The diesel switch over was obvious and the engine noise (i was in the front coach of a 2 train set) noticeable but not intolerable. Much better in a big, isolated box on the front than under the floor.
Overall: A good modern train.
No doubt the refurbished GWR HSTs complied with this standard. Within weeks they were switched to half lighting and most have remained so ever since!It’s your imagination, the lighting is the same across all fleets. There is a BS EN standard for rolling stock lighting, the 80x meets this. The standard was published in either 2001 or 2002, I forget which and gives limits for lux and glare, stock built before this would be to a different standard, but would have to meet it if refurbed.
The diesel engines on the 800s don't bother me in the slightest, they are pretty quiet. I had my first run to Bristol Parkway on electric power today on the 08:45. Whilst the performance was undoubtedly excellent, the point to point times weren't much better than an HST can do. I've had numerous runs Pad to Reading in 23 minutes and Reading to Swindon in 24 minutes. They'll have to tighten up the dwell times to make much difference.
Not sure if they did have to comply, if the refurb was signed off before this standard and it may we’ll be that half lighting was not signed off, if it was under the new standard, but no one has ever raised it.No doubt the refurbished GWR HSTs complied with this standard. Within weeks they were switched to half lighting and most have remained so ever since!
No new cushions. Only new seat covering material.
Is the cushion actually different on the 802s, like it feels it is, or is it just that they are newer and have not yet collapsed?
NI strongly suspect it’s the Placebo effect. People wanted the 80x to be rubbish; so subconsciously override their own feelings to arrive at a negative opinion. You’ve gone on one thinking it’s different, improved and had a better experience; but factually all that’s changed is the covering material.
But.... the Desiro is a regional train and the IEP has delusions of being an InterCity train. The seating in the 800/802s is utterly unacceptable for an IC train.Seats again (sorry!)
As I noted above, at the weekend I found that the Class 802 moquette seats were vastly superior to the original fabric ones. The cushion appears to be different both in hardness and shape so you don't feel the support under the base as badly and the headrest doesn't cut into your shoulder as much either if you're tall - they make the seat *almost* acceptable, and not *much* different from the perfectly acceptable Desiro seat (Grammer E3000).
I wish it was true but I passed on an 802 yesterday and very definitely had the metal bar digging into my posterior. I think it is just a case of some seats are in a better state than others. Kind of a farce for a brand new fleet....Nope, it absolutely is different. Maybe the moquette itself is what is helping, but the cloth seat definitely "fell down" either side of the supporting bar on the original seat which really hurts my backside (literally like sitting on a fence or gate), and the newer Class 802 moquette didn't (you could feel the supporting bar but only just). I travelled on both types on the same day.
if you don't think foam seats can collapse, try a 350/1 then a 350/3 (or two seats on a /1 where the base has been replaced on one of them, as there have been some piecemeal replacements on the worst seats) - they are exactly the same seats but you will notice a massive difference.
Taking too long to retrofitSeats again (sorry!)
Is this new cushion and cover going to be fitted to the existing ones?
Well I don’t know how they can call the GWR HST style Grammar seats IC either! They’re high density more suited to a regional train I think!But.... the Desiro is a regional train and the IEP has delusions of being an InterCity train. The seating in the 800/802s is utterly unacceptable for an IC train.
If you say so. In terms of materials they are identical. Having travelled on many varieties of rolling stock I’ve never encountered what you describe; but perhaps my backside isn’t as sensitive as yours clearly is.
The interiors were developed by DCA Design International, who are based in Warwick.
No, definitely in my opinion.In your opinion perhaps.
The company also responsible for styling le shuttle locomotives and class 90, among other things.
As I noted above, I had a quick nose underneath a Grammer E3000 in a 350/2 (more comfortable despite being 3+2) and noted that there is a simple design flaw in the Class 800 seat - the E3000 has a hard plastic base on the cushion stopping you feeling the metal bar (which is there in exactly the same location), whereas the 800 seat doesn't. I have no idea who thought this design was acceptable, but they deserve the sack. (If new fire regulations prevented plastic, a piece of sheet steel would achieve the same thing).
Other things about the seat (headrest, height, hardness, h...uprightness ) are just a matter of opinion, but this is just appalling design. If I'd bought one for my lounge, I'd be taking it back and demanding a refund as not fit for purpose.
I’m glad im not the only one to notice the ridiculous metal bar running through the middle of the seat base either. I had to take a few of the IETs last year with the flat cloth seat covers then and it was becoming more noticeable. The newer coverings tend to hide it to some extent but after sitting in the same seat for a pretty tedious journey from Plymouth to Reading in one, you do start to notice it after a while. Who thought to have that bar, running central through the seat, really hasn’t a clue on what it’s like to use them!
Gauge testing run today from Laira to Newquay and return, 802007 and 802012
Of course seats collapse when the foam deteriorates and loses its load-bearing ability. This usually happens over a number of years, though.Neither.
No they’re not any different, but the seats on the 800s haven’t “collapsed” either - they’re as they were when they first came into service; it’s not sprung so it can’t collapse.
Well, they’re certainly good enough and have been good enough for the RailJet fleet in Austria, and they’re hardly reagional .
