gazthomas
I agree, both the 365 and 319 are faster than that!I'm guessing you've never actually been on a 365, as they most certainly do reach 40mph a lot sooner than that!
The issue with Moorgate would be the lack of emergency access at either end of the unitCould they be shortened, have shoes fitted and used on the Moorgate branch?
Could someone explain what makes these units so great? My memories of taking these between London, Cambridge, and Ely, is them being noisy, uncomfortable to sit in, and terrible luggage storage (once I realised where it was). And odd toilet smells if you sat in the wrong carriage. To be fair I don't spend much time on British EMUs so I don't have much data to compare with...
If it came to that, don't see why they couldn't just keep doing it with 700s into the Cross instead...
No. Moorgate trains need end doors for emergency evacuation.Could they be shortened, have shoes fitted and used on the Moorgate branch?
Top speed of the 365s is 100mph. I've no expert knowledge but having travelled on them thousands of times over the last 20+ years they are no slouches.
If refurbished and fitted with Aircon, could the 365s be nippy enough to do the London to York stoppers, freeing up Azuma for more trains to Edinburgh and Leeds? I'm guessing acceleration compensating for lower top speed?
Meanwhile in the real world that wont be happeningIf refurbished and fitted with Aircon, could the 365s be nippy enough to do the London to York stoppers, freeing up Azuma for more trains to Edinburgh and Leeds? I'm guessing acceleration compensating for lower top speed?
I would like to see them run London to York services but as @47802 said that's unlikely to happen (unfortunately).If refurbished and fitted with Aircon, could the 365s be nippy enough to do the London to York stoppers, freeing up Azuma for more trains to Edinburgh and Leeds? I'm guessing acceleration compensating for lower top speed?
My suspicion is that when it all goes wrong fewer services will go through the core from the GN side meaning more services will need to revert to King's Cross. This will require more trains which is where the thought about 365s returning comes from.
Exactly my thoughts. It seems more wishful thinking.
I think that's where the overhauls are carried out.There was a 365 passing stratford at around 7:00-7:15 yesterday from hackney wick direction - showing up on RTT as going to Ilford - Are GA taking 365s?
No. Ilford do the C4 overhauls on them.There was a 365 passing stratford at around 7:00-7:15 yesterday from hackney wick direction - showing up on RTT as going to Ilford - Are GA taking 365s?
That's what I meantNo. Ilford do the C4 overhauls on them.
If GN services were terminated at Kings Cross then similarly some services south of the river would need to be terminated, probably at Blackfriars Bay Platforms, London Bridge or possibly Cannon Street. Since all four of these would be terminal statuion for some services those services would spend longer than usual at such stations so yes more Rolling Stock would be required.
Any pictures?There was a 365 passing stratford at around 7:00-7:15 yesterday from hackney wick direction - showing up on RTT as going to Ilford - Are GA taking 365s?
Yes but they would no longer be spending time traversing the core which means time saved. Given a Blackfriars-St Pancras time of 10 minutes (give or take) that time would now be available as turnround time. Given some small adjustments to timetables and turnrounds elsewhere the number of additional units needed might not be very big. And perhaps cut something back somewhere (where there is duplication) and bingo, no extra units needed at all!
Any pictures?
What route in the GA network are they clear to run on?It would be going to visit Bombardier sheds at Ilford Depot and nothing to do with GA. A Class 365 is not routed cleared for the majority of the GA network.
There is no need to free anything up for more ECML trains because the EC IEP fleet is already ordered and is significantly larger than the fleet it is replacing, specifically to allow for all the planned extra long distance services. Your hypothetical use of 365s instead seems to be clutching at straws...If refurbished and fitted with Aircon, could the 365s be nippy enough to do the London to York stoppers, freeing up Azuma for more trains to Edinburgh and Leeds? I'm guessing acceleration compensating for lower top speed?
