Defiance149
- Joined
- 30 Dec 2013
- Messages
- 401
Can anyone confirm which 800 was delivered from Newton Aycliffe to Doncaster last Wednesday (17th) please?
Sounds like a normal day on the MML to me. The GWR 800 leaflet does suggest coach A should be at the front and first class is at the London end of each set. Now there's more and more diagrams becoming 800 and 802 operation which now have reversals I would it's problem becoming quite difficult to keep each set the same way around so its in the same formation each time.Question for the forum regarding the formation of 2 x Class 800 trains.
I caught the 0726 from Cardiff this morning which was running to London.
The display boards announced that first class was in carriages 4, 5, 6 & 7.
First class was indeed in the middle of the train (of course separated into two halfs) and the two quiet carriages where at the extreme ends of the train.
I had seat reserved in carriage C. The train arrives in Cardiff with carriage G at the front (London end) the second carriage in was H then J (obviously no I ro avoid confusion with a 1).
What formation are 2 x 5 car 800s meant to be in? First class in the middle or at each end? The carriage arrangement seemed odd, not to mention the display boards showing numbers not letters.
Did anyone catch Paddington 24/7 tonight? Section on two of the Hitachi IETs being released from the factory in Italy. The guy, presumably from Hitachi, that shows the camera team around the interior is very proud of the quality, including the seats. Points to the quality of the seat and the covers and mentions there's a lot of leg room.
Mind you, he also points to inside the accessible toilet and says sensors are working and hand dryer is working. Should hope so?
Well, it's the same factory that built the Fyra V250 trains... back then they even had difficulties with properly fitting out the magnet which holds the toilet paper roll in placeMind you, he also points to inside the accessible toilet and says sensors are working and hand dryer is working. Should hope so?
A quick technical question for those in the know - after last weeks incident with the dewirement, what is the state of electric running for the 80x's between Didcot and London? I haven't been travelling much these last two weeks so have not seen for myself
No change from status quo. Certain units occasionally have diesel only restrictions for various unrelated reasons. Not being as involved in the HSS side of things as I was a few months ago I’m unsure whether there are still drivers who only sign the things on Diesel; but that’s also a possibility.
Is it right to presume that 802's now cover most of the daily Cotswold diagrams through Oxford to Worcester, Hereford etc?
There’s been heavily mis-quoted source suggesting some of the 802 fleet was ordered for the Cotswold line. Not so - although many 9-car sets will (if the enhanced timetable ever happens) work Paddington-Oxford fasts. Anything outstabling at Worcester or Hereford should also end up as an 802, as the 800s prefer to be safely tucked up in their depots overnight. But the bulk of the daytime service to Worcester/Malvern/Hereford will be 800s.
Similarly the Paddington-Bedwyn fasts are actually planned for 5-car 800 operation, released off other work by the 802s. Despite many sources (including Modern Railways) suggesting some of the 5-car 802s were ordered for Bedwyn work.
The original 9 car 802 order specifically included a set for the Cotswolds. It was originally diagrammed in the justification to the DfT to be one set doing a morning working before going west and the reverse happening with another set in the afternoon/evening.
What the DfT had as passenger loadings for the North Cotswold line were completely out of date and their proposed mostly 5 car diagrams were inadequate for the task.
I'm pretty certain that would be classed as commercially confidential and not available to the public.Do we know how much Hitachi get every time a service is run?
Vacuum Circuit Beaker? Perhaps Dr Bunsen Honeydew was part of the project team.All 800s and 802s are now restricted to diesel traction only due to concerns about VCB (Vacuum Circuit Beaker) operation.
Going well then... Good thing DfT changed the order so all the GWR sets had diesels.
Thanks for the info there @JN114, however I think my reference to Beaker from the Muppet Show went amiss!Standard component on all AC Electric Traction. Large circuit breaker between the Pantograph and Train Line which isolates the the train electrically from live OHLE when tripped. Circuit Breaker is in a vacuum to prevent arcing as it operates. Makes a loud bang when operated; can be heard twice through neutral sections.
