paddington; it is a shuttle from West Ealing.Single change at Ealing Broadway surely?
Things have changed since I lived in Ealing. I used to catch a Greenford service home from Padd every day.The Greenford branch doesn't run to Ealing Broadway, apart from the last train of the day to Paddington and first train of the day from Paddington; it is a shuttle from West Ealing.
Having said that, since the original diagrams showing what trains will be stopping at stations were published, some changes were announced including an extra 2 tph, I haven't seen anywhere stating where these will call, so it may provide a single interchange for the Greenford branch?
Yes, things have changed. A new bay platform was provided at West Ealing a year or so ago (maybe a little more) and the through service cut back. All part of the general 'keep the relief lines clear for Crossrail' policy.
More importantly, it has given passengers at Southall a more even off peak timetable by reducing the 23 minute gaps twice an hour down to a much better 15 minutes. While in the peak it gives them another service they are guaranteed to be able to board (if only my fellow passengers actually used the full length of the train in order to take the most advantage of it… e.g. evening peak loads of seats in Coach 5 while you can't even move in Coaches 1-2)Also to allow GWR to introduce the half hourly Hayes shuttles to give passengers of Acton Main Line a better experience than a 2car 165
There use to be a turnback siding at Ealing Broadway but it has since been removed.The Greenford Line is something of a problem child and it is difficult to know what to do with it. It does have some strategic worth as a diversionary route and for turning stock, e.g. HSTs when the First Class ends up at the Country End.
It could have more potential if a turnback siding could have been constructed for it east of Ealing Broadway, allowing Greenford trains to terminate and start back there - Ealing Broadway would not only offer a direct link to the area's main shopping centre as well as far better onward connectivity with other rail services (not to mention same-platform interchange with services arriving from Paddington), and it would allow two trains to maintain a 20-minute-interval service (just). However I suspect the lack of available paths in between the freight and planned extra Crossrail services would make this a no-no.
I suspect Crossrail's Sat and Sun off-peak will be basically the same as the weekday off-peak service, and the primary reason for curtailing the Greenford shuttle was to remove the flat crossing conflict with up Crossrail services. It won't really matter what day of the week it is, the problem will be the same.Yes I was in support of an Ealing Broadway service even once an hour, but surely on a Sunday the service could start running and do Ealing or London Paddington? I imagine more paths would be available to enable this.
True, although the reduced capacity will be less of an issue at weekends. Politically however I can foresee locals asking "well if you can run trains from Greenford to Paddington on weekends then why not weekdays?", and we end up with another Wimbledon loop saga...I suspect Crossrail's Sat and Sun off-peak will be basically the same as the weekday off-peak service, and the primary reason for curtailing the Greenford shuttle was to remove the flat crossing conflict with up Crossrail services. It won't really matter what day of the week it is, the problem will be the same.
Will West Ealing gain a Sunday service under Crossrail? As my local station I'm really hoping for this, you should see how many people are waiting on the platform in the morning peak!
Some stakeholders have questioned whether the Greenford branch is best served in future by the Great Western franchise or whether there could be a case for incorporating it into the Chiltern franchise, which is due to be re-let in 2021. Chiltern operates a large fleet of similar diesel trains from its nearby depot at Wembley and could therefore be well placed to operate the service in future.
a) Giving reasons, do you agree or disagree with the options outlined above for:
Transferring Greenford branch services to the Chiltern franchise;
Agree
Disagree
No opinion
I suggested similar branding for Romford - Upminster some time ago which I thought would make more sense than having a detached section of LO. All the responses rubbished the idea because the line branding wouldn't match the TOC.I'd propose using the Greenford branch for an experiment...
Post-Elizabeth Line, keep the service as-is for a couple of years, and see which way passenger numbers go. I'd fear downward, unless connections at West Ealing are quick and reliable.
Then one day:
-Put the line on the tube map as 'Elizabeth line link' (or something like that)
-Redecorate/rebrand the stations, with staff at all (and make accessible where practical)
-Up the service to 4tph* using a pair of Turbos internally refreshed with a dedicated livery (even if still GWR operated in practice)
...and see what that does to passenger numbers.
*4tph all day is not fully straightforward with the occasional freight paths on the route, and only one signal section each way from Drayton Green to Greenford South Jn, plus conflicting moves out of the bays at each end. Plus 4tph makes the line something like 'musical chairs' if a unit fails - one unit failing means the other has nowhere to go.
While it would take signalling/points work. The greenford gwr train would be best served running along the central line until west ruislip and then joining the chiltern mainline until high wycombe.
Yes, and about time too. It's a disgrace that Hanwell, West Ealing and Acton ML haven't had a Sunday service up to now.
