Iv applied for Gloucester station.
Got my date for first lot at the end of the month.
What was the group assessment like? Did you find it easy?
Cheers
Cheers
There are details elsewhere on the forum about what to expect, they will give you a general outline of what to expect but it won’t be exactly what is mentioned there. These forums are monitored by TOCs so it’s frowned upon to go into much detail for obvious reasons. As others have mentioned at stage one accuracy is key, there’s no point in finishing any one paper if it’s littered with errors, concentrate on accuracy whilst being aware of the time available, you’re NOT expected to finish! All I would say as far as the second assessment stage is you need to come across as confident without being over confident, as well as inclusive of the opinions and ideas of the others in the group. Don’t be afraid to take the lead but at the same time don’t come across as bossy! If anyone is holding back within the group then look for an opportunity to bring them back into the loop. It’s basically a fine balancing act!
Interview wise just make sure you have lots of examples to relay about;
-Difficult situations you’ve dealt with, both customers and with colleagues also.
- Teamwork examples
- Be clear about why you want the role and what qualities you can bring to it.
-Do a little bit of research about the company, be familiar with any recent initiatives etc etc
I actually found the group exercises quite enjoyable in a weird sort of way! It’s a bit daunting walking into the room to the various managers sitting around the outdoes with you and your colleagues in the middle, but put that to the back of your mind and concentrate on impressing!
Good luck!
