GWR Class 165/166 Turbo Diagrams
PHILIPE
14 Nov 2011
Caerphilly
I thought the only Turbos were only embargoed in the Bristol area were the non RHM units e.g 166201.
I stand to be corrected as I'm not completely sure but I have read somewhere that there is a problem with gangway connections preventing them from working through the Severn Tunnel until a modification is done. In fact, I'd welcome the correct reason myself.
FGW_DID
23 Jun 2011
81E
It wasn’t a modification as such, to achieve safety validation to operate through the Tunnel, the unit had to have both sets of ‘bi-parting saloon end doors’ operative.
Over in LTV land, the Turbos ccould enter traffic with one set locked out but to use the Tunnel both sets have to be working.
6 Sep 2016
Looks like a two car 165 is standing in for a four car 387 on the following services this evening:
17:04 Didcot Parkway to London Paddington due 18:28
18:45 London Paddington to Reading due 19:49
20:00 Reading to London Paddington due 20:58
21:15 London Paddington to Didcot Parkway due 22:39
23:21 Didcot Parkway to London Paddington due 00:42
cactustwirly
10 Apr 2013
Why?
It's a reduced TT on Sundays, so there should be plenty of 387s about
FGW_DID
23 Jun 2011
81E
No idea why but those workings are on two 387 diagrams so it should be 2 vice 8! Genius is still staying there are two 387s (387145 & 165) allocated to the workings.
JN114
28 Jun 2005
I concur with FGW_DID - it’s an 8 car 387 in play - perhaps an earlier plan to 2 vice 8 was advertised by the LTV info controller; but not reversed when the depot wizards and their magic spanners sprung forth an 8 car.
6 Sep 2016
My apologies; JourneyCheck stated 2 vice 4.
Mitchell Hurd
28 Oct 2017
According to the latest (November 2018) issue of 'Modern Railways', the first 2 5-car Turbo train diagrams to Portsmouth Harbour will be the 07:30 and 17:30 services from Cardiff Central. At last larger trains!
I wonder what feedback will be given to these trains for long-distance passengers. Look at the quite poor feedback on SWR's Class 450's (3+2 seating) against the 2+2 Class 444's that have positive feedback!
My Guide to Services GWR book basically said it was during this timetable change. Must be further delays in electrification.
The delay has been previously explained as due to route clearance of Ground Signals in the Portsmouth Harbour area. I believe they’d already be running except for that problem.
Kite159
27 Jan 2014
West of Andover
The car is looking even more appealing by the day for those folk travelling from Southampton to Newport, instead of a nice 2+2 seated 158 with reservations, tables seats & folding seat back tables replaced by 3+2 outer suburban units with limited tables, (highly likely) no seat reservations and no folding seat back tables.
Those folding seat back tables are useful for when you have cups of coffee, as somewhere to rest the cup when it was half full.
cactustwirly
10 Apr 2013
But there's a lot more seats, so a lot less likely that you'll have to stand
JN114
28 Jun 2005
Due to failure of IET traction, 1P13 0701 Oxford to London Paddington will be formed 165135 this morning.
29 Jun 2018
166205 on 2U26 1648 Great Malvern to Cardiff replaced at Gloucester by 166213.
Defective internal doors given as reason so unable to traverse Severn tunnel.
Parallel
9 Dec 2013
Unsure if it’s a Turbo on the 17:49 Bristol to Weymouth (it usually is though) but the train operating this service today terminated at Frome with a train fault. Next train for Weymouth three hours later. (Unrelated side note, the 17:23 Bristol to Portsmouth was a 2 car 150 vice 3 car 158+2 car 150 today. 2 cars vice 5. Ouch!)
JN114
28 Jun 2005
Engine isolated - not allowed to outstable a 16x with an engine isolated; 17:49 Bristol Weymouth spends the night at Weymouth and (usually) works the 2nd Weymouth up in the morning.
30 Jul 2015
I notice that journeycheck is reporting a booked 4-car turn on Paddington - Bedwyn (albeit a 2-car today). I have never seen a pair of 16x on Bedwyn trains before, so is this a recent change?
07:05 Bedwyn to London Paddington due 08:41
09:06 London Paddington to Bedwyn due 10:19
10:41 Bedwyn to London Paddington due 11:52
12:06 London Paddington to Bedwyn due 13:19
This is due to a broken down train.
Will be formed of 2 coaches instead of 4.
Last Updated:01/11/2018 06:12
JN114
28 Jun 2005
Looks like a typo to me; those trains are all diagrammed 3 car Turbo. Also while the new length siding has been commissioned at Bedwyn, I’ve not yet seen authority for us to put longer than a 3 car on passenger services to Bedwyn yet.
Is it possible that running 4 cars to Bedwyn has only just been enabled by the extension of the reversing siding for IETs and the 0705 was deemed right for a capacity increase.
Edit: obviously not from the more informed comment above.
30 Jul 2015
Thank you for the reply. I did wonder if it was a typo but I know that the 07:05 Bedwyn - Paddington is an extremely busy train in to Reading, so not beyond the realms of possibility that it would be strengthened if it was possible, but it sounds like it isn't.
causton
4 Aug 2010
But unless it has gained some method of having seat numbers and a method of being able to hold seat reservation slips, it will be like a 350 on LNWR having coaches being lettered A-B-C-D.
I assume you mean LNR? I don't think Network Rail operate 350s.
In any case, the 350s when they are being reliveried (at least the full relivery on the 350/1s and /3s) are having the coach letters removed, much to the displeasure of the people who used them to carry out their job!
Kite159
27 Jan 2014
West of Andover
LNWR is my way of shortening London NorthWestern Railway.
Farewell to the random coach letters on the 350s,
30 Jul 2015
Non RHM 165136 coupled on to the rear of RHM 166217 at Reading on 2P99 2102 Didcot - Paddington this evening. This is the first time I have seen a mixed height pair in passenger use.
Mitchell Hurd
28 Oct 2017
That might be the 6-car Turbo I saw go past the track alongside the Railway Centre at Didcot this morning when waiting for the a bit delayed 08:35 to Ealing Broadway instead of my intended 09:08. It's rare to have a 166 coupled to a 165 in the Thames Valley now.
