Connor43002
- Joined
- 16 Mar 2018
- Messages
- 34
Will GWR use one of their own for testing or would they hire a SWT unit?I heard this week that current plans are for Class 158’s to start crew training in Devon and Cornwall in May.
Cool, thanksPlan is to use a GWR unit.
Most of Exeter sign them anyway so only really Plymouth, Par and Penzance that need itI heard this week that current plans are for Class 158’s to start crew training in Devon and Cornwall in May.
Some Par drivers have moved down from other depots where they used to work them, possibly the same for Plymouth and Penzance as well.
Par and Penzance used to work them in Cornwall up until about 10 years ago.
Stupidly the HST's are not being used on services between Exeter and Taunton. Only on the Cardiff-Taunton and Exeter-Penzance which does'nt make any sense.
There are very few guards at Par and Penzance who were even on the railway 10 years ago! A lot of the drivers are former guards but obviously won' have had experience of driving 158's.Par and Penzance used to work them in Cornwall up until about 10 years ago.
It means you dont need to change trains especially if its a voyager the to continue to your final destination. It also means they would probably be using less TramsNot stupid if more XC services are to be extended from Bristol to Exeter as part of their proposed timetable changes and GWR will running more semi-fasts between Exeter and Paddington from next January. Should be plenty of trains between Taunton and Exeter, one way or another. I can't see any reason to provide even more.
Just passed a 158, assuming it was this one, stabled on EX which was quite nice to see for a change.Re-posting in correct thread, appreciate mentioned by another poster though. Was previously in GWR Livery Group
Reported on Group that 158956 today is working:-
1C04 07:26 Bristol TM to Penzance
2E68 13:39 Penzance to Exeter St Davids
Presumably Exeter West crew to Penzance and return
Testing on the Barnstaple line did happen, not sure on how well it went though but looking at the timings on RTT it was on time.Just passed a 158, assuming it was this one, stabled on EX which was quite nice to see for a change.
Does anyone have any info on the 159 being borrowed and tested on the Barnstaple line recently - whether it happened and if it was successful/able to keep timings etc? Thanks folks.
Thanks Conner. I was wondering how it compared to classes 143/150/153 in acceleration? But that sort of answers that then.Seen it at Truro
I'm not familiar with Turbos, but for me the (main) problems with the 158s are capacity, legroom and engine noise.It will be a sad day for the long distance users of the Cardiff - Portsmouth services, getting downgraded to an outer suburban 3+2 seated Turbo, hardly any tables, no seat back tables, counted place reservations most likely for advance tickets...
Definitely. I suppose it’ll be difficult to know until they’re put out on a few rush hour services?The other key indicator is dwell time. Whereas a Turbo is probably equal to a 150 on this count, a 158 with the slow door cycle and narrow vestibules is not. Hence the Barnstaple line test runs; any seconds that can be shaved off the running times between stations will reduce the impact of lengthened dwell times.
Engine noise on the Turbos is really impressive to me. Even sat directly above the engine it's not that noticeable and at the ends of each carriage you can actually hear yourself think...I'm not familiar with Turbos, but for me the (main) problems with the 158s are capacity, legroom and engine noise.
This thread is suggesting that the Turbos fix the capacity problem. How do they do on the other two?
We all already sign class 150 so 158 should just be a simple conversion one days training at most I'd guess
This is a very valid point, often 150s replace the usual 158s on the Portsmouth-Cardiff service, and although they are less pleasant to travel on (and not really suitable for the route at all) the dwell times seem much much better. It can take an age at Temple Meads or Southampton for passengers to squeeze through the narrow doors and vestibules of a 158 and find their seats, I expect the turbos could seriously help in this regard.The other key indicator is dwell time. Whereas a Turbo is probably equal to a 150 on this count, a 158 with the slow door cycle and narrow vestibules is not. Hence the Barnstaple line test runs; any seconds that can be shaved off the running times between stations will reduce the impact of lengthened dwell times.
Last Wednesday waiting at Bristol TM for the 17:54 service to Cardiff Central and when a refreshed Green GWR 158 rolls into the platform it took passengers to alight 3 whole minutes which is so time consuming and by then it was leaving Bristol TM 8 minutes late due to the excessive dwall times. So a Turbo would suit this route well as it was designed to work high capacity Regional Express services and can work to 90mph max speed.This is a very valid point, often 150s replace the usual 158s on the Portsmouth-Cardiff service, and although they are less pleasant to travel on (and not really suitable for the route at all) the dwell times seem much much better. It can take an age at Temple Meads or Southampton for passengers to squeeze through the narrow doors and vestibules of a 158 and find their seats, I expect the turbos could seriously help in this regard.
They should know pretty well what the dwell times will be without going to that amount of trouble, by looking at what happens at other stations with similar passenger numbers. There's probalby also a minimum dwell time in the timetable planning rules.Definitely. I suppose it’ll be difficult to know until they’re put out on a few rush hour services?
Unless GWR can rustle up a load of people to all cram onto a test train one night?
I’m up for it...
