GWR Class 387s Paddington to Bristol Parkway from Monday 24th May
Melancholia
21 May 2016
Argleton
Not sure if this has been posted elsewhere, but from Monday 24th May, Class 387s will be running from Paddington to Bristol Parkway in place of IETs, due to the ongoing problems with the IET availability.
I don't know whether it'll be a 4 car, 8 or a 12. Somebody in the know might post below.
The diagram is as follows (and links to RTT):
- 3U44 0508 Reading Train Care Depot - London Paddington 0550 [ECS]
- 9U44 0712 London Paddington - Bristol Parkway 0837
- 9L43 1019 Bristol Parkway - London Paddington 1142
- 9U54 1212 London Paddington - Bristol Parkway 1336
- 5Z54 1349 Bristol Parkway - Swindon 1414 [ECS]
- 5Z53 1432 Swindon - Bristol Parkway 1457 [ECS]
9L53 1510 Bristol Parkway - London Paddington 1643
- 9U66 1712 London Paddington - Bristol Parkway 1836
- 5Z66 1904 Bristol Parkway - Reading Train Care Depot 2007 [ECS]
JN114
28 Jun 2005
They will be 8 car sets (GWR /1s), sets freed up as @StephenHunter says by the temporary loan of 387/3 sets from c2c for Newbury services
31160
18 Mar 2018
Will this be extended through to Cardiff eventually i wonder,could release the IETs that still work to go south west
StephenHunter
22 Jul 2017
The original idea was to use them for additional services to Cardiff when needed, say for rugby, but the 110mph capability of the 387s isn't fast enough for IET replacement long term.
The IETs will return as they are fixed.
cactustwirly
10 Apr 2013
The route from Wooten Bassett to Cardiff is 110mph max isn't it?
So it's only Paddington to Swindon where it's a problem
Horizon22
Jobs & Careers
8 Sep 2019
Crewed with Paddington drivers, guards on at Didcot.
The fact that they're class 9 somewhat surprises me! 'U' is the normal headcode for anything to Bristol Parkway or Stoke Gifford however.
JN114
28 Jun 2005
Being Electric-Only the signallers have to be careful in the Bristol Parkway area if there’s any disruption.
Just a risk-mitigation measure.
Also helps NR identify they’re talking to the right controller at GWR, if there’s a need to; as these are (as with all 387-operated trains) managed by LTV division not High Speed
Horizon22
Jobs & Careers
8 Sep 2019
True, although the Swindon services weren't run as 9's just 1Zxx. But as you say, better safe than sorry just odd to see. Especially from Paddington which already has 9xxx TfL services - hopefully the signaller doesn't get confused and put them on the Relief Lines!
JN114
28 Jun 2005
Swindon doesn’t really have any problem places you can’t send an electric-only train, save the Kemble Line. The pitfalls at Parkway are somewhat more subtle.
TfL don’t (yet) use 9Uxx or 9Lxx on our side of the sewer so should be ok at the London end.
Horizon22
Jobs & Careers
8 Sep 2019
9Uxx running into the tunnels on trial running but I imagine that will be hard to confuse!
Anyone know if these will be running next week too or is it just this week only?
They’re in real-time trains next week. I expect as they’re short term planned they’ll only show the next week, but they’ll almost certainly be around for a good while yet.
66789
28 Mar 2021
Swindon
Due to a points issue at Wootton Bassett Junction one of the 387 runs ended up going through the Goods Loop today. Possibly the first train to go through on the OLE.
JN114
28 Jun 2005
After consulting with colleagues, Apart from possibly a test train while it was being commissioned; we’re confident now that today’s 9L53 was indeed the first electric train to use Wootton Bassett Goods Loop...
Of note the same train ran fast from Didcot Parkway to Paddington, recording an impressive start to stop time recorded by yours truly of 35m 28s, despite a 20mph ESR at Ruscombe; an average of 89.8mph.
Wychwood93
25 Jan 2018
Burton. Dorset.
RTT indicates a departure of 16.21 1/4 from Didcot for a Paddington arrival of 17.06 1/2 - the 9L53 today? - more of a 45m time. I took the 9L43 10.19 from Bristol Parkway on Monday - the Ruscombe TSR a pain, a couple of 8xx powered services ahead of us, good speeds, up to 112, when things got going. RT from Didcot, 1 minute late from Reading and 8 late into PAD. Up to 113 earlier, but the 387s do give a rough ride on poorer sections - I was over a bogie, which makes a marginal (?) difference. Will give them another go.
HST274
3 Mar 2020
Worcestershire
Ye looks like a 1636 3/4 departure and a 1712 1/4 arrival into PAD. That would make it 35 1/2 minutes but could be wrong
