Ground signals Wolverhampton side of Sandwell and Dudley
brick60000
18 Apr 2013
Hi all,
Travelling from Smethwick Galton Bridge towards Wolverhampton just now, I noticed what appeared to be 2 aspect bulb (in design at least), unlit, ground mounted signals on the wolverhampton side of Sandwell and Dudley on the opposite direction line (up direction towards London). Does anyone know what their function is at all?
It's got me rather intrigued!!
Thanks,
Brick60000
neilb62
11 Nov 2015
Darwen.
They were something to do with the now defunct Albion Sdgs, probably backing signals for reversing in. I did ask about them whilst route-learning but no-one had much idea either!
Railsigns
15 Feb 2010
They are set back white lights, operated by a plunger when ground signal NS361 is 'off'.
PHILIPE
14 Nov 2011
Caerphilly
Normal access was by travelling from the Wolverhampton direction and reversing into the Sidings. Although more trains travel via the Abbey Foregate Loop at Shrewsbury now, at the time that oil trains ran from West Wales they used to travel that through so as to be able to approach from Wolverhampton.
mikestone1952
12 Feb 2011
That was the only way trains were allowed to access the sidings. The connection was relaid but almost immediately part plain lined. The planning application for the new EMR reclamation facility implied that they would be using rail, although it seems unlikely that any individual scrap yard would produce train-loads of recoverable material.
brick60000
18 Apr 2013
Thanks for all the replies! I've never seem such a signal before so all very interesting!
Sent from my SM-G935F using Tapatalk
9 Aug 2012
EMR are significantly rail linked in the area, with Kingsbury, Smethwick and Landor Street all with sidings. I do agree though, this operation is unlikely to use this connection. I wonder what will happen during resignalling!
Will need to check but I think signalling into the siding is removed but space left in the interlocking.
RichmondCommu
23 Feb 2010
Richmond, London
Do EMR own the scrap yard at Beeston which is also rail connected?
150219
24 Nov 2009
Believe it's still there on the panel at New Street, with reminder appliances, although 690A are partially plain-lined on the ground.
IIRC the three sidings aren't there anymore, in advance of the gate separating railway owned infrastructure and the sidings. I stand to be corrected, but I believe there are new industrial units in the area.
mikestone1952
12 Feb 2011
See above - the former oil terminal is now a reprocessing centre owned by EMR for recycling non-ferrous waste from their other yards. The sidings themselves have been removed but there is a gate in the security fence and it appears that the area they occupied has not been built on.
I know its still on the panel now, I will be surprised if it survives phases 4 and 5 of New St resignalling in its current form.
Harbornite
7 May 2016
I was neve aware of this plan, interesting!
The sidings were removed around 2011.
