Group Bourdon Tool
Mojo
7 Aug 2005
Chris Gresham has kindly agreed that the forum may host a free-to-download copy of his "Group Bourdon Tool" software.
Note that he can't offer support via the email address in the program any longer, as that domain has expired and therefore no longer valid.
He would like users to be aware of the following:
One thing which needs to be made known is the program was written before the appearance of Windows Vista/7/8 and, as a result, the .HLP (help file) may not function without the user installing the official Microsoft Help32 fix/patch.
This patch can be found for all versions of Windows (post XP) on Microsoft's website here:
http://support.microsoft.com/kb/917607
The patch should be installed before the Group Bourdon Tool.
This patch is *only* required to get he "help" function working on Windows Vista/7 or 8. It is *not* required for the program proper. In fact, the program will run without access to the help file - but will issue a warning upon launch.
He has requested that this software is not redistributed anywhere else, or changed in any way.
http://www.railforums.co.uk/bourdon.zip
shan5742
6 Feb 2013
lol I finally find one somewhere else and then it appears on rail forums :). thanks tho!!!
Blillpers
30 Oct 2012
I just tried it. A similar test is being used here in Sweden (together with the infamous "jumping dot"-test), so this is propably going to be really helpful! Are these results any good? :)
LCC106
16 Nov 2011
It's a good base to work on... You just need to reduce the omitted's now! (Other than that IIRC my results were similar to yours with practice).
Blillpers
30 Oct 2012
Third attempt, great improvements! Good thing there are two years before I can even take the test, lots of time to practice!:lol:
result2l.jpg*********
JCLeeds
10 Mar 2013
Not sure if this is working properly for me; the GBT version doesnt give any instructions on what to find and mark, what are you meant to do with the dots? Find patterns that replicate the first set? Any guidance appreciated
FlamTap
23 Nov 2012
Not sure if this is working properly for me; the GBT version doesnt give any instructions, what are you meant to do with the dots? Find patterns that replicate the first set? On both of them, the mouse doesnt work, the only way to move and mark is arrow keys L-R and arrow upward to mark? Is this correct? Any guidance appreciated
The program comes with built-in help covering everything you need to know, and includes a "quick start" section. The mouse isn't used.
JCLeeds
10 Mar 2013
Thanks, figured out the GBT as well as SCAAT now
The GBT is way harder than the SCAAT. I'm managing in the 1000+ cell region on GBT with 20+ omitted. What levels do we need to be attaining here? And what is more important, speed or accuracy?
playmore64
14 Mar 2012
Really! I prefer the GBT all day every day:D
In all honesty both are a major factor but I would place accuracy before speedy.
hopefultrainee
19 Jan 2013
hi thanks very much for this, I can't seem to get the help function, even after following the advice given. Is there any chance someone could give some instructions on how to practice the test? It would be most appreciated. Thanks
NI 271
10 Sep 2012
The Doghouse
Both use same controls, right arrow to move along from left to right, left arrow to go back (will only go back a maximum of one space), up arrow to mark/unmark the group in the box.
Any problems, let me know, I'm off work tomorrow so will be on here at some point.
JCLeeds
10 Mar 2013
I couldnt get the help to work either. Choose test type, SCAAT or GBT. Leave settings as default. SCAAT tells you what to look for on each sheet; controls are arrow keys; right goes right, up marks a cell, left goes left but you get one left space only to correct a fault. Up also unmarks on a correction. Keep going one cell at a time left to right until it tells you its finished, then you get a score.
I still dont know what is a good score!
Recent scores; anyone who can advise how these stack up?
SCAAT Total cells 1253, omitted 4, incorrect none
GBT Total cells 1120, omitted 7, incorrect none
All settings left as default
Beveridges
8 Sep 2010
BLACKPOOL
I've said it before & I'll say it again, 7 omitted "might" pass but you should aim for 2 or less to be safe
daddy_badger
21 Mar 2013
54.083061, -0.192220
In round 1 of scaat you have to find a particular shape on every row working left to right. In round 2 you have to find 2 particular shapes in every row working left to right. In round 3 of scaat you have to find a particular shape plus the first shape at the the start of each row for that row only. Hope that makes sense. On the paper gbt there are 18 rows, I managed to get to 14 making 1 mistake that I corrected on the 5th sheet. I passed, however you still need to do well in the TRP and MT4 (if the toc you apply to uses that test.)
387star
omissions and incorrect selections are both marked as negative I think? therefore they are as bad as each other especially when there are multiple mistakes per page
am I right?
bandit
6 Mar 2013
Overall Statistics:
Perception & Attention:
Targets Omitted ------------ 3
Marked Incorrect ----------- None
Speed:
Total Cells ---------------- 1350
Mean Cell Time ------------- 0.289
Median Cell Time ----------- 0.230
Completed Rows ------------- 52
Mean Row Time -------------- 7.234
Median Row Time ------------ 7.240
Vigilance:
Row Fluctuation ------------ 2.09
Does this look a good practise? Still working on the omitted.
daddy_badger
21 Mar 2013
Overall Statistics:
Speed:
Vigilance:
Who is your assessment with? Try 3 sheets at 2:00 minutes .
daddy_badger
21 Mar 2013
Might be ok, although nobody knows the pass mark. 1 missed is good, believe the row fluctuation needs to be low also so would say that score looks ok, but do not quote me on that. Scoring I think is different between TOCs and may take x number of the top percentage. Keep practicing, but not on the day before.
TDK
19 Apr 2008
Crewe
Scoring is down to the quality of the candidates. If you gett all the candidates passing then it will be graded, although you have passed the assessment if someone has a higher score than you in the GB/Reaction etc it could mean you will be put on hold where the other candiate will not. So say for example you have 20 candidates and they all pass the assessments and the company only need 10 drivers, ten will be put on hold.
Don't worry about row fluctuation and all these figures, just be consistant and accurate and you will pass.
Flyboy
1 Nov 2008
North Lincolnshire
On GBT I usually average about 12 rows and 300 cells per sheet giving a total of 1500 for the complete test, normally with about 2 to 3 omissions. I'm therefore trying to slow down to around 1400 cells in order to aim for zero omissions, however, my row fluctuation (vigilance) score is usually up at around 3 or 4. TDK - you say don't worry about row fluctuation but should I realistically be looking to get this lower?
Beveridges
8 Sep 2010
BLACKPOOL
A row fluctuation of 3-4 means you are consistant, 2 is very consistant and anything under 2 is robot-like
I had a look to see if my results are still saved on computer. These are some of my results from my last couple of practice attempts of this very boring test, back on the 13th December 2007.
GBT test results 1
Overall Statistics:
Targets Omitted ------------ None
Marked Incorrect ----------- 3
Speed:
Total Cells ---------------- 1519
Mean Cell Time ------------- 0.253
Completed Rows ------------- 58
Mean Row Time -------------- 6.324
Median Row Time ------------ 6.250
Vigilance:
Row Fluctuation ------------ 3.47
GBT test results 2
Overall Statistics:
Targets Omitted ------------ 1
Marked Incorrect ----------- 1
Speed:
Total Cells ---------------- 1630
Mean Cell Time ------------- 0.235
Median Cell Time ----------- 0.220
Completed Rows ------------- 64
Mean Row Time -------------- 5.878
Median Row Time ------------ 5.860
Vigilance:
Row Fluctuation ------------ 2.97
Passed with Grade A when I did the real thing.
Don't know what I'd get if I practiced again now, the test is so boring I can't motivate myself to have another go at it just for the sake of seeing if I can still do it.
