Gloucester, Hereford, Cheltenham all would have issues with 10 cars that SDO wouldn’t be able to solve (too long to stand between signals/points etc)
Curious about Gloucester as platform 1+2 is long enough for a pair HST's, I assume this issue that 10-car in platform 1 would foul platform 2? In terms of Cheltenham is there not enough land within the NR boundary to extend the platforms at and/move the signals nearer to the A40 so a 10 car could be platformed? Point taken about Hereford surprised if that is the only station on the cotswold line that couldn't cope with a 10-car considering how short many of the platforms are.
No, the lights are on or off. The units go into sleep mode after 15 minutes without an active cab, this puts the lights and HVAC off, the crew can over ride sleeep mode for 30 minutes at a time, but not change the lighting brightness.Technical question, does the train's software control the brightness of the interior lights?
The lighting brightness definitely needs to be changed. Some people have sensitive eyesight...
Given the "airline" style seating on the IETs, perhaps going the whole hog and adding dimmers isn't a bad idea...It's not as awful as the HST, but about 75% of the present level would be good.
I like the bright lights, makes it easy to read and do crosswords. Nothing worse than being sat in dingy conditions. I will check the regs, I am sure there will now be minimum lux levels - more elf and safety gone mad.....
Isn't that what reading lights are for...?I like the bright lights, makes it easy to read and do crosswords. Nothing worse than being sat in dingy conditions. I will check the regs, I am sure there will now be minimum lux levels - more elf and safety gone mad.....
5 Car - 130m longBack to the 5 car v 9 car thing, I noticed in Rolling Stock Review 2018 - 19 that a 5 car iet is 162m long but a 9 car is only 242m. I say only because doubling up a 5 car would be 324m probably slightly more with the coupling points would make a 10 car some 80 longer than a 9 car. That seems a hell of a lot more. I just can`t see how that`s true.
I've had similar runs with HSTs over the years, more in the down direction than the up, e.g. Depart Swindon at xx:40, arrive Parkway at xx:02. I'm also looking forward to the accelerated schedules.On Weds 6th Feb, had my first run under electric power from Bristol Parkway-Paddington, waas 13.03 Parkway-Paddington, 2x5 car 802, again the performance under electric power was impressive, absolutely slaughtered the timings, 22 mins Parkway-Swindon, 24 mins Swindon-Reading, between Parkway and Paddington we spent approx 10 mins waiting time, they have so much time in hand under electric running, can’t wait to see what they achieve when the faster timetable comes out, I expect to see some impressive timings especially the Paddington-Parkway non stops.
That makes sense now. There is no way those earlier figures I quoted could have been true. The rolling stock review publication was obviously wrong. I should have guessed as everywhere else I had noticed 26m for carriage length + coupler facings. Thanks for that.5 Car - 130m long
9 Car - 234m long
Each vehicle 26m long between coupler faces.
Totals so far this week is 11 from a very rough estimate of 800 trains, so just over 1.3%:
MONDAY - 2
TUESDAY - 1 (not including 20:17 Frome to Westbury!)
WEDNESDAY - 0
THURSDAY - 0
FRIDAY - 8
The improvements seem to have coincided with much more use of the new 9-car 802/1s that are still being delivered.
In fact, two Cotswold Line diagrams that are supposed to be 5-car, were covered by 9-car units, so there were the following longforms.
1W19, 09:21 PAD-WOF
1P29 12:00 WOF-PAD
1W31, 15:22 PAD-GMV
1P44, 18:29 GMV-PAD
1W12, 05:47 PAD-WOF
1P22, 08:25 WOF-PAD
1W23, 11:20 PAD-WOF
1P33, 13:55 WOF-PAD
1P22 and 1W31 being especially useful to run as 9-cars as they load well as 5-cars.
I’m pretty pleased to here this because the seemingly increased gamble of “will my seat res. work out” gets boring. At least this removes at least one variable.The reservation system on the nine-car sets has been switched off until all the HSTs are gone, I believe.
Card reservations should be in place instead.
Are all the 5 car 802s accepted already?802101 to 802105 have been accepted. 802106 is due for acceptance next week and 802107 the week after.
The last one, 802114, is due to be accepted around mid-April.
800301 has been in service for a while, 800001 & 800002 are still for Driver training.Was in 802001 today, quite surprised as still not seen 800001 or 800301 in service yet.
Fantastic, thanks. Not long to go now till they're all in.Are all the 5 car 802s accepted already?
