GWR Dec 19 timetable
Discussion in 'Allocations, Diagrams & Timetables' started by nickw1, 9 Apr 2019.
  1. didcotdean
    didcotdean Member
    107
    25 Jun 2013
    In the early schematic representation of the new timetable service provision, not only did the weekday Cardiffs stop at Didcot, they didn't stop at Reading except in peaks, although that didn't survive into the next iteration.
  2. Wilts Wanderer
    Wilts Wanderer Established Member
    1,033
    21 Nov 2016
    From what I’ve heard along the grapevine, it’s to do with creating freight paths between Swindon and Didcot.
  3. 800002
    800002 Member
    436
    19 Jun 2019
    As in creating additional paths or mainintain the current level of existing paths?
    What with the additional traffic going thatway, i would have thought there wouldn't be much more capacity to offer freight (above what is currently there).
  4. 800002
    800002 Member
    436
    19 Jun 2019
    Going to try to keep this HEX post contained - having now written out the potential diagrams (based on RRT / open data stream output).
    Heathrow Express possible diagrams - from RTT platforms. NOT-OFFICIAL (in any way).
    Five diagrams (presume eight cars each but could be only 4).
    Note: appears all start as 8 x Cl.387, with evening divides. No current schedules to suggest a 4 car start with strengthening during the day. All the evening ECS paths are non-Q, suggesting all diagrams split in the evening to become 4 x Cl.387 from 2040 on wards. Further info suggests no splitting of diagrams is planned by HEx (GWR), planned ECS's reflect current need by HEx and to cover any overlap when timetable change occurs. [Thanks @JN114 ] A point i overlooked was that HEx (GWR) won't (and can't) be using the OOC EMU depot! Silly me (my apologies).
    Note: there appears to be a few platform errors in the evening (so it seems, to my eye, in formulating the below diagrams). I've struggled to make sense of some of the workings (around 1Y84 onwards). The headcode increment at paddington is: Yxx = T+4, untill 1Y84 / 1Y85, when 1Y85 becomes 1Y90 and all then follow Yxx = T+5.
    1Y84 (plat 6) = 1T88 (plat 7) + 1T89 (plat 6)
    1T88 can not be formed by 1Y83 (HEx-02), the previous arrival on Plat 7, as that diagram splits later in the day as 1Y88 - 5Y88 and 1T91 (all plat 6).
    Possible 1Y84 (currently showing #6 at PAD) is showing incorrect platform, and should make 1T88 (currently showing #7 at PD) and 1Y84 (currently showing #7 at PAD) should make 1T89 (currently showing #6 at PAD) and then the pattern prevails till close of play. Means that anything I've proposed after 1Y84 is incorrect. (again, apologies).
    I've edited to remove the evening ECS moves (before close of play), and shall take a look at the late evening schedule when time allows.
    So here is what it looks like is happening:
    Using Terminal 5 as they currently use Paddington (two platforms in Dec 19, vice 1 platform currently)
    Lay over of 25 minutes at Terminal 5 (vice the current 10 minutes)
    Lay over of 8 minutes at Paddington (vice the current 20 minutes)
    There looks to be sufficient turn time at Terminal 5 to absorb any late running, certainly on the down, ensuring a right time start for the up services. They should present to Hex Jn ontime. [the XR pad - T4 and shuttle appear to allow sufficient leyway if they are delayed, with the the up HEX having an on time start from T5]
    I don't see much interaction with the tunnel services, within 6-7 minutes of ontime running, with the exception the the up HEx follows the up XR at heathrow central XR xx26-xx28 / HEx xx31-xx32 and XR xx56-58 / HEx xx01-xx02
    Arrival at pad upto 5 minutes late and it can still probably get out ontime (or within 1 or 2 minutes). The late inward going straight back out when late is neither her nor there really, as it shouldn't be able to get to 25 late or more (affecting the back start from T5 - and if it is, I would suggest the whole of paddington is screwed and the XR will be getting curtailed (probably the Hayes stoppers, rather than Heathrows). I don't foresee the need to cancel HEx if they are within 10 / 15 minutes lateness (obviously depending on circumstances) - it'll just operate 1 in / 1 out at pad, as planned (albeit a bit delayed). If they are all running out of course, it's not an issue. If a single unit is out course however, that could be a different matter.
    With regard to HEx starting late and knock on effects - there is a decent margin (to depart say 3 late, and only knock the incoming GWR - the other arrival are / should be parallel arrivals to the departing HEx). Running on the down at Hex Jn at xx19 + xx49 the HEx is followed by the non-stop bristol at xx23 and xx53; Wales at xx26 and xx59; and Oxfords xx28 and 58. There shouldn't be too much to overcome there.
    Then the xx34 and xx04 HEx is followed by the cheltenham / Bristol slow at xx36 and 10; the bristol slow / WofE at xx40 and 12; and the Oxford / bedwyn at xx28 and 16. Again, this should be plenty of time for all to rumble through with minimum issue if HEx is a little late. They should be able to make up any time pre-reading.
    But time shall tell.
    I make no apologies for length of the post!
    Possible diagrams:
    HEx-01:
    5T22 0402 ex-OOC [a. Pad 0419]
    5Y22 0436 ex-Pad / 5T22 (Q) / 5T17 (Q) / 5Y22 (Q)*
    5Y22 a. T5 0457 - 1Y22 d. 0512
    1Y22 a. Pad 0535 - 1T26 d. 0540
    1T26 a. T5 0602 - 1Y27 d. 0627
    1Y27 a. Pad 0647 - 1T31 d. 0655
    1T31 a. T5 0716 - 1Y32 d. 0742
    1Y32 a. Pad 0803 - 1T36 d. 0810
    1T36 a. T5 0832 - 1Y37 d. 0857
    1Y37 a. Pad 0917 - 1T41 d. 0925
    1T41 a. T5 0946 - 1Y42 d. 1012
    1Y42 a. Pad 1032 - 1T46 d. 1040
    1T46 a. T5 1102 - 1Y47 d. 1127
    1Y47 a. Pad 1147 - 1T51 d. 1155
    1T51 a. T5 1216 - 1Y52 d. 1242
    1Y52 a. Pad 1302 - 1T56 d. 1310
    1T56 a. T5 1332 - 1Y57 d. 1357
    1Y57 a. Pad 1417 - 1T61 d. 1425
    1T61 a. T5 1446 - 1Y62 d. 1512
    1Y62 a. Pad 1532 - 1T66 d. 1540
    1T66 a. T5 1602 - 1Y67 d. 1627
    1Y67 a. Pad 1648 - 1T71 d. 1655
    1T71 a. T5 1716 - 1Y72 d. 1742
    1Y72 a. Pad 1802 - 1T76 d. 1810
    1T76 a. T5 1832 - 1Y77 d. 1857
    1Y77 a. Pad 1717 - 1T81 d. 1925
    1T81 a. T5 1946 - 1Y82 d. 2012
    1Y82 a. Pad 2032 (plat 6) - 1T86 d. 2040 (plat 6)
    1Y82 a. Pad 2032 (plat 6) - 5Y82 d. 2045 (plat 6) (OOC EMU a. 2105)
    1T86 a. T5 2102 - 1Y87 d. 2127
    1Y87 a. Pad 2147 - 1T92 d. 2210
    1T92 a. T5 2232 - 1Y93 d. 2257
    1Y93 a. Pad 2317 - 5Y93 d. 2330 (OOC EMU a. 2250)**
    *5T22 has two paths, from OOC, one 'Q' for ECL into Pad. 5T17 shares 5T22 timings, but ECL (vice RL)
    **5Y93 + Q to Reading
    HEx-02:
    5Y23 (d. 0430 OOC) a. T5 0507 - 1Y23 d. 0527
    1Y23 a. Pad 0550 - 1T27 d. 0555
    1T27 a. T5 0616 - 1Y28 d. 0642
    1Y28 a. Pad 0702 - 1T32 d. 0710
    1T32 a. T5 0732 - 1Y33 d. 0757
    1Y33 a. Pad 0818 - 1T37 d. 0825
    1T37 a. T5 0846 - 1Y38 d. 0912
    1Y38 a. Pad 0932 - 1T42 d. 0940
    1T42 a. T5 1002 - 1Y43 d. 1027
    1Y43 a. Pad 1047 - 1T47 d. 1055
    1T47 a. T5 1116 - 1Y48 d. 1142
    1Y48 a. Pad 1202 - 1T52 d. 1210
    1T52 a. T5 1232 - 1Y53 d. 1252
    1Y53 a. Pad 1317 - 1T57 d. 1325
    1T57 a. T5 1346 - 1Y58 d. 1412
    1Y58 a. Pad 1432 - 1T62 d. 1440
    1T62 a. T5 1502 - 1Y63 d. 1527
    1Y63 a. Pad 1547 - 1T67 d. 1555
    1T67 a. T5 1616 - 1Y68 d. 1642
    1Y68 a. Pad 1702 - 1T72 d. 1710
    1T72 a. T5 1732 - 1Y73 d. 1757
    1Y73 a. Pad 1817 - 1T77 d. 1825
    1T77 a. T5 1846 - 1Y78 d. 1912
    1Y78 a. Pad 1932 - 1T82 d. 1940
    1T82 a. T5 2002 - 1Y83 d. 2027
    1Y83 a. Pad 2047 - 1T87 d. 2055
    1T87 a. T5 2116 - 1Y88 d. 2142
    1Y88 a. Pad 2002 (plat 6) - 5Y88 d. 2215 (plat 6) (OOC a. 2235)
    1Y88 a. Pad 2002 (plat 6) - 1T93 d. 2225 (plat 6)
    1T93 a. T5 2246 - 1Y94 d. 2312
    1Y94 a. Pad 2332 - 5Y94 d. 2340 (OOC a. 0003)**
    **5Y94 + Q to West Ealing
    HEx-03:
    5T19 (Q) ex-OOC d. 0425 a. Pad 0441
    5T18 (Q) / 5T24 (Q) ex-OOC d. 0423 a. Pad 0441
    5Y18 (Q) ex-pad d. 0451 a. HEX Central 0511
    5E23 (Q) ex-W. Ealing d. 0500 a. HEX Cental 0510
    2E23 d. HEX Central 0513
    2E23 a. T5 0517 - 1Y24 d. 0542
    1Y24 a. Pad 0602 - 1T28 d. 0610
    1T28 a. T5 0632 - 1Y29 d. 0657
    1Y29 a. Pad 0717 - 1T33 d. 0725
    1T33 a. T5 0746 - 1Y34 d. 0812
    1Y34 a. Pad 0833 - 1T38 d. 0840
    1T38 a. T5 0902 - 1Y39 d. 0927
    1Y39 a. Pad 0947 - 1T43 d. 0955
    1T43 a. T5 1016 - 1Y44 d. 1042
    1Y44 a. Pad 1102 - 1T48 d. 1110
    1T48 a. T5 1132 - 1Y49 d. 1157
    1Y49 a. Pad 1217 - 1T53 d. 1225
    1T53 a. T5 1246 - 1Y54 d. 1312
    1Y54 a. Pad 1332 - 1T58 d. 1340
    1T58 a. T5 1402 - 1Y59 d. 1427
    1Y59 a. Pad 1447 - 1T63 d. 1455
    1T63 a. T5 1516 - 1Y64 d. 1542
    1Y64 a. Pad 1602 - 1T68 d. 1610
    1T68 a. T5 1632 - 1Y69 d. 1657
    1Y69 a. Pad 1717 - 1T73 d. 1725
    1T73 a. T5 1746 - 1Y74 d. 1812
    1Y74 a. Pad 1833 - 1T78 d. 1840
    1T78 a. T5 1902 - 1Y79 d. 1927
    1Y79 a. Pad 1947 - 1T83 d. 1955
    1T83 a. T5 2016 - 1Y84 d. 2042
    1Y84 a. Pad 2103 (plat 6) - 1T88 d. 2110 (plat 7 RTT)
    1T88 a. T5 2132 - 1Y89 d. 2157
    1Y89 a. Pad 2217 - 1T95 d. 2255
    1T95 a. T5 2316 - 1Y96 d. 2342
    1Y84 a. Pad 2103 (plat 6) - 1T89 d. 2125 (plat 6 RTT)
    1T89 a. T5 2146 - 1Y90 d. 2212
    1Y90 a. Pad 2232 - 1T94 d. 2240
    1T94 a. T5 2302 - 1Y95 d. 2327
    1Y95 a. Pad 2347 - 5Y95 d. 0003 (OOC a. 0021)**
    *5T19 / 5T18 / 5T24 from OOC share same path into pad
    *5Y18 / 5E23 share same path into Heathrow Central (ex-pad / ex-West Ealing EMU)
    **5Y96 + Q to West Ealing
    **5Y95 + Q to Reading
    HEx-04:
    3T24 (Q, RDG) d. 0408 a. Pad 0456 - 1T24 d 0510
    1T24 a. T5 0532 - 1Y25 d. 0557
    1Y25 a. Pad 0617 - 1T29 d. 0625
    1T29 a. T5 0646 - 1Y30 d. 0712
    1Y30 a. Pad 0732 - 1T34 d. 0740
    1T34 a. T5 0802 - 1Y35 d. 0827
    1Y35 a. Pad 0847 - 1T39 d. 0855
    1T39 a. T5 0916 - 1Y40 d. 0942
    1Y40 a. Pad 1002 - 1T44 d. 1010
    1T44 a. T5 1032 - 1Y45 d. 1057
    1Y45 a. Pad 1117 - 1T49 d. 1125
    1T49 a. T5 1146 - 1Y50 d. 1212
    1Y50 a. Pad 1232 - 1T54 d. 1240
    1T54 a. T5 1302 - 1Y55 d. 1327
    1Y55 a. Pad 1347 - 1T59 d. 1355
    1T59 a. T5 1406 - 1Y60 d. 1442
    1Y60 a. Pad 1503 - 1T64 d. 1510
    1T64 a. T5 1532 - 1Y65 d. 1557
    1Y65 a. Pad 1617 - 1T69 d. 1625
    1T69 a. T5 1646 - 1Y70 d. 1712
    1Y70 a. Pad 1732 - 1T74 d. 1740
    1T74 a. T5 1802 - 1Y75 d. 1827
    1Y75 a. Pad 1847 - 1T79 d. 1855
    1T79 a. T5 1616 - 1Y80 d. 1942
    1Y80 a. Pad 2002 - 1T84 d. 2010
    1T84 a. T5 2032 - 1Y85 d. 2057
    1Y85 a. Pad 2117 - 5Y85 d. 2123 (OOC a. 2143)
    1Y85 a. Pad 2117 - 1T90 d. 2140
    1T90 a. T5 2202 - 1Y91 d. 2227
    1Y91 a. Pad 2249 - 1T96 d. 2310
    1T96 a. T5 2332 - 1Y97 d. 2351
    1Y97 a. Pad 0015 - 5Y97 d. 0028 (OOC a. 0101)**
    *3T24 has no other path currently (NOTE: the 5T24 path above ex-OOC is same time as 5T18+19)
    **5Y97 + Q path to Reading
    HEx-05:
    3T25 (Q, RDG d. 0419 a. Pad 0513)
    5T20 (Q, OOC d. 0456 a. Pad 0515)
    5T25 ex-OCC d. 0456 a. Pad 0515 - 1T25 d. 0525
    1T25 a. T5 0546 - 1Y26 d. 0612
    1Y26 a. Pad 0632 - 1T30 d. 0640
    1T30 a. T5 0703 - 1Y31 d. 0716
    1Y31 a. Pad 0747 - 1T35 d. 0755
    1T35 a. T5 0816 - 1Y36 d. 0842
    1Y36 a. Pad 0903 - 1T40 d. 0910
    1T40 a. T5 0932 - 1Y41 d. 0957
    1Y41 a. Pad 1017 - 1T45 d. 1025
    1T45 a. T5 1046 - 1Y46 d. 1112
    1Y46 a. Pad 1132 - 1T50 d. 1140
    1T50 a. T5 1202 - 1Y51 d. 1227
    1Y51 a. Pad 1247 - 1T55 d. 1255
    1T55 a. T5 1316 - 1Y56 d. 1342
    1Y56 a. Pad 1403 - 1T60 d. 1410
    1T60 a. T5 1432 - 1Y61 d. 1457
    1Y61 a. Pad 1517 - 1T65 d. 1525
    1T65 a. T5 1546 - 1Y66 d. 1612
    1Y66 a. Pad 1632 - 1T70 d. 1640
    1T70 a. T5 1702 - 1Y71 d. 1727
    1Y71 a. Pad 1748 - 1T75 d. 1755
    1T75 a. T5 1816 - 1Y76 d. 1842
    1Y76 a. Pad 1903 - 1T80 d. 1910
    1T80 a. T5 1932 - 1Y81 d. 1957
    1Y81 a. Pad 2017 - 1T85 d. 2025
    1T85 a. T5 2046 - 1Y86 d. 2112
    1Y86 a. Pad 2132 (plat 6) - 5Y86 d. 2145 (plat 6) (OOC a. 0205)
    1Y86 a. Pad 2132 (plat 6) - 1T91 d. 2155 (plat 6)
    1T91 a. T5 2216 - 1Y92 d. 2242
    1Y92 a. Pad 2302 (plat 6) - 1T97 d. 2325 (plat 6)
    1T97 a. T5 2346 - 5T97 d. 0003 (OOC a. 0041)
    *3T25 ex-Reading TCD / 5T25 ex-OOC EMU / 5T20 is copy of 5T25 path
  5. JN114
    JN114 Established Member
    2,014
    28 Jun 2005
    The 387s aren’t planned to split on HX duties - the paths to Old Oak are just to provide continuity for the current 332 operations; which will almost certainly run for a short time into the new TT period.
  6. Bikeman78
    Bikeman78 Member
    625
    26 Apr 2018
    I think the problem is mainly in the up direction. Originally they were planned to depart Cardiff Central earlier but they would have conflicted with the XX:45 Nottingham or XX:50 Manchester. If they depart at XX:54 and stop at Didcot, the fast train from Bristol will catch up.
  7. LordCreed
    LordCreed Member
    309
    28 May 2014
    That's the current plan, stepping back each trip onto the following set.
  8. 800002
    800002 Member
    436
    19 Jun 2019
    Thanks for point this out - I've edited my original post to reflect. (I was also silly enough to forget about HEx (GWR) not using OOC at all!
  9. CharlesR
    CharlesR Member
    104
    11 Apr 2019
    Does anybody know what the allocations will be like for December? i.e Will we be seeing 10 cars on the North/South Cotswolds at peak times?
  10. FGW_Lad
    FGW_Lad Member
    115
    19 Mar 2011
    Berkshire
    I know this is not strictly GWR related but as the Reading to Paddington stoppers will be transferred to TFL, will the full 9 car 345s be used?
  11. 700007
    700007 Established Member
    1,036
    6 May 2017
    Near a bunch of sheds that aren't 66s.
    Yes - some are already out testing after PM peak between London Paddington and Hayes & Harlington and it is expected to ramp up this week if all goes well.
  12. Wilts Wanderer
    1,033
    21 Nov 2016
    That is the eventual plan yes, in addition to 345 operation to Heathrow. However both are dependent on the current software/signalling problems being solved. I imagine the backup plan will be to retain enough 7-car sets to operate the Reading service and cut the Heathrows back to Hayes if these issues persist through the Autumn.
    Edit - I believe Heathrow operation has already been deferred from Day One in December to a later date. What this means for 9-car operation is now anyone's guess as I was led to understand the two were analogous due to software patching.
  13. kevin_roche
    kevin_roche Member
    256
    26 Feb 2019
    Yes the Heathrow operation of 345s, known as Phase 2.2, is not planned until Phase 5a, Paddington to Reading, has been running for 3 months at the earliest.
    There is a requirement to validate the running of the TPWS signalling under the ETCS which is how the software on the 9-car units is set up. The current 7-car operation is with standalone TPWS. I believe that the Hayes & Harlington service has also been operated by a 9 car units in the evening in order to test that configuration too.
  14. DaveHarries
    DaveHarries Established Member
    1,677
    12 Dec 2011
    England
    Just wondering but does anyone know why the semifast trains are not using the through lines at Swindon? They are all shown with platform numbers whereas if they used the through lines then any train stopped in the station could be more easily overtaken.
    Dave
  15. HamworthyGoods
    HamworthyGoods Member
    286
    15 Jan 2019
    Depends what they need to overtake, your assumption is passenger overtaking passenger whereas it’s more likely to be passenger overtaking freight, with the freight in the centre roads.
  16. Mintona
    Mintona Established Member
    3,118
    8 Jan 2006
    South West
    There is only one centre road and it is the up main. Platform 4 is the down main so all down trains will pass through platform 4.
  17. Wilts Wanderer
    1,033
    21 Nov 2016
    Thanks Kevin, a most interesting confirmation of what Id heard.
  18. FGW_Lad
    FGW_Lad Member
    115
    19 Mar 2011
    Berkshire
    Perfect, thanks for the detailed response!
  19. Mag_seven
    Mag_seven Established Member
    4,852
    1 Sep 2014
    here to eternity
    Overtaken by what events?
  20. HamworthyGoods
    286
    15 Jan 2019
    The timetable offer and validation process.
  21. Mag_seven
    4,852
    1 Sep 2014
    here to eternity
    Thanks - I actually realised that after I had posted. :)
  22. cle
    cle Established Member
    1,823
    17 Nov 2010
    Do we think there might be scope for double-ending any of the stations, especially on the western end of the network? Many of these stations were used to having 2-3 car turbos, and will now have much longer trains. Not much has been done to any of those stations. The eastern ones too, but at least they've typically had longer trains (still single exits though)
    There is tons of development - it would be great to increase the catchment at places like Hayes (tricky with huge building) and Southall.
  23. traindoorshut
    traindoorshut Member
    19
    25 Aug 2018
    A fuller list for direct services from BPW to PADD for the weekday:
    Direct Services:
    BPW: 657-0702, PADD: 0814 (72mins)
    http://www.realtimetrains.co.uk/train/Y94409/2019/12/18/advanced
    BPW: 0757 - 0801, PADD: 0914 (73mins)
    http://www.realtimetrains.co.uk/train/Y94412/2019/12/18/advanced
    BPW: 0901 - 0903, PADD: 1015 (72mins)
    http://www.realtimetrains.co.uk/train/Y94327/2019/12/18/advanced
    BPW: 0929 - 0933, PADD: 1044 (70mins)
    http://www.realtimetrains.co.uk/train/Y94329/2019/12/18/advanced
    BPW: 1001 - 1003, PADD: 1114 (71mins)
    http://www.realtimetrains.co.uk/train/Y94331/2019/12/18/advanced
    BPW: 1031 - 1033, PADD: 1144 (70mins)
    http://www.realtimetrains.co.uk/train/Y94333/2019/12/18/advanced
    BPW: 1101 - 1103, PADD: 1214 (71mins)
    http://www.realtimetrains.co.uk/train/Y94335/2019/12/17/advanced
    BPW: 1130 - 1132, PADD: 1244 (72mins)
    http://www.realtimetrains.co.uk/train/Y94337/2019/12/17/advanced
    BPW: 1201 - 1203, PADD: 1314 (71mins)
    http://www.realtimetrains.co.uk/train/Y94339/2019/12/17/advanced
    BPW: 1231 - 1232, PADD: 1344 (72mins)
    http://www.realtimetrains.co.uk/train/Y94341/2019/12/17/advanced
    BPW: 1301 - 1303, PADD: 1414 (71mins)
    http://www.realtimetrains.co.uk/train/Y94343/2019/12/17/advanced
    BPW: 1331 - 1333, PADD: 1444 (70mins)
    http://www.realtimetrains.co.uk/train/Y94345/2019/12/17/advanced
    BPW: 1401 - 1403, PADD: 1514 (71mins)
    http://www.realtimetrains.co.uk/train/Y94346/2019/12/17/advanced
    BPW: 1532 - 1534, PADD: 1646 (72mins)
    http://www.realtimetrains.co.uk/train/Y94349/2019/12/17/advanced
    BPW: 1631 - 1633, PADD: 1746 (73mins)
    http://www.realtimetrains.co.uk/train/Y94351/2019/12/17/advanced
    BPW: 1734 - 1735, PADD: 1845 (70mins)
    http://www.realtimetrains.co.uk/train/Y94354/2019/12/17/advanced
    BPW: 1832 - 1834, PADD: 1944 (70mins)
    http://www.realtimetrains.co.uk/train/Y94355/2019/12/17/advanced
  24. Envoy
    Envoy Established Member
    1,220
    29 Aug 2014
    From a quick glance, it looks to me that anybody travelling from say Swansea to Birmingham is likely to have a longer wait at Bristol Parkway for a connection with Cross Country. For example, a Swansea to PAD service arrives BPW at 9.14 but the next northbound XC is not until 9.44 (to Edinburgh). This is likely to mean that people going from places west of Cardiff to Birmingham and beyond are likely to make the change at Cardiff to the Nottingham services - which are usually only 2 or 3 coaches. Throw in the fact that Worcestershire Parkway station is also likely to open with the December timetable change and we could well find that the Cardiff to Nottingham services won’t be able to cope with the increased demand. (They can barely cope now - with most people from places west of Cardiff making the change at Bristol Parkway for the Midlands).
    * Places west of Cardiff do of course have their own direct services to Manchester via The Marches route (Shrewsbury) which also has links to Scotland via a change at Crewe. It is people heading to/from The Midlands and north-east who are likely to be affected by a poorly matched change at BPW and would put added pressure on the direct Cardiff > Birmingham > Derby > Nottingham trains.
  25. kevin_roche
    kevin_roche Member
    256
    26 Feb 2019
    In Mark Wild's latest monthly report which is now published on the TfL website he says:
  26. Bikeman78
    Bikeman78 Member
    625
    26 Apr 2018
    It's not as bad as you think. Typically the trains from Swansea arrive at XX:53 and the XC to Birmingham departs at XX:09.
  27. 50031
    50031 Member
    160
    28 Aug 2013
    I notice the 387 Swindon Cocklebury-Didcot ECS movements, seem to be via Swindon platforms for reversal. No Swindon starters in the new timetable. Will GWR start some back from Swindon once the timetable beds in, or in May?
    Also, they are marked as 75mph Sprinter when empty stock, then become EMU 110mph when in passenger service from Didcot.
  28. JonathanH
    JonathanH Established Member
    2,302
    Why would they do that?
    Are you suggesting some kind of demand between Swindon and the stations from Cholsey to Tilehurst?
    Possible reasons why this could not happen include:
    * They (presumably) can't operate DOO(P) from Swindon so would need a guard as far as Didcot
    * I guess that LTV guards don't sign Didcot to Swindon
    * I don't suppose that any other GWR train managers sign 387s
    * Demand between Swindon and Didcot at the relevant times is met by the IEP services.
  29. 50031
    50031 Member
    160
    28 Aug 2013
    Because it was reported as a proposal to to start back some 387s from Swindon (Morning only) , in any case, the intention has been to clear 387s through to Cardiff as Crowdbusters for Rugby and other events..
    Obviously I'm not suggesting demand from Swindon to Cholsey, Goring, Pangbourne, Tilehurst!
  30. JN114
    2,014
    28 Jun 2005
    No GWR Guards sign 387s full stop. They are only operated DOO(P) at present.
    DOO agreement prohibits extensions of DOO operations beyond its current Geographical limits; so Swindon will require Guards.
    There have been aspirations to run 387s in regular passenger service to/from Swindon; to date they are only aspirations with no firm/committed plans.
Share This Page
