thanks for that am I right in thinking then if conductors role unsuccessesfull it wouldn't affect a second chance at driver assessments as ultimately that's where I would like to end up.really annoyed at the failing the tea-occ as reading on here its difficult to get through the paper sift and have to do that again assuming another trainee role comes upHi Tony - no it wouldn't stop you applying for a Conductor / TM role with GWR. You wouldn't be able to apply for a driving role for 6 months but anything else is fine. You cannot, however, apply for a conductor role; turned down for that and then reapply for TM as the assessments are the same. However if you pass the Stage 1 Assessment and fail Stage 2 your result is valid for 3 years so you wouldn't have to resit it. Hope that helps!
thanks have just applied and completed online assessment fingers crossedYou would be barred from reapplying to a Guards role after failing Driver assessments only if you failed an element of the drivers assessments that is common with guards. Tea-occ isn't one of them.
The 6month rule applies to job groups. For driver this is anything requiring you to do driver assessments, such as Manouverer or Depot Driver
Guards would be any customer service role, so.that could be Conductor, TM, gateline, dispatch, booking office etc
